Question about Vivendi Jumpstart Spanish (72019) for PC, Mac
Can't run Brain Play Jumpstart Spanish from Scholastic
My computer is xp and has tons of room. Every time I try to run this software it tells me that I need 3MB of virtual memory.
  • 508 Answers
How to increase Virtual Memory?
In Windows XP
1.Click Start, and then click Control Panel.
2.Click Performance and Maintenance, and then click System.
3.On the Advanced tab, under Performance, click Settings.
4.On the Advanced tab, under Virtual memory, click Change.
5.Under Drive [Volume Label], click the drive that contains the paging file that you want to change.
6.Under Paging file size for selected drive, click to Custom size check box. You can enter the amount of memory you would like to reserve for Virtual memory by entering the initial and maximum size.
7.Click Set
When you are prompted to restart the computer, click Yes.
Special Note: You should choose the same amount for the initial size and maximum size. This will Stop your CPU from constantly changing the paging file.
HOT TIP: To stop your CPU from constantly changing the paging file, set the initial and maximum size to the same value. For example, 500 and 500. The value should be at least 1.5 times more than your physical RAM. If your computer has 512MB of RAM increase the virtual memory paging file to 1.5*512= 768
In Vista
1. Click Start button Picture of the Start button
2. Click Control Panel
3. Choose System and Maintenance and then click System.
4. In the left pane, click Advanced system settings.
5.On the Advanced tab, under Performance, click Settings.
6. Click the Advanced tab, and then, under Virtual memory, choose Change.
7. Click Custom to change the Initial size (MB) and Maximum size. See the hot tip above.
Can't run Brain Play Jumpstart Spanish from Schola - virtualmemoryadvancedtab.png
virtualmemorychangeCan't run Brain Play Jumpstart Spanish from Schola - virtualmemoryset.png><br /><br />
<img src=
Remember to choose the drive you would like to use to increase the virtual memory. In most cases it usually your C: Drive. You can set the initial size and maximum size after clicking the Custom size check box.Remember its better to keep the Virtual memory values the same.
Also having enough available space is absolutely necessary for your virtual memory and RAM to function properly.
Posted on May 13, 2009
  • 221 Answers
Right click on My Computer, go to Properties, then go to the Advanced tab, then click on the Settings button under Performance, then click on the Advanced tab, then under the Virtual Memory section, click Change. In the new window, change the Paging file selection from "System Managed" to Custom Size. Change the Initial size to 4092, and set the Maximum size to 4092 as well. Click Set. Click Ok and close all windows. It'll tell you to reboot. After your reboot, your virtual memory size will now be 4GB. If you have plenty of hard drive space, this won't have any negative affect on your system. You should be able to run your game now.
    Champion:
  • 381 Answers
Hi...you have a problem the memory so u need to try clean or replace the memory...Thanks....^_^
    President:
  • 688 Answers
You can use the following steps to manually change your virtual memory.But you will need to probably upgrade your RAM
Memory in your computer. You may not have enough to run the program.
How to manually change the size of the virtual memory paging file loadTOCNode(4, 'moreinformation'); You must be logged on as an administrator or as a member of the administrator’s group to complete this procedure. If your computer is connected to a network, network policy settings may prevent you from completing this procedure.
To manually change the size of virtual memory, follow these steps:
  1. Click Start, click Run, type sysdm.cpl in the Open box, and then press ENTER.
  2. Click the Advanced tab, and then under Performance click Settings.
  3. Click the Advanced tab, and then under Virtual memory click Change.
  4. Under Drive [Volume Label], click the drive that contains the paging file that you want to change.
  5. Under Paging file size for selected drive, click Custom size, type a new paging file size in megabytes (MB) in the Initial size (MB) or Maximum size (MB) box, and then click Set.
  6. Click OK to close the dialog box and apply changes.
Well, for me virtual memory wasn't really the issue, although that was the error that was showing, I had to go through the install process 3 times, and especially work on Quick Time install to get it to work. That was after I spent entirely too much time messing with the virtual memory settings. Bad error messages can be worse than none at all.
Posted on Oct 13, 2009
Brain lara cricket supoorts windows 8
Brain lara international cricket 2007 doesnot support windows 8 and windows 8.1 platform so it gives some errors like 0x00000xxx. Downgrade the operating system to windows 7,xp or windows server 2008 then it works fine. It is not the pirated cds problem its platform problem. You cant even run in compatible mode in windows 8,8.1.
