Question about Miele W4840 Front Load Washer
Miele touchtronic W4840 WASHING MACHINE WON'T START WHEN I PRESS THE START BUTTON
5 Suggested Answers
skyblue67
  • 71 Answers
SOURCE: Miele W4840 is LOCKED
hi try pressing in the heavy soil button to take off the child lock, good luck
Posted on Jul 19, 2009
  • 3 Answers
SOURCE: miele touchtronic 1113 washer
There is a float switch in a pan under the machine. This pan is probably full and the float switch is causing the Intake & Drain fault signal. You can lean the machine over to towards the front to partially drain the pan. Put a towel down to catch the water. When you put the machine level again the fault lights should be out. The real question is where did the water come from. You can easily remove the top (4 screws, 1 on each side behind the little plastic caps and 1 on each side of the back. Torx heads) and look down inside while you start the cycle. Look for leaks.
Good Luck,
Dan
Posted on Aug 11, 2009
  • 177 Answers
SOURCE: my miele touchtronic w 3039
Sounds like you may have flooded the base of the unit and activated the float switch. Tip the unit forward slightly with a towel at the base and all the water will pour out. You should be right to run the unit after that and any other water inside will dry up. it won't rust as it is stainless steel inside.
You may just have over sudded the unit by using the wrong detergent or too much. After you have the unit running again test the unit with no detergent and see if you activate the waterproof system again. if you do then you will probably have a split hose inside the unit.
Posted on Mar 02, 2010
  • 91 Answers
SOURCE: why dose the water leak out from the Miele
Hi dear.Please check the door gasket for any wear & tear.(Also open the door,ajar inside the door gasket, check inside of it for any fine tear or cut.)Please check for pump filter.Is it attached correctly.I hope that helps.Thanks.
Posted on Sep 02, 2010
How to cancel programme once it is activated on Miele W502
Turn the machine off.
Turn dial to finish.
Turn power back on.
Select drain and start.
When drained you can begin again.
Nov 17, 2012 | Miele W4840 Front Load Washer
My Miele W1119 washer won't run. It was fine earlier today and I just completed a load of wash. When I started the next load on the Normal cycle, the timer lights to 58 minutes as always and the...
sounds like bushes mine done the same changed them now all good check it is not leaking water on to the bottom of machine this will activate the sensor to stop washing and drain water
Jun 04, 2017 | Miele Touchtronic W1119 Large Capacity...
Miele w1113. Washer drum won't spin during wash cycle
I assume you are saying the machine is working except the drums not turning? - you need to see if the belt has come off because thats what i would check first if you hear the motor start/stop after it fills up with water.
May 30, 2011 | Miele Touchtronic W1113 Washing Machine
W4840 water proof system activated how to reset
1. Unplug the washer
2. Tilt the machine forward about 45 degrees
3. Water will start pouring out from the base pan. Have some towels handy to clean up.
4. Put the machine back in its position
5. Plug it
7. You should be ready to go
Causes
- You may be using too much detergent. Try lesser amount next time.
- There is a leak. If using less detergent does not solve it and this message keeps coming back, then the leak needs to be investigated.
Dec 10, 2010 | Miele W4840 Front Load Washer
Why dose the water leak out from the Miele Touchtronic W1113 Large Capacity Washing Machine w/ Stainless Steel Honeycomb Washing Drum?
Jun 19, 2010 | Miele Touchtronic W1113 Washing Machine
Jul 19, 2009 | Miele W4840 Front Load Washer
Miele w1113 alarm buzzer
do you have 3 dashes across the dispaly?? you need to get into service mode to access the fault
Aug 17, 2008 | Miele Touchtronic W1113 Washing Machine
Miele touchtronic 1113 washer
Good Luck,
Dan
Aug 09, 2008 | Miele Touchtronic W1113 Washing Machine
Drsining washer manually
open the little door at the bottom fron and twist open the lint filter clean out
Jul 12, 2008 | Miele Touchtronic W1113 Washing Machine
Miele W4840 Front Load Washer Logo
297 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
