Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Philips 50PP9202 50 in. Rear Projection HDTV-Ready Television?
Philips 50PP9202 50 in. Rear Projection HDTV Television
upper corner has red arch mark and lower bottom of tv has red mark also, lettering is doubled.
  • henrysmpj Jul 15, 2008
    I have the same problem but I also have the glass hour effect. any suggestions?
    Genius:
  • 1,139 Answers
Hello Anthony14,
This is an indication the the red convergence amplifier has goone bad you will need to replace the convergence correction modules. Now before replacing these you may want to make sure that the bias resistors and the zener diodes are ok. The convergence ICs are part number STK329-110 or STK329-150.
I would suggest that you get a schematic and equipment to make the needed tests, or take the set to a shop to replace the bad components.
I hope this helps,
Thank you,
Shuttle83
Posted on Oct 15, 2007
I have a 7 year old Panasonic HDTV. Picture quality has been great until today. As an example, the banner at the bottom of the picture is visible but it is also displaying in an arch mode above the...
Tv any colors mis alignment.The tv convergence board parts are dead.The convergence board require changing the 2 STK convergence ICS and some or all it resistors,this parts must change to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 27, 2010 | Panasonic PT-53WX53 53" Rear Projection...
From about 4 inches down from the top of the tv and from the center to the left corner is red and green and the corners on the bottom of the tv are also arched but not as bad
this is a vartical non linarity folt .
chech vartical stage capaciter 470umf/63v 4.7um/50v 1000/50v
0.47um/63v Replace and first svr.menu to set vartical linyarity adj.
set V- hight is sum down sum 1" or 2 " after the set vartical linyarity V-line. set up to down and check the pictur. if not then Replce capaciter.
Oct 04, 2009 | Hitachi 51F500 51" Rear Projection...
Red archs in the picture
Ur convergence it dead.Tries Websites Tv repair World.com,Tvrepairkits.com.U know to solders?Replaced the IC and all the resistors.
May 25, 2009 | Zenith R40W46 40" Rear Projection...
Phillips 60in 60pp93/5217 red and green arch at bottom of screen
you need the convergence repair kit which contains both convergence ics and all resistors along with step by step instructions. heres a link to the site that has the repair kit.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-dptv-305-dptv345-convergence-repair-kit/cName/convergence-repair-kits
Jan 21, 2009 | Philips 60PP9202 60" Rear Projection...
PHILIPS 50P8341 60 IN.
Check the other posts for convergence problems. This may be what you're experiencing. Have you tried bringing it in with multipoint convergence? It's under Menu -> Picture -> Manual Converge -> Multipoint Red and Multipoint Blue.
Dec 07, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 51pw9363
jessecool,
The convergence amps need to be replaced.. Your set uses two STK392-120 Sanyo original Ics.. Also all the low ohm resistors in that circuit should be measured for change in value and replaced if not within tolerance..
Bill
Nov 28, 2007 | Philips 51PW9363 51" Rear Projection...
Arches of words and top and bottom doubled with red words
Convergence mis-alignment = replace convergence amp IC's
Part # STK392-110 sub to upgrade STK394-160E. I use
Hitachi brand for no recalls.....................T.
Oct 31, 2007 | Philips 60PP9202 60" Rear Projection...
Convergence
Replace convergence IC's.
RE-check alignment
Oct 23, 2007 | Hitachi 46F500 46" Rear Projection...
Philips 55PW9363
Hi! ronogre,
This set has a defective SMALL SIGNAL BOARD.
Toprol
Jul 31, 2007 | Philips 55PW9363 55" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
89 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
