Question about Haier HTF24R21 24" TV
Block on how do you turn the block off teletision?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 140 Answers
The default code is "0000"
Here is a link to download the user manual:
http://www.haieramerica.com/en/support/
Posted on Oct 15, 2007
Where is the turn signal flasher in my fuse block on my 1985 Olds Delta 88?
THE TURN SIGNAL FLASHER IS LOCATED AT LOWER RIGHT CORNER OF FUSE BLOCK (OLD STYLE)
THE HAZARD FLASHER IS LOCATED AT UPPER CORNER OF FUSE BLOCK
Oct 12, 2017 | 1985 Oldsmobile Delta 88
HOW to turn off popup blocker in IE
Pop-up Blocker limits or blocks pop-ups on sites that you visit. You can choose the level of blocking you prefer, turn on or off notifications when pop-ups are blocked, or create a list of sites that you don't want to block pop-ups on. Pop-up Blocker settings only apply to Internet Explorer.
To turn Pop-up Blocker on or off
  1. Open Internet Explorer, select the Tools button , and then select Internet options.
  2. On the Privacy tab, under Pop-up Blocker, select or clear the Turn on Pop-up Blocker check box, and then select OK.
Block all pop-ups
  2. On the Privacy tab, under Pop-up Blocker, select Settings.
  3. In the Pop-up Blocker settings dialog box, under Blocking level, set the blocking level to High: Block all pop-ups (Ctrl + Alt to override).
  4. Select Close, and then select OK.
Turn off notifications when pop-ups are blocked
  3. In the Pop-up Blocker settings dialog box, clear the Show Notification bar when a pop-up is blocked check box.
support microsoft com
Jun 04, 2017 | Computers & Internet
2003 Buick rendezvous turn signal, and brake lights, and hazards lights stop working
Check the HZDLFL fuse# 40 - 15amp in the console fuse block
Fuse Block - Center Console
Inside of console, behind the right console access panel , if the fuse is good the turn signal / hazard flasher module is bad.
Turn Signal/Multifunction Flasher Module
In the fuse block - center console
Dec 05, 2015 | Buick Cars & Trucks
No cold water it's turned on and the water hose has no blocks
When you disconected the hose, did you turn the water on to see if you have water to the washer? There could be deposit blocking the water supply.there could also be blockege inside the washing machine
Mar 17, 2013 | Washing Machines
My sony rear projection tv's red light started blinking 8 times, so I removed the high vltage splitter, so I needed to test the block. And you guys are sugesting for me to turn on the tv, now do I
Turn on very briefly and make sure the large red wire that entered the block is well away from any metal---if hear a frying sound and blink sequence is gone the block is bad( I used to put the wire into a old soda bottle as it has over 20 thousand volts coming out of it, much like the spark plug wires in a car---high voltage with low current.
Nov 01, 2012 | Televison & Video
How can I find out what fuse makes the lights on the cluster and the a/c control panel turn on?
What engine size?prev.gif next.gif Underhood Fuse Block 4.2L Engine Except Saab Underhood Fuse Block (2002 - 2005 Early Production) gm-06-42-1628.gif
5.3L Engine Except Saab Underhood Fuse Block (2003 - 2005 Early Production) gm-06-53-1632.gif
5.3L & 6.0L Engines Except Saab Underhood Fuse Block (2005 Late Production - 2007) gm-06-53-1635.gif
Jul 12, 2010 | 2005 Chevrolet TrailBlazer
My phone is locked. I tried to turned it on but says SIM Blocked!
If sim is blocked all you need to do is contact your sim provider(sim company) through customer care number or through nearest retail outlet. They will provide you a new sim if it is locked due to putting wrong codes or if they have blocked it for some reason they will inform you and release the block.
Dec 13, 2009 | Samsung Cell Phones
What to do when one of the burners on the ranges do not turn on
HI the tap to the burner could be blocked might need greasing or the jets in the burner are blocked or the injector is blocked or the control switch is split and is turning on ths tap spindle
Feb 27, 2009 | Viking VGRC485-6 Gas Kitchen Range
Our TV Sylvania blocks some progrfams on ch. 51
Go to the TV setup menu and look for the V-Chip settings. Turn it off altogether or if you have children you may want to just raise the block up to MA, R, or X rated programs
Jan 25, 2009 | Sylvania 6427TE 27" TV
Haier HTF24R21 24" TV Logo
99 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
