Question about Belkin (F5D7050) 802.11a/g/b Wireless Adapter
Internet connection worked fine now adapter saying connection unplugged
I don't know what happened I was conncecting to internet at local cafe, etc. now whenever I try to connect to internet belkin adapter looks like it is connected but it is not I cannot connect through AP list -hit connect and nothing happens.  What can I try?
  • 661 Answers
Check your firewall settings, it may be blocking the connection.
Posted on Oct 15, 2007
Magic Jack Plus worked in USB and then Internet on computer stopped working
It's got the wrong gateway setting. Without a gateway (router) to the Internet it can only see local network stuff. I suspect the Magic Jack is still trying to be the gateway but it has no Internet. Stop Magic Jack doing this and it should work.
Feb 27, 2015 | Computers & Internet
One of my computers wont connect to internet keeps saying limited acsess other computers are working fine
It means there is issue of tcp ip address. Limited connectivity means network adapter tcp ip not correct or not getting ip from DHCP server. For that set static ip in network adapter tcp ip property ac your local network range. Let me know if you need further assistance. Thanks for using FixYa.
May 25, 2011 | Computers & Internet
I have 2 e-machine computers. One is operating on Windows 7 and the other is Windows XP. Trying to connect a wireless Netgear adapter G-54 . The windows xp says I am conncected however I can not...
please check your internet connection through command prompt by typing ping www.google.com -t if the website didn't reply, restart your modem or connect your service provider.
Feb 02, 2011 | NetGear : WG111 54 Mbps Wireless USB 2.0...
A cable is not plugged into the network Adapter "Local Area onnection" where is the local area connection suppose to go?
This just means, that you don;t have a phone line, or a RJ45 line
plugged into the computer.
If you have a cable modem, then a line (rj45) runs from the modem
to the Ethernet port in the back of the computer.
You need to plug something in or us wireless to get on to the internet.
So it depends on what service you have depends on what you plug it.
If you need anymore help just post back, let us know what service you use.
Cable,phone, satellite.
Feb 14, 2010 | E-Machines eMachines Monitor E15T4
Can't connect to internet on desktop computer
Most likey the issue is with the network adapter. As it does not work even with the modem and router the card seems to be faulty.
Hope this helps.
Sep 05, 2009 | Computers & Internet
I cannot conncect to the internet and it says that my Intel/pro w
When you get home, do the following:
  1. Connect your computer to the modem with an Ethernet cable.
  2. Go to start -> Control panel -> Network Connections
  3. Find a connection called "Local Area Connection"
  4. Right-click and choose "Properties"
  5. Scroll down until you see "Internet Protocol TCP/IP"
  6. Double click it.
  7. Make sure that both buttons for "Obtain...automatically" are checked.
  8. Click "OK" until all windows are closed.
  9. Open a command prompt (Win-key+R) and type "cmd"
  10. In the following window type "ipconfig /release"
  11. When that is finished type "ipconfig /renew"
  12. When that is finished, type "ipconfig /all > C:\fixya.txt". This will create a text file on your C: drive.
  13. Copy the contents of the file and post it here as a comment, if you still can not access a webpage.
I will bookmark this page and come back here later or tomorrow to see what you posted.
For your info, my output looks like this:
Windows IP Configuration
Host Name . . . . . . . . . . . . : [computername]
Primary Dns Suffix . . . . . . . : blabla
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . :
Ethernet adapter Wireless Network Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Intel(R) PRO/Wireless 3945ABG Network Connection
Physical Address. . . . . . . . . : XX-XX-XX-XX-XX
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.1.100
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 192.168.1.1
Lease Obtained. . . . . . . . . . : Friday, August 07, 2009 09:35:22
Lease Expires . . . . . . . . . . : Saturday, August 08, 2009 09:35:22
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : Broadcom NetXtreme Gigabit Ethernet
Physical Address. . . . . . . . . :XX-XX-XX-XX
IP Address. . . . . . . . . . . . : 192.168.1.60
Lease Obtained. . . . . . . . . . : Friday, August 07, 2009 09:35:16
Lease Expires . . . . . . . . . . : Saturday, August 08, 2009 09:35:16
See you later!
Aug 07, 2009 | Dell OptiPlex GX270 PC Desktop
USB wireless internet adapter disconnecting
Sounds like the usb ports are sharing an I/O channel. So when you unplug one usb device the CPU is being told that the USB port is not being used.....Maybe..... To test this, hardwire into a data cable and plug in different devices, next unplug a devise and see what happens. If you stay connected you may have found your answer. Unfortunately I don’t think a reimage or restore will fix the problem. If you get the same result try a reimage of your OS. Good luck.
Again sound like a mother board issue.
Questions to ask, When did I notice the problem (Maybe able to restore to the point the problem started.) and did I install new software or hardware when this happened?
Good Luck
Apr 05, 2009 | NetGear WPN111 RangeMax Wireless USB 2.0...
Moving internet to another room
As long as you have an active DSL connection in the new room, yes you should be fine. All settings are saved in the router's flash memory and won't be lost by disconnecting the power. Make careful note of where everything is plugged in (a digital photo is great!) and in the worst case, you can move it all back until you figure out what is wrong.
Jan 01, 2009 | Netopia 2247NWG-VGx Wireless Router...
Wireless Connection
Move your computer to different postions and see if the frequency of the problem changes. Take your computer to a wireless internet cafe and see what happens as you move around the cafe. If your computer works at the cafe, your wireless router may be defective.
Nov 20, 2008 | IBM (31P8301-IBU) 802.11b Wireless Adapter
Belkin (F5D7050) 802.11a/g/b Wireless Adapter Logo
67 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