Dec 24, 2012 | Codemasters Brian Lara International...
Installing the jumpstart advanced 1stgrade cd rom that has 4 cds to it and I can't get it to install.
Jumpstart advanced 1stgrade cd rom installation.
System Requirements
Windows: 98/ME/2000/XP; Pentium II 266MHz (Pentium II 300MHz or faster for XP); 64 MB RAM (128 MB RAM for XP); 100 MB HD; 12x CD-ROM drive; 16-Bit color; Windows compatible sound card
If you are installing on a newer OS ie Vista, or Win 7, due to software incompatibility the software might not install, or even you can install the software might no work.
You can try using the "compatibility mode" in Vista or Win 7 to install the programs as "administrator" but no guarante this will work.
Alternatively, you can get a newer version which is compatible to your Operating System.
Hope it helps.
Jul 25, 2010 | Jump Start JUMPSTART ADVANCED 1ST GRADE...
A friends daughter was given per asus pc from boyfriend (ex now) he bought it in his name. xmas 2009 for her.. some minor problems but she doesnt have receipt to ring up and get it looked at (not talking...
Try media player classic a software that can play dvds and cds
why the DVD wont play might be for different reasons... 2 broad category software / hardware 0.I ll assume its a drive that can play cds and dvds 1.software- u must have a problem with the drivers. Drivers tell computer's brain how to connect to each of its organs(parts like monitor keyboard DVD drive etc) if this is missing its like ur brain doesnt know how to move ur right hand...u ll need to reinstall the drivers then... u ll get the drivers from the website for the laptop Hardware 2. next try using a lens cleaner for ur drive it usually is an air can and a disc... try that ... 3. If still the problem hasnt been solved... the trouble maybe with the drive physically which means u d have to replace the DVDdrive...
Jun 15, 2010 | Computers & Internet
I installed the CD for Jumpstart Spanish 1st-3rd grade- 2nd edition but at the end of installation, I got an error message about needing at least 3mb of memory and then it ends installation and the program...
To fix, try this
Right-click on My Computer icon, and select Properties.
Click on the Advanced tab,
then select the Settings button within the Performance section.
In the Performance Options window, click on the Advanced tab, and then select the Change button in the Virtual Memory section.
Click the Custom size button...
Change the Initial size (MB) setting to 4000
Change the Maximum size (MB) setting to 4000
Select SET to accept the change, which will close the Virtual Memory window. Select OK to close the Performance Options window. And select OK to exit the System Properties window.
please rate my solution
have a nice day.
Jul 07, 2009 | Jump Start JumpStart Spanish...
My computer freezes
it may be because your system is satisfying only the basic requirements to support the game
see the system requiements for the game to run from the readme file or upgrade your system to a latest configuration
i said it because these problems occour commonly to old pc's
May 19, 2009 | Jump Start JUMPSTART ADVANCED 1ST GRADE...
Get black screen and loading icon
Dear sir,
I faced this problem and I solved it by :
1. uninstall adobe flash ActiveX
2. Install adobe flash plugin try to download it by use chrome ( I used chrome ..google browser)
3. uninstall tell me more
4. Install tell me more
5. Run tell me more
That's it
Aladdeen.
alaalddeen_n@yahoo.com
Dec 30, 2008 | Auralog TeLL me More Spanish Premium...
Changing an english computer over to spanish
to change your operateing system language you need to get the windows in that language. There are many difrent versions of windows in difrent languages.
If I want my xp to be in finnish I have to get my hands on a CD which is in finnish. IF I want english I need a english version of the cd.
You will need a spanish xp setup cd.
also it may be possible to convert xp into another language. with some
Windows XP Multilingual User Interface (MUI)
I hear it costs money and I haven't used or tryed it.
Jun 27, 2008 | HP Pavilion dv6000z Notebook
PROBLEM INSTALLING SOFTWARE
hi jimmy, you are using xp with spanish language , it is the problem because please check the software you are trying to install is supported by the spanish language or change the language setting to any other language and try it
Apr 23, 2008 | Computers & Internet
Vivendi Jumpstart Spanish (72019) for PC, Mac Logo
796 people viewed this question
Top Vivendi Computers & Internet Experts
David Payne
David Payne
Are you a Vivendi Computer and Internet Expert? Answer questions, earn points and help others
