Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Dont know where to hook springs to brake on mower deck...arm assembly pad brake
  • verlam810 May 13, 2009
    model # for craftsman lawn tractor, that needs help for putting on springs is----917275390
  • John C Bridgers Sr May 11, 2010
    Hello verlam810:
    Most of these Attach to a Slotted Hole in the Deck. Some have a Special Bracket the is Bolted to the Deck for the Spring to Attach to.
    >>Send me the Model Numbers Off the Mower, Please. With these I can Locate the Proper Manual and Better Assist you. The Model Numbers are Usually Located Under the Seat on a Sticker or Tag on the Body.
    Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
    Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
    Good Luck
    Respectfully
    jbridger (John)
  • 246 Answers
Hello Again verlam810:
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left. Select the "Mower Deck" Sub File.
>>There are 2 Brackets (#142) that the Springs #147 (Brake Springs) Attach to.
>>We can Use the Breakdown for a Reference if you have More Questions.
>>Till Next Time. May All Your Mechanical Problems be SMALL ONES and as Always, May the All Mighty Bless You and Yours. Be Safe and Happy.
Best Wishes and Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
Blades won't engage on my zero turn 50" cut husqvarna (approx2011) I found a 7" spring on the ground and don't know where it goes back on. Can u help
Looking underneath the mower on top of the deck there should be a flat metal arm with a flat faced pulley on the end. This pulley pushes against the belt that drives the mower deck . The spring should be hooked on that arm and pulled tight over to a place on the deck and this is what keeps the belt tight enough to turn the blades when you engage the pto switch. My recommendations to put this back on is to remove the belt pulley cover on the deck right side roll the belt off at that pulley giving you a bunch of slack so you can hook up the spring and put the belt in the right position on everything else then go back to the deck right hand pulley start putting the belt back on that pulley and when it is to tight to get it all the way on reach under the deck and use the blade as leverage to finish turning the pulley and walk that belt on the rest of the way ,it will not hurt a thing, all you are doing is pulling that 7 inch spring over like it was intended to be, then replace the cover on the deck spindle.
May 17, 2016 | Husqvarna Garden
I have a Toro model number 20622 auto start go forward and backward the blade won't turn it's like it's got a break on it how do I get this to work when I pulled the lever nothing happens
Anon, a lot of these Toro decks do have a type of brake on one of the idler arm and pulley to stop blade. You will have to get a repair/service manual if your owners manual does not show it. Normally can be seen in deck belt installation diagram. If blade brake checks out OK, it is possible one or both blade spindles bearings are seizing.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Riding Lawn Mower Spindle Assembly Replacement Craftsman Lawn Mower Repair...
How to Replace Brake Pads on Mower Cutting Deck
Mower Deck Return Spring Replacement Craftsman Riding Lawn Mower Repair...
Apr 18, 2016 | Toro Garden
Replacing a mower brake tension spring
Mower Brake Return Spring Replacement - Craftsman ...
? 2:15
www.youtube.com/watch?v=kyuE5NBR5xU
Jul 31, 2014 - Uploaded by RepairClinic.com
This video provides step-by-step instructions for replacing abrake return spring on Craftsman riding lawn ...
Oct 27, 2015 | Craftsman Garden
I have a MTD yardman 1999,2000 ride mower that won't start because it says the pto is engaged when it's not actually engaged if you could comment an image of the same 42 inch deck?
Check your PTO switch operation which is at the engagement handle.
As for hooking the cable spring to deck idler pulley and brake assembly it goes in the hole closest to the idler pulley on the G deck which different then the F deck which uses the same idler arm assembly as the part is design to fit both decks.
Also make sure your using an OEM spec as a will fit will not work properly. You also must the spindle pulleys belt retainer covers in place so the belt will stay on.
May 10, 2015 | Mtd Garden
I have a poulan pro PR1842STC; the blades won't stop turning after I disengage the mower belt
On the top of the mower deck, there is a spring that will pull to disengage the blade idler pulley. At the same time, it will release two springloaded arms with brakes that press on the pulleys at the top of the blade spindles. On top of the mower deck at the back, the two spring loaded arms may be held out of the braking position by a cam. Make sure the cam is free to allow the blade brakes to activate when you disengage the blades. If arms are out of alignment, or the parts are too worn, the blade brakes won't move and the blades keep spinning, even after you have disengaged and the safety switch is deactivated. This is a dangerous situation and should be fixed soon. Good luck.
