Question about HP LaserJet 2840 All-In-One Printer
I have the hp 2840 lazer printer It burns on black spots on the edges. I have replaced all of the toners & the drum...still the same problem! Also, I can print sometimes...some times I cant unless I turn off the printer & then turn it back on...or if I go into the printer & hit restore, but it only helps for one or 2 prints. Can you help???:)
I would check the fuser assy to make sure that the teflon coating is not worn off or damaged.
Posted on May 13, 2009
Black stripe when printing from hp laserjet 2840
Cartridge faulty...
Two ways you can find out the faulty cartridge.
1. Remove each cartridge, just flip the drum shutter & chk for any toner bands appears on drum surface.. if found replace that cartridge..
2. Go to the paint. create four colored page as shown, print & verify which colored print mixed with bads.. replace that cartrdige.. ">
Mar 01, 2014 | HP LaserJet 2840 All-In-One Printer
We have an HP Color Laserjet 2840 printer in our office. We were low on our black ink drum, bought a new drum and installed it. Copies are coming out perfectly but the "replace black...
The 2840 is a slightly different sort of machine when it comes to supplies. There is a main imaging drum unit which works for all four colors, and then there of course are the 4 colors. If the unit was asking for a drum unit then you should have instaled a Q3964A. It is entirely possible that your drum unit and black cartridge both expired at the same time, in which case, you need a black toner cartridge now.
Jul 28, 2011 | HP LaserJet 2840 All-In-One Printer
HP Laserjet 2840 asked for drum replacment afther only 5300 pages but should make 20000. Prits where still perfect but now it refuses to print. Any solutions how to keep using the drum?
Check online for refill instructions and where to buy the chip to replace on the drum, most of the drums today have little chips to replace that tell the printer when they are used up, even when there's still life in them.
Dec 24, 2009 | HP LaserJet 2840 Printer
HP 2840- vertical black streaks on paper edges when copying using black only- copies fine in color
The Drum unit is worn or defective. try another drum unit. this should take care of your problem.If it's new then get your money back and replace it.
Dec 10, 2009 | HP LaserJet 2840 Printer
How to change the drum in the HP Printer 2840
romve the toner and right side scriw and left side scrue the remove in toner and remove the drum ......
insert the new drum if any probelm logon www.compudesk.in and click live chat and send off line msg .
Oct 12, 2009 | HP LaserJet 2840 All-In-One Printer
Toner specks along the edge of the page
Rev. Gregory.
Its looks like you have a small pinhole, or divot, on a imaging conponent that is common to all four toner cartridges. Remove the drum unit from the prtr and keeping the green handle close to you pull back the shutter which covers the drum, and look for spots of toner at the either end. If you hold the page with the spots on it, with the leading edge centered and touching the drum, it will give you some idea where the edgeis relative to the end of the drum. If you can't see any corresponding spots on the drum surface.
Put the drum unit back into the prtr and allow the prtr to restart, then switch off and remove drum, this will have turned the drum to a new position, and should show any defects. Only expose the uncovered drum to light for a minute at a time, and avoid touching the surface.
Let me know what you find.
Cheers
DeJudge
Sep 24, 2009 | HP LaserJet 2840 Printer
HP 2840 *(Error Message) = replace supply using black only Will only print in black All color and black toner are 75% or more full The drum was low so I replaced it just in case but error message remains.
By repalce supplies, it means that you have to replace the other toner cartridges and that it is only going to print black only
Al
Eliteprintersolutions@gmail.com
Apr 14, 2009 | HP LaserJet 2840 Printer
HP 2840, black ink drum q3964a
Hello, these printers tend to be finicky.
In other words, just replace the black toner. When the printer says its low, or empty, regardless of wether or not it is, just replace it.
Replacing the drum, when it says black toner needs to be replaced will do nothing to rectify the issue.
Buy only HP Toner and Drum cartridges for this printer. Do not try to refill toner cartridges, and do not reset drum. You will only end up destroying your printer in the process.
Feb 26, 2009 | HP LaserJet 2840 All-In-One Printer
Copies come out with splotches
replace the drum. take out toners and clean inside real good. check your exit rollers to see if they have any ink on them. be sure you use genuine hp products.
Jun 26, 2008 | HP LaserJet 2840 All-In-One Printer
Replace Cathridge
The front panel tells you witch toner cartridge should you replace. If a supply memory error ocures then the cartridge should be replaced or exchanged with a new one. The imaging drum unit is also consumable. for "Joe 50" - there are 4 toner cartridges in the printer.
Dec 28, 2007 | HP LaserJet 2840 Printer
HP LaserJet 2840 All-In-One Printer Logo
63 people viewed this question
Seeker5211
Seeker5211
