Pc problem my personal computer has been given me problem, it is not displaying bu the systems are working the vga card was inbuilt with motherboard but i have change the vga card still still not displaying
  • 50 Answers
Plz follow the steps:
>> plz check the power cable which is the black thick one
>>replace it with the one on the CPU and check if some coloured lines appear on the screen ..thats Self -TEST
>>if it shows the self test then ur monitor is good and its the issue with the data cable thats connecting the monitor to the tower
>>try to boot it in the safe mode to check if its an issue with the VGA card or not
Posted on May 13, 2009
  • 61 Answers
Hi there, can you please use another monitor? See as well if the monitor being used is working fine on another setup.
EP-8KDA7I DISPLAY DRIVER
This motherboard doesn't have an inbuilt video controller, it will just use a generic VGA driver that comes part of Windows.
Perhaps you're looking for a video card driver that's plugged into one of the PCI or AGP slots?
Dec 21, 2012 | Computers & Internet
I opened my box and removed the motherboard i.o.t clean it but when i assembled the pc again the fans goes on but i dont get any display on the screen.... What can be wrong
Is the video card inbuilt in the motherboard or its external? If external properly you have not placed the vga card properly on the pci slot. Open and check the vga card is properly placed.
Apr 19, 2012 | Intel Computers & Internet
Sir! i have winfast NF4K8AC motherboard with Vga display card 128 MB DDR (ROHS Compliant Lead - Free). It was working 6 month smoothly but now I am having problem with display .I have checked the same Vga...
the drivers might not be installed correctly you might have to uninstall the graphics card restart your computer then reinstall the graphics card and its drivers
If your computer came with a motherboard disc the drivers could be on it
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
hope this helps
Aug 16, 2011 | Foxconn NF4K8AC-RS-1.0 Motherboard
Frequency out of range (upgraded to win 7 )
You have to install AGP card into the motherboard nowadays motherboards is with inbuilt display card is without video memory which does not support to high resolution if yu dont want to do that then restart and press F8 and keep pressing untill menu appear then select "enable vga mode" and press enter your problem will be solved
Mar 14, 2010 | Gateway FPD1975W 19" LCD Monitor
AOC 212Va-1 problems with DVI
no you just install an AGP card into the AGP slot of the motherboard then you can see any high resolution because your motherboard is with inbuilt display card will not support to high resolution external card is necessary for that
Mar 12, 2010 | AOC 212VA-1 Monitor
I have the same problem
Dear! If monitor showes power but not showes display its means that monitor requires heat and it very better if you can give sun-rays. I assure your monitor will work if you do that for 4 hours. Check your monitor sepreatly with another system or computer if it works that means your VGA card not supported so you should change your VGA card but first check your monitor.
Thank You
Jul 30, 2009 | ASUS P5RD1-VM Motherboard
I have not vga driver on my pc after installing win xp and dont know which vga card is on my computer I MOVE MY VGA DRIVER FILE FROM ONE PLACE TO ANOTHER
you can download the VGA driver for your motherboard D945GAG from the website given below:
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=1672
choose the operating system and download the VGA driver
Regards
-Dileep
Feb 28, 2009 | Intel D915GAG Socket 775 Motherboard -...
SYSTEM BOOT IS SOOO SLOW
the pc had two VGA one is opnboard and the other is a vga card,so i opened it aond took the vga card out and it worked with the original onboard;i then fixed the vga card back and it also worked.
the problem was that a shoddy work was done.the vga was not fixed tightly and that was the problem.
Aug 26, 2008 | Aspire Computers & Internet
Monitor powers down upin startup
you need a new video card. it is powering down becuase it is not reciving any signal from you computer. if you are useing onboard video (vga) get a pci video card if you are useing a pci card try puting it in a dfrent slot.
Dec 20, 2007 | Gateway 310S (2900621) PC Desktop
How to disable onboard VGA
I believe if you install an AGP card the onboard VGA is supposed to be automatically disabled. Did you buy an AGP card?
Nov 28, 2007 | Foxconn P4M800P7MA-RS2 Motherboard
Open Questions:
Cervical Cushion- Pillows for Neck Pain Are you a very sedentary person? Do you have a classic office job and are 8 hours or more sitting in front of a computer? Then you most likely suffer from cervical pain. Cervical pain means having severe pain in the neck area because of an incorrect position of our cervix for quite some time. The cervical block or its numbness is due to the unnatural compression of the vertebrae. In this guide you will find all information about cervical pain, how to prevent them and how to cure them, but above all you will learn how to choose your cervical cushion that will help you lessen the pain or make it disappear completely. In the following table you will find some models of cervical pillows that can be found on the market, along with some of the major features that distinguish them. How to Choose a Cervical Cushion Since on the market you can find a great multitude of cervical pillow models, choose the most suitable one and certainly not a small business. First of all, choosing the most appropriate one is to understand what pathology you are suffering from. Although we often call it neck pain, cervical is not always the same in all cases. In this regard, it is understood that not everyone can use the same cushion. There are cases where the patient needs a more flexible pillow, others where there is a need for stiffer material, so before buying your new cervical cushion it would be interesting to consult your trusted physician, who can visit you and decide for you what is best suited to your pathology. Another factor could concern the price, but being in the medical field I recommend closing an eye on this item, ten euros more or less are nothing when it comes to health. Moreover, the price is directly proportional to the quality of the material used and of course there are materials that cost more than others. So as you see there are several factors to consider. Take care of all the advice you'll find on these pages and you too will be able to make the right choice. What is cervical pain and remedies? The area of ??the cervical vertebrae is that portion of our body that accuses so-called cervical pain when our neck or our head is in an incorrect position for several hours. This area is very important for our health and our well-being. In practice it connects our body and especially the spine to the head, with all the nerve endings that pass right in this particular area and very sensitive. When this area is subjected to a continuous stress, we do not only pain neck pain, but we also compromise the proper functioning of the head movement. Very often the pain becomes so strong that besides affecting the neck, it moves to the upper shoulders and joints, causing the famous head turns and also nausea. In the most severe cases a capatina is recommended by your doctor. Among the various factors that can trigger these severe pains are incorrect posture or an improper pillow. At the origin of this evil, however, there are also muscle contractions, trauma and stress. For this reason, the cervical pillow was born, which relieves the pain and allows the neck to be in the correct position. Structure, shape and material are designed to fit perfectly to the shape of the neck, sustaining it and giving it relief.
Oct 23, 2017 | Major Computers & Internet
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
