Question about Pioneer Car Audio & Video
Installed a Pioneer DEH-P5000UB CD receiver in my vehicle. It worked fine for a week. Now only the CD player works. Cant adjust the sound no receiver working no light display on the unit.Twice since problem started when I re-attached face plate I got light display and all controls worked, only to not work again when I shut off vehicle and restarted.
  • 1 more comment
  • tsamiam62 May 14, 2009
    I tried your advice, eraser on the contacts, still no go. No lights and no adjustments possible.I even tried erasing the contacts on the deck. Chewed up the eraser pretty good. I blew off the eraser crumbs, should I leave the eraser crumbs on the contacts?, or do you have another suggestion?
  • tsamiam62 May 15, 2009
    Last night I tried the stereo and it did not work. This morning however it is now working and continues to work just fine. If it does it again I will try your other suggestions and see how that works. Your probably right about the cost of a repair shop. I can buy the same unit from amazon.com for 109 dollars. Thank you for your help. I am as satisfied as can be with your advice. Well worth the $10 I spent. Thank you again. tsamiam.
    My stereo started working this morning after the eraser trick. I will try your other suggestions if the problem continues. Thank you for your advice. Worth the $10. Satisfied customer, tsamiam62
  • 15,935 Answers
The faceplate connection is not making contact. Take an eraser and rub the contacts on the faceplate so it makes good contact.
Thanks for using FixYa!!
Posted on May 13, 2009
  • blueextc3221
    blueextc3221 May 14, 2009
    no the eraser debris should be brushed away after cleaning.
    if there are spring-type contacts on the radio - bend each one out slightly to make contact with the faceplate.
    If the connectors are working good - the problem most likely is in the ribbon cable behind the connectors inside the radio itself.
    It is a common problem with pioneer to have this piece broken if the faceplate is not installed properly and forced in place.
    i can only suggest tapping on the top of the radio to try and establish contact.
    professional repair will be required - however it may exceed the cost of a new radio.
    If it was a new purchase - it should be under warranty.
  • blueextc3221
    blueextc3221 May 15, 2009
    no problem.
Amp error message on Pioneer DEH-15UB. Vehicle was jump started twice would this cause this problem? The receiver is not connected to an external amp. The radio/cd player will work for about two minutes...
I just had an "amp error" message display on my Pioneer DEH-15UB and it quit playing. No sound at all. It happened while I was driving my Jeep. When I got home I removed the passenger side speaker from the sound bar and found the previous owner had used a wood screw to hold the wire to the speaker. That screw came into contact with the metal roll bar and caused the error. When I installed ends on the wires the error message cleared itself and now works fine
Sep 17, 2013 | Car Audio & Video
How to reset my DEH-P5000UB, because my display turned off, weird
Re:"everyother light turns on the faceplate but the display is off"
That means that the unit is either faulty, or one of the two powered lines required had not been connected.
The unit is reset by simply disconnecting the connector at the back.
This will not help in fixing the problem.
Ensure that unit is wired properly. Use a voltmeter to test wiring.
Here installation manual with proper wiring.
Here also the owner manual.
May 26, 2010 | Pioneer DEH-P5000UB Car CD/ MP3 Player
I cant set the clock on my pioneer p5000ub radio
Here is the link to your manual:
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/212724165DEHP4700MPOperationManual.pdf
Set the clock:
press function to select clock, press left or right to select the part of the clock display you want to set, press up down to set the clock.
Cheers!
Dec 28, 2009 | Pioneer DEH-P4700MP CD Player
I was playing some music from a kignston pendrive when the music stoped and appear a error 10! CD and USB stop working until unplug the battery.
This sounds like a corrupted file or bad device that caused a conflict. Try a different device, if the problem persist then you need to re-install the drivers for the usb and cd drive or at least update them.
Aug 26, 2009 | Pioneer DEH-P5000UB Car CD/ MP3 Player
P5000UB wiring diagram
red -Acc power
yellow -12 memory power
black -ground
blue -amplifier remote
blue/white -power antenna
SPEAKERS
white left front +
white/black left front -
grey right front +
grey/black right front -
green left rear +
green/black left rear
purple right rear +
purple/black right rear -
Aug 25, 2009 | Pioneer DEH-P5000UB Car CD/ MP3 Player
Pioneer DEH-P8600MP WORKS PROPERLY BUT I CANT GET NO SOUND
My friend maybe you burn out the audio amplifier output
Aug 25, 2008 | Pioneer DEH-P8600MP CD Player
Car Audio & Video Logo
107 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
