Question about Dell Latitude D600 Notebook
Can't obtain an IP address
I thought at first it was a virus that hit our windows 2000 systems that caused them to not be able to access the network or internet. We ran Avast boot scans and it deleted several viruses the first time, then we reran it a second time to make sure it got everything and it found nothing the second time.
Two system does some times they will connect, sometimes they wont. Now an XP machine is doing the same thing and we can not be running into these issues this frequently.
I ran ipconfig and I am getting a 169.254.xxx.xxx that will appear as an ip address and a sub mask of 255.255.0.0. The working systems get ips of 74.124.255.xxx and sub masks of 255.255.255.128 and they fill in the default gateway. I have tried everything I can think of to fix them and there are no viruses left.
  • rchaney86 May 13, 2009
    Found out it is a bad network switch. Plugged the computer directly to the modem and it worked, plugged it into switch it did not work.
  • Nelson Olaso
    Nelson Olaso May 11, 2010
    hi..did you make to try Obtain IP Address automatically and Obtain DNS server address automatically?..thanks..^_^
  • 1,602 Answers
TURN OFF THE FIREWALL IN WINDOWS, TURN OFF WINDOWS DEFERENDER AND ANY OTHER ANTIVIRUS PROGRAM YOU ARE RUNNING.
PS IF YOU ARE USING FIRE FOX THAN IT WILL NOT RUN UNTIL YOU DISABLE FIREFOX OR EVEN DELETE IT.
Posted on May 13, 2009
When my wireless access point is turned on, my computer is unable to renew the ip address. I show excellend signal strength, but "little or no connectivity"
Hi, Your computer is most like have IP address permanently asign. To change the setting for windows 7, click start, click control panel, click network & internet, click network sharing, click connection, click lower left hand property, click Internet protocol version 4 (TCP?IPv4), click property and click obtain and IP address automatically. Your Router will asign IP address. Windows XP, Click start, click connect to, click to show all connection, right click to the wireless connection adapter, click the property and click the down arrow click to TCP/IP, click the property and change it to obtain IP address automatically. That should work for you. Get back to us if this information help you solve you solve the problem. Good day now.
Jul 13, 2011 | NetGear WG602 802.11g/b Wireless Access...
Tip
Cannot access internet!!!!!
Using Windows Operating Systems:
Windows XP:
1.Powercycle equipment (Unplug power wait 15 seconds then plug back in)
2.Go to Start/Run/Type ncpa.cpl then hit ok.
3.Double Click Wireless Connection (Router Connection) Hit Properties.
4.Click on tcp/ip then hit Properties
5.Ensure Obtain ipaddress automatically is checked as well as Obtain a DNS server automatically is checked.
6.Restart Computer, If still unable to access internet check you Firewall:
Start/Control Panel/Windows Firewall/Change Windows Firewall Settings/Turn Off not recommended.
7.Last Go to Start/Run/CMD/Hit ok
A.Type netsh int ip reset reset.log Press Enter after every Command
B.Type netsh int ip delete arpcache
C.Type netsh winsock reset
D.Type ipconfig /flushdns
8.Restart Computer
9.If still having issues check for viruses or malware in your computer.
10..Refer to your manufacture.
Windows Vista/7:
2.Go to Start/Search Bar/Type ncpa.cpl then hit Enter.
3.Right Click on your connection usually (Wireless) then click Properties.
4.Uncheck Internet Protocol Version 6 IPV6
5.Click on Internet Protocol Version 4 IPV4 Then hit Properties (Do not uncheck IPV4)
6.Ensure Obtain ipaddress automatically is checked as well as Obtain a DNS server automatically is checked.
7.Restart Computer, If still unable to access internet check you Firewall:
A.Start/Control Panel/Security/Allow Program Through Windows Firewall/General Tab/Turn Off.
8.7.Last Go to Start/All Programs/Accessories/Right Click on Command Prompt then hit Run as administrator and hit continue.
10.Refer to your manufacture.
on Jan 11, 2011 | Computers & Internet
Tip
Before you start configuring the WRE54G you need to consider the following...
Before you start configuring the WRE54G you need to consider the following factors:
1. Make sure that there are no wireless security enabled on the router like WEP and wireless MAC filtering. If you have them enabled try to disable them first. Check if there is a wireless computer that is currently working on your network.
2. Make sure that the SSID broadcast is enabled.
3. Then Hit the Automatic Configuration button on the WRE54G for about 3-5 secs.
The wireless computer should be connected to the SSID of the Range expander.
The range expander doesn’t have any DHCP server. The IP address that will be assigned to the computer will be 0.0.0.0 or the Auto-configuration IP 169.254.xxx.xxx.
