Question about Sony Handycam CCD-TRV608 Camcorder
Recording When I oush the record button on the back and top it will not record. The VCR mood works fine.
    Problem Solver:
  • 16 Answers
Is this camera brand new or old? If it is new, I sugesst that you check with your manufactuer. If it is old then you should go to your local sony store and get it checked out
Posted on Jun 14, 2008
I have problem with my pd 170 when i push recording switch it gos on paus mood
There are three buttons for recording. Please try the other two buttons ( one is on the top, other is under the handle) if the recording starts with any of the buttons, then your main button will be faulty. You have to get it replaced.
Hope it helps. Don't forget to rate me.
Thanks for using FixYa.
Jan 15, 2011 | Sony Dvcam DSR-PD170 DV Digital Camcorder
I pushed the otr button by mistake and now I can not stop it from recording or turn off the vcr.
OTR stands for one touch record, each press of the button will increase the recording time. However if you keep pressing the button it should go back to "0" and stop!
Feb 22, 2010 | Emerson EWV603 VHS VCR
I am attempting to record from a VCR tape to
I have a Magnavox MWR20V6 and I am attempting to record a Tv show but when I play it back the recording is just black.
Jan 15, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox TV: Somehow the record button on the remote will not record VCR. It ejects the tape and does not record. Please help. Thank you.
Try Using a new VHS tape. If the new tape ejects when press recording, the recording switch inside your VCR could be defective.
Let me know if you require further assistance.
Aug 26, 2008 | Televison & Video
Timer recording
is there a lithium battery in your vcr to back up short power outs?check for that battery short,and replace it if needed.
Apr 27, 2008 | GE VG4250 VHS VCR
Error code E 4 54040990
You need to go into the set up menu and select recording options. On the recording options menu, scroll down to dubbing options. On the dubbing options menu select either VCR to DVD or DVD to VCR.
Recording and Dubbing are not the exactly the same thing. You use the record buttons to record TV directly to VCR/DVD you use the dubbing buttons and set up to record DVD to VCR or VCR to DVD.
Hope this helps.
Dafid
Apr 16, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
VHS Recording Tape
not much of a help but sounds like your record head is bad on the vhs heads,
use cleaning tape try that, if that fixes great, if it helps but not fully there, you might have to clean them by hand with very soft paper town and rubbing alcohol rub side to side very easy , if none of the above work you have a bad record head or record board, not worth repair vs cost
good luck
Aug 25, 2007 | Philips Magnavox 20MC4304 20 in....
Recording From An External Device
The following Models can be used as a recorder to record from a VCR, TV or another Camcorder. 2004 - SC-D107 2003 - SC-D5000, SC-D27 2002 - SC-D180 Recording In Player Mode 1. Connect the camcorder to the VCR or TV with the AUDIO/VIDEO cable (provided) (to the A/V Outputs on External Device) 2. Set the power switch of the camcorder to PLAYER mode. 3. Turn on the VCR or TV. 4. Insert the blank tape with protection tab closed into the camcorder. If you want to record from a connected VCR, insert a recorded VHS tape into the VCR. 5. Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. 6. Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. "AV IN" and picture appears on the LCD monitor. OUT : Releases the INPUT mode. 7. Press the START/STOP button to set the camcorder to REC PAUSE mode. "PAUSE" appears on the LCD monitor. 8. Select the TV program or playback the VHS tape. 9. Press START/STOP button to start recording. If you want to pause recording for a while, press the START/STOP button again. 10. To stop recording, press the (STOP) button. Notes: * Recording from an analog VCR to the camcorder is only possible when the VCR is playing back at normal speed. * If you want to see the camcorder picture with a TV, set AV IN/OUT in the menu to OUT.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Sony Handycam CCD-TRV608 Camcorder Logo
26 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Jose Ma DM.
Jose Ma DM.
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
