Question about Acer Professional P211 21" CRT Monitor
The screen is pink tinted
The screeen is pink
  • 221 Answers
A pink (or any tinted) screen is usually an indicator of one of two things:
1. The cable going from the video card to the monitor is loose. Try adjusting the cable and see if the picture changes. Put pressure in all directions slowly to see if it clears up. If it does, you should change your monitor cable.
2. One or more of your CRT "guns" or "rays" is malfunctioning, causing the red gun to be too strong, or causing the green or blue to be too weak. This is difficult to fix... time for a new monitor. Sometimes you can get a little more life out if by smacking the monitor on the side.
Posted on May 13, 2009
I turned on my TV and the whole screen has a pink tint
If using a box for signal disconnect it from power for a while to see if when it reboots this issue is gone or not.
Nov 28, 2012 | Samsung HLP4663W 46" Rear Projection HDTV
Pink hue to all photographs taken on screen and print
You may just have the white level set wrong or the camera in the wrong mode than what you are epecting.
You should be able to reset or set that from the setup menu.
Mar 23, 2010 | Sony Cybershot DSC-T200 Digital Camera
My hitachi 43fdx20b has a pink tint to it. I have noticed that if i move the tint slider one way or the other it will turn the screen green, but now it doesn't. Does this have something to do with my...
My 43fdx20b had a pink tint to it also. The picture was clear otherwise. I found, on mine, I needed to adjust the Red Screen control. It was located behind the front panel. I removed the two screws on either side of the front panel and was able to remove the panel. Then I adjusted the Red Screen control. I found that if I tuned in an old Black and white movie I could adjust the color fairly accurately. Good Luck.
Jan 02, 2010 | Hitachi 43FDX20B 43" Rear Projection...
Laptop LCD goes black after a few seconds
Yes, The pink tint is an indication that the backlight is failing. Now the backlight is basically dead, the best way to get back going is to do an Ebay search for your model laptop and get a new screen. Most screens can be purchased for around $50.00 - $70.00 and they are very easy to swap. Email me if you need more info.
Buddy
Corporate Computer
www.ccl-la.com
Aug 03, 2009 | Samsung SyncMaster 940N Flat panel Monitor
Pink tint
your va and vs on power supply need to be adjusted but you have to know what your doing to set it right and requirs a volt meter
Jan 16, 2009 | Samsung SPN4235 42 in. Plasma HDTV
Compaq laptop pink screen sometimes
The normal cause of a pink tinted screen is that the LCD back light is beginning to fail. Kind of like a regular florescent bulb does when it starts to go bad. It may last for a while, but eventually you'll have to replace it.
Ron
Dec 13, 2008 | Computers & Internet
Pink tint on Dell 1704FPT Flatpanel LCD
Unfortunately if you have tried a different machine (it could be a bad video card) and tried the cables most likely it is the screen itself. Typically when one of these lcd's begin to fail the pixles no longer access the blue field and you see mostly red instead of the other two colors. In short pink screen is terminal, it will last for a while longer.
Oct 01, 2008 | Computers & Internet
LP70+ projects a dark rose/pink tint upon the screen
The pink tint produced by my LP70+ projector was not a lamp issue but a connectivity issue. I swapped the old cable with a good known cable and the tint went away.
Aug 14, 2008 | InFocus LP70+ Multimedia Projector
Pink tint when shhoting in bright sunlight
Sane problem with C713, the view screen is dark and gives focus warning, then the pics come out with a pink tint. I believe it is the sensor or shutter problem. Can't get any solutions either.
Nov 12, 2007 | Kodak EasyShare CX7530 Digital Camera
Acer Professional P211 21" CRT Monitor Logo
354 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
