Nothing on screen but coloured lines.Started with thin lines but now thick ones
It sounds that the T'Con board to this set is faulty. Before replace it, re-seat the flat cable [LVDS], that connects this board to display panel. If here is any loose contact at any of the two socket-ed terminals at its both end, this kind of fault can occur. If you wish to get some details, check the site linked here. Pull up older posts. Screen-shots to defective LCDs are given. You can compare it to that of your TVs' and can make sure about the fault. http://electronicshelponline.blogspot.com/
SOURCE: thin vertical red line
This maybe the symptom of a bad Panel. One Vertically This line is 99% bad panel. Call your warranty provider or SONY tech support if purchased under 2 years.
Best regards
CircuitCity
SOURCE: My KDL46X3100 has developed two thin black lines
It is problem of LCD Panel that will be replaced.
Please check with dealer / store for extended warranty option.
SOURCE: Thick lines descending plasma screen
maybe you have interference with other electrical component near your tv. move the component, example cable box, dvd, sat box.
