Question about Onkyo TX-SR605 Receiver
Onkyo TX-SR605 - Suddenly switches itself off and back on
Unit has suddenly started switching itself into standby mode then immediately switches back on again. Unit is about 18 months old. no problems up to now. This can occur several times a day. Happens in Receiver mode and whilst watching satelitte.
  • bernard682 Aug 28, 2009
    Problem solved. Electicity supply to house was arcing at supply 100 amp fuse. Eventually this fuse blew and all electricity to house was lost. Supply company restored power and no problems anymore. It seems as though Onkyo was most sensitive component.
  • 6,784 Answers
HI, this is a reset procedure that this unit is trying to initiate. there has been a surge of some sort that the system has survived but, there is some lasting damage as well that has resulted in a slight programming error within the mother board.
This unit has a program that was installed at the manufacture. it runs the basic operations. there has been some major damage that is causing the internal program to stall and reset itself. the only way to reprogram is to send it back to the manufacture or, you can locate a local repair depot through Onkyo. the Onkyo techs are the only option when re programing is needed.
Posted on May 13, 2009
ONKYO tx-sr605 HDMI CHANNEL 2 INTERMITTENTLY SWITCHES TO STANDBY
Check the Ohm value (4, 8, 16...) on the speaker and on the ONKYO too.
If not the same that is the (big) problem!
Nov 24, 2007 | Onkyo TX-SR604 Receiver
Tip
Onkyo TX-SR605 Manual Download
Download Onkyo TX-SR605 Manual
Models: RC-682M / TX-SR605 / TX-SA605 / TX-SA8560
Have you misplaced your Onkyo TX-SR605 Owners Manual?
Would you like a digital, searchable, pdf version of the Onkyo TX-SR605 Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
________________________________________________
RC-682M Remote Code List & Programming Guide Here.
on Apr 20, 2010 | Onkyo TX-SR605 Receiver
Tip
Onkyo TX-SR605 Remote Codes
Download Onkyo TX-SR605 Remote Codes
4 Digit Onkyo Remote Codes
Have you misplaced your Onkyo TX-SR605 Remote code list / Owners Manual?
Would you like a digital, searchable, pdf version of the Onkyo TX-SR605 Universal Remote Code List Users Guide?
I hope that helps.
Download Onkyo TX-SR605 Users Manual Here.
on Apr 20, 2010 | Onkyo TX-SR605 Home Theater Receiver 7.1...
My onkyo tx-sr605 7.1 a/v tuner will not switch from game/tv to cable/sat or any other mode. I can't even get into the setup moder It won't power on even if I press the power button manually.
You have this all backwards. So essentially it won't power on. THAT must happen before setup or anything else.
http://www.retrevo.com/support/Onkyo-TX-SR605-Receivers-manual/id/2526bh742/t/2/
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Aug 21, 2011 | Onkyo TX-SR605 Receiver
Tip
I hope that helps.
The receiver sr605 display is not working. The only light on the unit that works is the red standby.
have you attempted to unplug it and plug it back in 2 mins later--sometimes a hard reset is all thats required...
Sep 04, 2010 | Onkyo TX-SR605 Receiver
I recently bought TX-SR605 7.1 receiver it was working fine but lately whenever i switch the on button it comes back immediately to the standby mode, can somebody help me out
Its possible that the Receiver is going into protection mode and possible some speaker cable might have touched the body or with each other.
Remove all inputs and outputs and then restart the receiver. If it starts then you are lucky. Connect all cable and wiring properly and ensure that they do not touch each other. You might have to reset the microprocessor if the recevier has got.
If the problem persist then let me know to further the trobleshooting.
Please do rate this solution and thanks for using FixYa.
Mar 04, 2009 | Onkyo TX-SR605 Receiver
Brand new Onkyo Tx-sr605 won't leave stand by
If the unit will not leave standby I would remove all power, disconnect *all* connections at the back, reconnect to a power source and try powering on. This will eliminate any connection causing the Onkyo to stay in standby due to a short. If it still will not enter power-on mode, you may want to look at the power source (is it properly grounded?), but beyond that the unit probably needs to go back.
Nov 03, 2007 | Onkyo TX-SR605 Receiver
Onkyo TX-SR605 Receiver Logo
547 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