Assign a static IP address on the wireless card. IP address should be 192.168.1.5, Subnet Mask 255.255.255.0, Default gateway 192.168.1.1
To assign static IP address on your machine you follow the steps below:
Windows 9 xs and ME:
Go to Start > Settings > Control Panel > Network > Highlight the TCP/IP of the Wireless LAN card you’re using > Properties
Under IP Address TAB:
Specify an IP address: 192.168.1.5
Subnet Mask: 255.255.255.0
Click the GATEWAY TAB:
Under New Gateway: Enter 192.168.1.1 then click on Add.
Then Hit Ok All the way out… hit yes if it’ll ask you to restart
Windows XP and 2000
Go to Start > Control Panel > Network Connections > Right Click Local Area Network Connection that you are using > Properties > Internet Protocol TCP/IP > Properties > Use the following IP address:
IP Address: 192.168.1.5
Default Gateway: 192.168.1.1
Then click ok all the way out.
Try to ping the Range expander. Go to start and then run type CMD for Win XP/2000, COMMAND for Win ME and below. On the black screen that will pop-up type PING 192.168.1.240 (Default IP address of the Range expander.
If the ping test was successful then you can access the setup page of the Range expander. If not, try to reset the Range expander for 10 seconds and then power cycle it.
To reset the range expander, follow the steps below:
Hold down the reset button for 10 seconds then unplug power while holding down reset...plug it back in after 5 seconds then wait for 10 more seconds before releasing the reset button.
To access the setup page of the expander, Open your Internet Explorer and please go to http://192.168.1.240
If will prompt a username and password box, leave the username blank password is admin.
On the setup screen of the expander, you can set the same exact settings on your router. SSID, Channel, WEP settings should be the same on the router and you need to specify the WLAN MAC Address of your router to the space provided for the WLAN MAC address on the setup page of the Range Expander.
Once you applied the settings, the lights on the expander should be both blue.
You can now set your IP address back to obtain an IP automatically and Obtain DNS address automatically.
Range expander should be working after performing the troubleshooting steps above.
If you have an Ethernet port on the WRE54G, try to connect the range expander directly to your computer with static IP address then ping the WRE54G. Make sure that you are not running any firewall and Internet security in your computer. If you were able to ping the 192.168.1.240 try to access it through the Internet Explorer and configure it from the there. Follow the steps that I gave to you to configure the wireless settings of the range expander.
Make sure that you have checked all the wireless security settings on your router. Make sure that you have those disabled. Try to set static IP address in your computer and try to ping the 192.168.1.240 and see if you can get a reply.
To set static IP follow the steps below:
Windows 9x and ME:
Specify an IP address: 192.168.1.10
Windows XP and 2000
IP Address: 192.168.1.10
Then Hit Ok All the way out.
on Mar 08, 2010 | Computers & Internet
Local area connection doesnt have a valid ip connection
1. Powercycle you equipment ( Unplug power for 15 seconds and plug back in) make sure that you are directly connected. 2.Open your network connections to do that depending on your OS operating system. Windows XP: Start/Run/Type ncpa.cpl and hit ok Windows Vista/7 Start/Search Bar/Type ncpa.cpl and hit Enter. 3.Windows XP: Double Click on Local Area Connection and hit properties, Click Internet Protocol and hit Properties once again. Ensure Obtain an Ipaddress automatically is checked as well as Obtain DNS server automatically is checked as well if not check them both. Close out of Network Connections. Windows Vista/7: Right Click on Local Area Connection and hit Properties, Uncheck Internet protocol Version 6 IPV6 and Click on IPV4 and hit properties. Ensure Obtain ipaddress automatically is checked as well as Obtain DNS server automatically is checked if not check both. 4.Restart Computer 5.Open Command Prompt: Windows XP: Start/Run/Type CMD hit ok Windows Vista/7 Start/All Programs/Accessories/Right Click Command Prompt and hit Run as Administrator then hit continue. 6. In Command Prompt Write the following commands remember to hit Enter after each command. netsh int ip reset reset.log netsh int ip delete arpcache netsh winsock reset ipconfig /flushdns 7.If unable to renew ipaddress scan for Viruses inside your computer using a security software and if you are still having the issue refer to manufacture. Good Luck 7. Restart Computer
Jan 13, 2011 | D-Link (DI-711) Router
WIRELESS CONNECTION ISN'T WORKING, CAN ONLY ACCESS USING WIRE
Assuming you have Windows XP, let's check some settings for the network connections. Click on "start" - "settings" - "control panel" - "network connections".
First we'll check the ethernet connection. Right click on "local area connection" - "properties" - choose "Internet protocol (TCP/IP)" - "properties". In case of not at automatically settings, click on both buttons to "obtain an IP address automatically" and "obtain DNS server address automatically". Your screen has to be like this:
Click on OK at both windows.
Now we'll check the Wi-fi connection. Right click on "Wireless connection" - "properties" - choose "Internet protocol (TCP/IP)" - "properties". In case of not at automatically settings click on both buttons to "obtain an IP address automatically" and "obtain DNS server address automatically".
