Question about RCA F32450 32" TV
Rca tv wont turn on after lightning storm
My 5 year old 32 in rca tube tv will not work after a lightning storm.  The tv now makes a loud buzzing sound.  I can smell it getting hot or electrical smell after being pluged in for a little while
Than you
  • ccdwolfeman Aug 24, 2008
    I have 3 tv's that will not turn on after a lightning strike. seems that I have no power and no odor. thanks, chuck Wolfe
  • 143 Answers
This is tipical you have some caps in the main ac power supply that are designed to take a spike of ac one is probably open or shorted if you are brave open set and see if you can see where smell is comming from.get back to me
Posted on Nov 02, 2007
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
It is high voltage section failure
better call skilled tech to fix it.
Posted on Oct 15, 2007
RCA 35" tube tv buzzing
Its probably the power coil. It it's buzzing it wont be long before it goes. you can try degaussing it if the TV has that ability otherwise you would have to bring it into a shop no idea on the estimated repair cost.
Thanks
Dustin
Jan 22, 2011 | Televison & Video
RCA TV, model number 32V550T. No picture but sound is fine.
hiya
this sometimes is quite simple to fix as it cud be a dry joint on the circuit board where the tube motor sits.
or it cud be the tube is on its way out, which wud be cheaper to buy a new tv rather than have it fixed
rik
Feb 24, 2009 | RCA 32V550T 32" TV
Rear screen tv
replaced flyback transformer
Sep 17, 2008 | RCA F36650 36" TV
Hdtv dlp 52 inch loss of picture and loud buzzing noise
Please see http://www.fixya.com/support/t1011937-transformers. It sounds like your flyback transformer is not properly soldered down/is failing.
Sep 06, 2008 | RCA HD52W59 HDTV Projection Television
Sound at power on
The sound you are hearing is the degausing coil which will vibrate for a second when the tv is turned on. This part demagnetizes the picture tube and this sound is really quite normal. Depending on the position of this coil it may vibrate against the front cabinet of the tv and may sound loud at times. If this really bothers you then you need to have the rear cover removed and have it repositioned a bit do it won't vibrate so loudly. Or you can enjoy the buzz for the short time it happens and not worry about it.
Jan 23, 2008 | Sony FD Trinitron WEGA KV-32HS420 32" TV
My Sony tv CRT
If it's between 5-10 secs, that's normal. You will turn the tv on and hear a loud (buzz/hum) that is the picture tube firing up, once it's fired up, it has a few more seconds until your picture comes up fully. That is about 5-10 secs from pushing the power button.
If it's taking longer than that, your picture tube may be going out.
I had a 36XBR250 and it took about 10 secs to fire up and show a picture, and it was 5 1/2 years old.
Nov 25, 2007 | Televison & Video
Rca buzz me off
Do you picture and sound normally in the background?
Nov 04, 2007 | RCA F32450 32" TV
RCA TV stopped working
Time to go to BEST BUY and nuy a better tv
Oct 13, 2007 | RCA 32F531T 32" TV
TV wont come on
Most likely cause would be a blown fuse on the power supply if you are getting no lights on the front, no response from the buttons, and no warmth from the back of the set. First check that not only is the power socket in the wall working, but also that the plug on the TV power cord is not faulty or distorted so it doesn't make the circuit when plugged into the wall, also if it has a fused plug, check that. Then if you feel up to taking the cover off, make sure the set is unplugged and leave it for a few minutes first. take off the back cover (usually a few screws around the base of the set, but it should be obvious) follow where the power cord enters the box, and about the first thing it should connect to is likely to have a fuse. Probably a couple of metal spring clips with a glass tube type fuse sitting in them. The fuse should have a rating stamped on it and you should be able to get a replacement at most hardware stores, but make sure you get the same type as well as rating. If a replacement fuse doesn't cure the problem then the next thing to suspect would be the transformer and rectifier circuit - the fuse should have protected these, but sometimes it doesn't work that way. If you need help checking these then please ask again, but I suspect the fuse is your problem. Hope this helps you out, please ask again if you need more info :)
Mar 24, 2006 | RCA F32450 32" TV
RCA F32450 32" TV Logo
407 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
