Question about GE Profile JGSP48 Gas Kitchen Range
Oven does not stay lit.....
Bought a used GE Range Model # JGP35BEA2BB and I've been sorry ever since.  Converted it to LP.  The sealed burners and broiler work fine.  However, when we turn on the oven and program it to 350 (just an example) it takes forever (5 min +) for the burners to come on.  Ignitor is a very bright orange.  When the oven comes on it will get to about 225 and then start going on and off.  Then comes the smell of LP.  Of course I shut it off at that time.  Of course, when I bought this the owners said it worked just fine.  Did I get ripped off or do things with conversions sometimes go awry?
Without regard we would like to have a solution to the oven problem.  I'd just love to bake some cookies and the broiler just doesn't cut it.....
Thanks so much,
Patricia
  • patrishka Oct 15, 2007
    Just ordered the ignitor......will let you know if that fixed the prob.  Thanks for your quick response.  A warning to anyone buying a used stove:  Check it out thourghly before you buy no matter how long it takes!!!
  • meenie May 25, 2008
    The bake on the gas oven wouldn't work. We replaced the igniter. While testing it, noticed that the igniter stays on. Not sure if this is the way it should work. Flame actually hits the igniter as well.
  • 943 Answers
HI thanks for your question. yes the igniter stays on all the time the flame is on, it keeps the safety valve open to give you gas. and yes the new igniter will work. thanks
Posted on Oct 14, 2008
Whirlpool WFG510S0AS2 range - stove burners work just fine, but both the oven and broiler does not stay lit. NOTE - this unit has been converted from natural gas to LP
when the lp conversion is done , it is normally just a jet size change that is done
however the air shroud has to also be adjusted to get a clean blue burn of the flame
The just jet change results in a slightly yellow flame which is incomplete burn of the gas and that creates carbon build up at the jet and burners causing partial blockage
I would suggest that you call in an accredited gas fitter to check the problem and if necessary , clean the jets and adjust the air shroud
Dec 30, 2015 | Whirlpool WFG510S0AS
Changed maxitrol regulator to lp to much pressure
If you only changed the gas regulator for use with LP (the regulator located at the connection of the gas service) then you still need to change the orifices for all burners, top and oven. Of course I assume this model can be converted for use with LP. Some models cannot. A new range that can be converted for LP typically includes the needed LP orifices. A card with the LP orifices is typically located at the gas regulator.
May 31, 2014 | Kenmore 72132 / 72134 Gas Kitchen Range
I got a GE gas range (model JGBS22) from a co-worker. She had converted it from gas to propane. I just had a plumber hook it up to natural gas but, even with the conversion manual, he couldn't change the...
There should be a set of orifices for each burner as well as the oven and broiler. When the unit was converted to propane, these orifices should have been replaced and the ones for gas put in with the conversion kit installation information. The kit should have been reattached near the pressure regulator.
If the kit was missing the orifices, then, yes, you are missing pieces. Check with your coworker if the conversion kit was missing. If you have the kit, it can be easily done by any appliance installer (or repair person) licensed for handling NG. (At least on our range, the conversion kit installation was straight forward. Every orifice was clearly labeled with the labels different for each burner and for the gas/LP kits (ABCD (NG) vs MNOP (LP)) .) The regulator is the only part that switched for LP or NG without the kit.
As I recall, the only tools we needed for the top burners were a small wrench (10 mm) and a small flat blade screwdriver. Remove one orifice and put in the appropriate replacement. Then adjust the burners so that they didn't blow out when the oven was opened or quickly turned from high to low (for the simmer burner). The oven and broiler took a bit longer. Several screws had to be removed to get at the orifices. Then the air flow had to be adjusted for the incoming gas.
I hope this helps.
(the conversion installation manual was on the counter during installation; I read it while it was open.)