May 09, 2013 | Poulan Garden
Replacement of v belt
Instructions1 Place the riding mower on a level surface and set the emergency brake. Open the engine or tilt the seat back to gain access to the battery. Disconnect the negative battery cable with a socket. Turn off the main fuel petcock valve from the tank to the carburetor. Set the attachment clutch in the "Disengage" position. Set the motion control lever to neutral. Place the mower deck lift lever in its lowest position to drop the deck.
2 Pull the belt against the engine drive pulley, then pull upward on it and slip it off the pulley. Unclasp the small clutch retainer spring from the pulley bolt. Detach the big retaining spring and then slide the collar sleeve off. Shove the housing guide out from the br
3 Pull the retainer springs off that hold the rear suspension arms to the rear mower deck bracket. Disconnect the front link arms that hold the front of the mower deck to the chassis. Pull the lift lever to put the suspension arms at full height.
4 Slide the mower deck out from the bottom of the tractor. Tilt the mower deck and prop it up with wood blocks. Use a stiff cleaning brush to remove all mud, twigs and grass clumps. Wipe the top of the deck and undercarriage with a rag.
5 Un-thread the belt from around the idler and mandrel pulley. Place the new belt around the mandrel pulley and idler pulley first, then stretch it up to the drive pulley and loop it into the pulley grooves. Make sure the V part of the belt rests inside the pulley.
6 Use the lever to raise the suspension arms on the deck. Push the deck back under the tractor. Lower the suspension arms and replace all the retaining springs in reverse or the order in which you removed them. Slide the sleeve back into position and secure it with the spring. Reattach the spring to the anti-sway bar. Shove the housing guide back into its bracket.
7 Raise the mower deck with the lever. Reconnect the negative battery cable with a socket. Turn on the fuel petcock valve. Start the engine and engage the main drive lever. Test-drive.
THanks
Apr 02, 2012 | Vacuums
Refer to brake pad arm assembly :I don't understand what keeps the brake pads from always riding on the idler pulleys. the springs keep them against the pulleys.
Hi, the spring on the brake rod pulls the lever forward when the brake is applied and a short lighter gauge spring pulls the lever back. This spring may be missing. Regards Phil.
Aug 22, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have a Craftsman mower, model 917.273810, and when you engage the blades, the brake pads that are used to stop the blades from turning when you disengage the blades...won't release and it trys to...
Sounds like you have a broken spring #148 on diagram, part #169022 that holds the idler arm back. Go to www.searspartsdirect.com and enter the model # of your mower and click on the mower deck to print drawing out, take your deck off the mower and see if all the springs are ok. If the pads are closed on the pulleys and the pads release when you turn the idler arm, the deck is ok. The problem will be a bad or disconnected safety switch that cuts the motor off if you try to ingage the mower. If the switch is disconnected under the seat it will kill the engine when the mower is engaged. I had this problem on my mower, just plug the wiring into this switch or replace it if it is bad.
Aug 16, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
There is a big, wrap-around lifting bar in the front of my Husky used to raise the engine assembly off the mowing deck but I can't figure out how to free the engine assembly so I can pivot it up to expose...
most rideons have the deck assembly able to be removed without too much work.usually release any spring tension,then spring clips holding the arms on,then usually you can disconnect the belts and slide the whole deck out sideways,from under the rider.
Jun 29, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
How do we service the blade / brake clutch assembly on John Deere 14SB lawn mower .
No serviceable parts,you can only buy complete clutch.To replace you remove blade and blade adapter.Use a very large vise-grip to remove spring and then you can remove bolt holding clutch arm.Disconnect cable from top side of machine.Remove engine mounting bolts,have another person pull engine away from frame while you slide clutch off.Going back together you may have a tuff time getting large spring back on hook under deck.I've been working on these for some time and have yet found an easy way to get large spring back on.
Nov 14, 2009 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
682 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
