Question about Kenmore 22422 Top Load Washer
After filled with water do not do anything
Kenmotre 24622300 will fill with water but cycle do not star
  • work350 May 15, 2009
    That was the problem. I found it when checking for any loose connection. Thanks ANYWAY.
  • 5,911 Answers
A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, repairclinic.com or appliancepartspros.com. Just use your model number as your search criteria. All three sites offer competitive pricing, so shop all three for the best price. If you still need assistance, please contact me and let me know. If my diagnosis is not correct, please post back and elaborate a bit more so I can assist you further. If your washer is not configured this way, or if you still have questions, please let me know.
Posted on May 14, 2009
My washer initial had a rinse cycle problem where no rinsing occur after washing, now it spreads to the wash cycle where it is pausing at the this cycle, need urgent advice
The problem is you are not getting cold water fill. (rinse is all cold water fill) Check to see if the inlet screen is plugged by turning valve off that supplies cold to the hose attached to the machine, then removing the hose at the machine and checking the filter inside the water valve where the hose was just removed from. If screen is not blocked, replace water valve.
Nov 20, 2011 | GE Washing Machines
Machine won't fill with water
Check that the inlet screens on the water supply are not clogged.
Make sure the water is for certain turned on (assuring nothing has changed).
If those are not found to be the problem, then it could be the fill valve(s) or the timer control.
Reply back what you find, and I can help you further.
Jan 29, 2009 | GE Energy Star WCVH6260F Front Load Washer
Washer will not fill
not your timer / if anything its eather the water valve or the water slector switch
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
My top-loading Maytag starts to fill with water when I turn it on and then completely stops and doesn't do anything more.
it could have a problem with the pressure switch.
the water supposed to trigger the start of the wash cycle and turns off the filling cycle.
it is a single trow switch that disconnect the connection of water filling and connect the wash cycle on.
maybe it is disconnecting the filling cycle but would not connect the wash cycle.
tnx 4 using fixya,
drcool
Sep 07, 2008 | Maytag Washing Machines
WASHER DOES NOT STAR
Try bucketing out the water from the tub. then Set it back to start and see if water fills back up if so, check the lid switch.
Jul 11, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer model 110.49722990 it will not go into the drain or spin part of the cycle, just sits there and hums, won't do anything. It will fill with water and wash,but thats all it won't finish the...
Does it fill with "cold" water?Will it spin?Drain?If the machine will fill up with cold water,will the timer advance by itself to finish?Or if you place the timer in spin cycle will it spin?First off if your not getting "Cold" water to fill inside :Replace the water valve (because when the timer stops after the agitation cycle it wont advance because it cant fill up with cold water.
May 23, 2008 | Kenmore Washing Machines
Kenmore 22422 Top Load Washer Logo
147 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
