Question about LG RUMOR Cellular Phone
My compter does not regonize my LG Dare or Sd Card? How can I sync music to my LG Dare with the software. My carrier is Telus and I did not get the cd with any of the downloads to do so?
    President:
  • 2,559 Answers
In order for the phone to work with ur pc u have to set/change the connectivity.
Go into Phone settings, then Connectivity, then USB Connection Mode, then select either Mass storage or Data Service, to use Mass Storage you must have a Memory card inserted into the phone, then you can select mass storage and use your phone as an external hard drive/memory stick. In this mode u can only transfer pics, music, videos etc from pc to phone and vice versa via your Computer Windows Explorer.
It will not enable you to use the LG PC suite Application. To use the LG PC suite, you must select Data Service, then connect your phone to the PC via a USB port.
Posted on May 13, 2009
I have a LG dare cell phone and want to transfer some pictures to my Laptop. Lap top is running windows vista 64 bit. when I connect the usb the pc does not recognize the usb connection. It recognizes all...
Well, for music...
Install the supplied software for your Dare on your computer.
In "My Music" select "Sync".
You can now see your Dare as a USB device but only music is accessible. :{
For photos the easiest way is to use a micro SD card and a card reader.
Store or move photos from your internal memory on your Dare to the micro SD card.
Transfer the micro SD card to your computer with either a built in card reader or a USB card reader.
The next alternative is to use a program like BitPim which can be a little tricky and can delete or copy all of your personal data (images, tones, contacts, etc...) depending on which button you press. The two buttons look very similar. Great way to download free ring tones and upload to your phone for free.
Oct 27, 2009 | LG Dare VX9700 Cell Phone
The music on my sd card has about 200 songs on it and when i put in my lg dare it shows that i don't have any songs on there at all??? help......
Turn off your phone, remove and reinsert the card and turn on your phone. Browse to your music player and refresh the music library before trying to play any music.
Sep 01, 2009 | LG Dare VX9700 Cell Phone
I cant transfer music or anything from my pc to my phone
Install the provided LG Dare software on your computer.
Using your USB cord, connect the phone to the computer.
Open windows Media Player.
Media Player should see your phone.
In the sync screen, drag music from your library to the sync column and then select sync.
This will copy the selected music to your phone.
Photos are easiest with a micro SD card, otherwise, you need software like BitPim.
Transfer photos to and from the micro SD card and the insert in your phone.
Aug 04, 2009 | LG Dare VX9700 Cell Phone
Music on my sd card does not show up in lg dare and it will not play any music. i know that there is music on the sd card because when i put it in my sandisk it loads music and says i have quite a...
the dare needs to see it in a file labeled MY MUSIC. it will not recognize your music files if they are not in that folder. Just like videos have to be in MY FLIX and pictures in MY PICS. good luck
Jun 23, 2009 | LG Dare VX9700 Cell Phone
I cannot connect to my V CAST. When I plug my Dare into the Computer to Try to SYNC my music, V CAST says "Connection Failure- Please check your cable connection to the PC" It is all connected but I don't...
WITHOUT sd card
go to my music, sync
should get red screen that says connecting...
then
v cast mobile phone
internal memory
select what program you use to sync with wmp, media monkey etc.
if you cant get that far make sure you have needed drivers, if possible try with different pc and or different usb port and i did have a bad oem usb cable
Jun 07, 2009 | LG Dare VX9700 Cell Phone
I have an LG dare
If your just trying to get music on to your phone plug it in and pull up windows Media player on your computer. Go to rip and when it says to insert device on your phone go to my music and touch the sync option and let it to it's then you should be able to put music on that way
Jun 04, 2009 | LG Shine KE970 Cellular Phone
How do you get music on your verizon phone without paying monthly
Using your supplied USB cable, connect your phone (after installing the drivers) to your computer.
On your phone, goto "My Music" and click on "sync".
Option 1:
Your Windows "Portable Device" connect pop up should appear.
Double click on "Sync digital media files to this device..." OR
Jan 05, 2009 | LG Dare VX9700 Cell Phone
My memory card wont work !
You have to install the USB sync drivers from your supplied CD-ROM before you can sync music.
Then select the "Music" option this will likely give you a prompt on your computer as to what to do next...
Dec 09, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Trying to sync music onto my lg dare
Instead of doing the sync music, try saving your music into your itunes account or on a flash drive. Than just plug your phone into the computer, click on settings, then tools, then USB mass storage. Open the file on your computer, than simply drag and drop your songs from the file on the computer or flash drive, into the phone's file folder. Drop it into your memory card on your phone or just in my music. (I personally recommend getting a micro SD card for the phone so you can hold more songs) good luck!
Nov 18, 2008 | LG RUMOR Cellular Phone
LG RUMOR Cellular Phone Logo
694 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
