Question about Aiwa NSX-A777 Shelf System
Volume Control not working properly
I have an Aiwa cx-na777 which works great except for the volume control knob. No matter what you do, it turns the volume up. At times, if you go real slow to the left, it will decrease in volume, but for the most part the volume only increases with any turn of the dial. Is there anything I can do to fix this problem? Thank you!
4 Suggested Answers
techman
  • 3130 Answers
SOURCE: volume knob
In other words the lever that the front knob is attached to is broken or the microswitch is bad or broken.. if your not a tech please take the unit in to a shop as there are no user serviceable parts inside these units. Good Luck
Posted on Aug 03, 2006
  • 4234 Answers
SOURCE: I need a part # for the volume controle on an Aiwa
The "volume control" on your Aiwa is in fact what is called an "encoder". These can fail. They work in concert with the microprocessor to control the electronic volume control IC. Yes this part can be replaced. Try calling Sony with your model number and request the part number for the volume encoder. They should be able to help.
Dan
Posted on Aug 24, 2009
SOURCE: Which Aiwa remote control unit to buy.
Went to manufacturer's website.
Posted on Dec 12, 2009
Aiwa repair
I have 2 AIWA CX-NA303 in need of repair. Volume control works only with remote. Cassettes no longer play and doors get stuck shut. Each now has one door each that won't close. Where can I get these repaired?
Jan 02, 2014 | Televison & Video
Volume dosent turn up and down correctly..u turn the knob and it dosent go louder or softer
I ALSO HAVE THE CX-NA777 SYSTEM, THIS WILL SAVE YOU SOME TIME AND MONEY, FIRST, YOU WILL NEEDS THE SERVICE HAMUAL FOR THIS UNIT, YOUR CONTACT IS www.kap1007@yahoo.co.in TELL HIM BRGARY3 SENT YOU, YOU WILL NEED A PAY PAL ACCOUNT TO PAY THE $9.00, THE MANUAL WILL BE SENT TO YOUR EMAIL, YOU WILL NEED A PAY PAL ACCONUT TO PAY, WWW.PAYPAL.COM TO START THE ACCOUNT, ONCE YOU GET THE MANUAL, GET AN ELECTRONIC TECH TO READ THE PART NUMBER FOR YOU, OR YOU MAYBE ABLE TO FIND IT YOURSELF, UNDER VOLUME KNOB, THEN CONTACT ANDREWSELECTRONICS AT WWW.ANDREWSELECTRONICS.COM, CALL CUSTOMER SERVICE AND PLACE THE ORDER FOR THE VOLUME KNOB WITH THE NUMBER THE TECH GIVES YOU, ONCE IT ARRIVES, YOU JUST HAVE THE TECH PUT IT IN FOR YOU, THIS MAY SAVE YOU AS MUCH AS $200.00.
Nov 09, 2013 | Aiwa NSX-A777 Shelf System
I have a CDC-X504MP. How do I get the fade control. I was in the truck when I bought it. Works great.
To get to the sound settings: Press and hold the Volume knob down. Press the "Seek" button until you see "Fad" on the display It will be between "Bal" and "LPF" Turn the volume knob to adjust
Jul 23, 2011 | Aiwa CDC-X504MP CD Player
I have an Aiwa cx-nma545 that I just hooked up to a Westinghouse SK-32h640g. The sound is very muffled. The sound is fine if I have it on cd or the radio but when on Aux Video I can barely here it.
On most TV's with speaker control there's a way to disable the TV's volume control effect on the level fed out to an external amplifier. Find it and disable it it or select FIXED for its level, or, while listening through the Aiwa, raise the TV's volume through its own remote and see if that affects what the Aiwa gets for volume.
Or, enable the TV's speakers but find the same interna lAudio setting and make it Fixed, but turn the TV volume down if you don't want to hear its speakers. That way, you could actually listen to the TV on its own speakers if you want, say, for casual watching of the Weather Channel or news, for example.
Nov 28, 2009 | Aiwa NSX-DS55 CD Shelf System
Dan
Aug 24, 2009 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
Remote Code Aiwa CX-NA505u
Does not play cds properly skips like crazy volume knob sometimes goes louder when i turn it down dosent read all cds eather whats the problem?
Mar 24, 2009 | Aiwa VX-S205 Combo
Aiwa Shelf system volume control doesn't work right
The part in question is called an encoder. I have had to replace this part on a number of Aiwa units. If you can post the model number off of the back, I''ll get you the part number.
Dan
Oct 01, 2008 | Audio Players & Recorders
Volume
the volume control needs to be cleaned. this control is a step switch basicly. and the switch contacts are not making proper contact. cleaning this requires dis-assembly and desoldering so if you are inclined to do this work happy fixing if not it shouldn't cost much to fix.
Jan 19, 2008 | Aiwa NSX-A115 Shelf System
Aiwa CDC Z117 volume dilemma
you probably try this move the nob in or out maybe it beetwenn 2 set in knob broken remove it turn the knob manualy good luck cheers
Jan 07, 2008 | Aiwa CDC-Z117 CD Player
Volume knob
Normal Aiwa compact shelf units use what is called a jog switch for the volume. Usually you can tell the difference if when you you turn the volume up or down. It goes a short distance and seems to spring back. In this case there are two momentary contact switches. One for up one for down. With a plastic lever on the back of the knob that bumps the approriate switch whether turning down or up. If the lever is broken it will bump up against one but not the other. If it is broken plastic you know how good gluing plastic goes it never seems to hold.
Aug 02, 2006 | Aiwa NSX-A777 Shelf System
Aiwa NSX-A777 Shelf System Logo
209 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
