Question about RCA R52WM24 52" HDTV Projection Television
Didn't know it did not have an internal turner
We have a 52" RCA HDTV (as it turns out) MONITOR. (RCA R52WM24) We do not currently have an actual cable box, although we do have cable service. How do we receive the cable signal with no coaxial jack on the tv? Are there external tuners, or is there an adapter of some sort? Thanks for any help.
  • 147 Answers
Any VCR with a tuner will serve the purpose. Simply connect the cable to the VCR and then hook the VCR to the Tv using the composite outputs ( yellow, white and red ). If you don't have a VCR buy a used one for ten bucks.
Posted on May 14, 2009
I have a 52" RCA
The deflection board needs replacement. You need the PSB260 deflection board available from www.tvrepairworld.com
May 17, 2011 | RCA R52WM24 52" HDTV Projection Television
Need tp replace power cord how do i do that
The RCA R52wm24 most likely has a push in cord that is very similar to a computer monitor cord. Radio shack sell them over the counter. Also most TV shops will have them used and sell for a few dollars. WE do all the time.
Please leave feed back
Feb 21, 2011 | RCA R52WM24 52" HDTV Projection Television
52" rca hdtv monitor power flashes 3 times after pushing it and tv does not turn on.
Hi
Thanks for using FixYa. On the Deflection board there are 3 capacitors CP 114, 120 and 150. 3 blinks occur if any of them is puffed up on top. To resolve this issue you'll have to replace all the 3 capacitors CP150 2200UF 16, other 2 are 220UF 35v they will be green with gold writing on them. Also re solder all pins on Fly Back Transformer (FBT). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 10, 2010 | RCA R52WM24 52" HDTV Projection Television
I NEED TO KNOW WHICH KIND/ITEM# OF PROJECTOR LAMP FOR A RCA R52WM24
look for the model number on back of your tv then go on google and type brand and model and part you are looking for e.x Lamp
Feb 08, 2010 | RCA R52WM24 52" HDTV Projection Television
PICTURE IS WARPED WITH GREEN RED LINE AT THE TOP HOW DO I FIX IT RCA R52WM24
Convergence is dead,must replace covergence it wth convergence kit,what in that kit.U know how to solders?Tries thes websites Tv repair world.com,Tv repair kit.
Oct 31, 2009 | RCA R52WM24 52" HDTV Projection Television
RCA R52WM24 52 in TV
the RCA service bulletin says to replace FL231, DL231 and CL230 all at the same time then reflow the solder on the flyback and the vertical output IC
Feb 07, 2009 | RCA R52WM24 52" HDTV Projection Television
About rca model r52wm24
I have no clue what your trouble is unless you respond to the origional post each time. can you let me know what your symptoms and or trouble was and I will try and assist you.
Jul 28, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA R52WM24 52 in. HDTV convergence IC location
the rca itc222 chasis uses no stk the convergence is controled with transistors... the convergence amp board is located above the main signal board(green board)... it can be identified as the one with several heat sink fins on it. FL231 is related to convergence.. there has been a problem with this fuse when it blows the processor doesnt know it is a projection set so it turns it into a regular tube tv. Here at the shop we have found number one reason this fuse blows is poor solder connection on the flyback. So replace the fuse and reflow the solder connection on the flyback and around that area also the horizontal transistor and then see if that doesnt fix the problem.. if you have an more trouble ..... willie@fordtv.com
Feb 29, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA R52WM24
271852 small signal board, 272082 main input, 271866 fav def
Dec 05, 2007 | RCA R52WM24 52" HDTV Projection Television
RCA R52WM24 52" HDTV Projection Television Logo
114 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