Jan 14, 2011 | GE JGBS22 Gas Kitchen Range
HOW TO CONVERT FROM NATURAL GAS T PROPANE
Their are 2 types of ranges. Ones with sealed burners and ones that do not have sealed burners. The sealed burner ranges must have a kit to replace the orifices. The none seal burner models are simply called crank down and flip models. That means you flip the screw on top of the regulator to where it reads LP. and then you tighten down the spuds on the top burners and the oven valve and then you adjust the air shutters.
Note: Some stoves with sealed burners cannot be converted to LP. The model number you posted is not a correct model number.
Nov 19, 2010 | Kenmore 72002 / 72004 Kitchen Range
Can this gas range be converted to lp gas maytag performa
moz-screenshot.pngmoz-screenshot-1.pngTurn off the gas supply.
Locate the gas valve regulator. Unscrew the top cap on the regulator,turn it over and re-install it.It should be marked NAT. LP.When correctly converted you will be able to read LP.
On the Performa all the conversion parts should just be adjustments. Remove the oven racks,remove the oven base pan,remove the oven flame spreader pan to access the safety valve. Take a 1/2 inch open end wrench and tighten the orifice on top of the gas safety valve. Tighten it until it is snug.Remove the top burners and raise the top to access the surface gas valves.Tighten the valve spuds until snug. Re-assemble all parts.Turn the gas back on and lite the burners. Turn them high and low to make sure they stay lit. If any burner is not right tighten or loosen the orifice spud for that burner only. All air shutter adjustments should be full open,
Dec 02, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Oven gas will not flow with pilot lit
There are basically two types of ranges to deal with:
those with sealed top burners, which are pretty much the standard today, and the conventional, 'non-sealed' ones.
While they operate in much the same way, their conversion is usually different. There are still a few ranges that use adjustable sealed burner orifices, but most are 'fixed' and must be individually replaced to convert each burner from one fuel to another.
(An orifice is simply a small brass fitting with a specifically sized hole very accurately drilled through it, and, if adjustable, has a provision to change the size of this hole by turning closed a threaded portion).
Either way, basically what you're doing when going from natural gas to LP is changing to a smaller orifice to allow for the higher pressure supplied by the 'bottled' gas (The available energy in each ft of gas is different too, but for our purpose here that's not important). Natural gas supplies typically run around a pressure of 5.5 inches water column, while LP runs at twice that pressure, averaging around 11 inches.
The orifice through which the gas travels to the burner must be smaller to accommodate this difference.
Adjustable orifices are simply 'snugged' down, clockwise, with a 1/2 inch open-end wrench, to convert them. Nearly all oven burners use these too - more about that in a minute.
Fixed orifices are replaced, and the good news is: the LP parts are usually included with the new range. On some brands (GE being one), the unused set is attached to a storage point on the stove, and this is a great idea. This way, they can't get lost, and if you ever want to convert back, there they are!
The not-so-good news: these little top burner orifices very often require a metric wrench to remove & install. And some can't be changed without a very slender wrench or nut driver.
Aug 08, 2009 | Imperial Kitchen Ranges
Oven Burner is giving a yellow flame
new ge range, converted to lp. oven flame is going up the sides of the oven and air shutter is all the way closed.
Nov 23, 2008 | Kitchen Ranges
Oven won't stay alight . has never worked from new . have checked all thermocouple connections all seem's well. probe is tight and in correct position.
To post a more specific solution you need to have the model number, but with the info you have given, I'm guessing that you have hooked the range up to LP gas and the range was not fully converted from natural to LP. If all burners burn nice, whomever converted the range may have missed one step. Many ranges with pilot lights have a small slot head screw behind the oven temp set knob which turns one way for natural, one way for LP.
Sep 16, 2008 | Kitchen Ranges
Low flame
so you stove was converted from natural gas to LP using WB28K10043 KIT-CONVERSION L.P. ? is this correct?
Aug 23, 2007 | Hotpoint RGB745 Gas Kitchen Range
GE Profile JGSP48 Gas Kitchen Range Logo
160 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