Now that we are sure that the settings are right lets see our connections.Connect your laptop with ethernet cable at the router and after the connection has been established, hit start - run - type cmd. at the new black window type ipconfig and hit enter. You will get the results for both ethernet and wireless connections. Mark with your mouse the details report and hit enter (for copying the results). Come back to this post and paste these results. I want to take a closer view of what is missing from your Wi-Fi connection.
I'll post you back details to do, when I see your report.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Sep 26, 2010 | Belkin Wireless Play Router (F7D4302)
Tip
Configuring WRE54G to a wireless router
Windows XP and 2000
Windows 9x and ME:
Windows XP and 2000
on Feb 07, 2010 | Linksys Wireless-G Range Expander (WRE54G)
Tip
How to check if you are connected to a usable network..
On any Windows device there is a set of protocols called TCP/IP.
When your device connects to a network, it attempts to obtain a TCP/IP network address that means it can connect to other devices on the network, or the Internet.
If it CANNOT obtain an address, you cannot do anything at all.
The actual address you obtain is set by the network administrator, but there is a way to tell if the network is not giving you a "real" address!
Windows 95 or 98 "start", "run" type in "cmd", then in the window that appears type "winipcfg"
Windows 2000 or later, "start", "run" type in "cmd", then in the window that appears type "ipconfig"
Both will give you screens of information that you can scroll through; look for your network adapter, then the IP address. (in the format xxx.xxx.xxx.xxx)
If the address begins 169.254 then you have NOT got a usable network connection.
on Dec 03, 2009 | Computers & Internet
No ip address on computer
IP addresses are generally assigned when you connect to another networking device such as a router, switch, or modem. You should first go to your Network Connections and right click on your networking device and click on properties. Click on Internet Protocol (TCP/IP) and hit properties. Then click on the box that says Obtain IP address automatically and Obtain DNS server address automatically. Now when you make connection with the router, switch or modem it should assign you an IP address. If this doesn't happen then you need to check your network cable, or wireless log in proceedure to find out why you're not connecting. These rules aren't for all systems. Some ISPs may require you to put in DNS servers and IP addresses. If the above doesn't help then contact your ISP to find out if there are specific settings. You can also view your Network Configuration settings by going to "Start" > "Run" cmd then in the window type /ipconfig /all. If you're connected properly you should have IP address, default gateway, DNS server and DHCP servers.
Oct 04, 2009 | Dell Inspiron 2200 Notebook
No ip address
when you say ip/config you mean wifi properties and internet protocol properties right ?
if so select obtain ip address auto and select obtain dns auto.
if thats not what you mean...goto control panel ..open network connections...click on ur network connection ...in the list at left select change settings for this connection...in network properties scroll to internet protocol..double click to open..select obtain ip auto and obtain dns auto.
there are other ways to fill in fields but you need relevant info..
there are programs which can show u ip's but most require a special driver.
incidently if you choose ip and dns auto you will not see ip address but when connecting to network you will see aquiring ip address please wait.
if for some reason you still cant connect go to a place where you know have free internet access and connect there then net connection will be configured
Jan 25, 2009 | Computers & Internet
Internet connectivity
TCP/IP network transport not installed
Symptoms: After you run Microsoft Windows AntiSpyware (Beta) or other anti-virus/spyware/adware software, 1) you may receive one or more of the following interactive error messages:
Could not start the Windows Firewall/Internet Connection Sharing (ICS) service on Local Computer. Error 10047: An address incompatible with the requested protocol was used.
or
Windows Firewall settings cannot be displayed because the associated service is not running. Do you want to start the Windows Firewall/Internet Connection Sharing (ICS) service?
or
This application has failed to start because SPORDER.dll was not found.
2) Third-party networking products may not function correctly.
3) Computers may not be able to connect to the network because they cannot obtain an IP address.
4) You may receive the following error message when you are using Microsoft Internet Explorer:
Error 404: Page cannot be displayed.
Cause:
There are known spyware programs that install layered service providers (LSPs) on client computers to gather user data. When Windows AntiSpyware (Beta) removes spyware programs, it also removes the spyware-based LSPs. However, Windows AntiSpyware (Beta) does not restore any LSPs after it removes the spyware.
Resolutions:
How to rebuild the Winsock LSP chain on Windows XP SP2
How to rebuild the Winsock LSP chain on Windows XP, XP SP1, and Windows 2000 __________________
Bob Lin, MS-MVP, MCSE & CNE
How to Setup Windows, Network, VPN & Remote Access on http://www.HowToNetworking.com
Networking, Internet, Routing, VPN Troubleshooting on http://www.ChicagoTech.net
Oct 17, 2008 | HP PAVILION A6230N DESKTOP PC
Dell Latitude D600 Notebook Logo
76 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
