Question about Cycling
I have a kawazaki kvf 400 1999. the oil level is never the same : one time high, one time low, one time high... at every check and i don't have leaks, what's going on? If i have a little burning by the piston ring because they are sticked, can i soil the piston top with WD-40 by the spark hole over a night, **** it by the spark hole and start it?
  • 200 Answers
Make sure you are checking your oil with bike level on level ground. Then check it at that location everytime...if you have a centerstand use it...Now the diptick shoul be unscrewed ,wiped clean and when reinserted DON"T screw it back down, check oil level w/ dipstick threads showing...i think your high/low ghost will disappear !....Good Luck to you friend...Tim
Posted on May 13, 2009
What does it mean when the vsa indicator and the engine emblem appears at the same time with code p2647?
I am not sure why they would both come on at the same time but the code P2647 means - Rocker Arm Oil Pressure Switch (VTEC Oil Pressure Switch) Circuit High Voltage.
So first thing first in diagnosing this code is to check the oil level.
Have the engine run for a bit and get warm to build up proper oil pressure. Then turn engine off and let the vehicle sit for a minute or two. Have the vehicle on level ground and check the oil level and condition.
If the level is low then top up till it is at the full line. When the engine oil level is low it may not have enough oil pressure to control and activate the VTEC system thus causing this code.
If the oil is super dark and black then you may be due for an oil change. (should be done around every 5000km.)
Sep 27, 2014 | 2006 Honda Odyssey EX
Tip
How to change oil
How to change your oil: * Make sure that the car is parked on level ground and the engine is shut off * Pop open the hood, you will see the metal loop sticking out of the engine block. This dipstick is usually in red for easy recognition. * Have a thick paper towel in your hand and pull out the dipstick with the other, wipe the end of the dipstick until there is no oil left on the dipstick * Insert the dipstick back in and wait for a few seconds. Remove the dipstick once again and look at the end of the dipstick. CHECK and MAKE SURE that the oil level is between the "Low" and the "High" mark. If the oil is at the low mark, it generally take 1 quart of oil to get it up to "High". * Also check the quality of the engine oil. If it is grainy or has little nuggets or looks dirty, it's time to change your oil. * Open the drain plug that is located beneath the engine and make sure your pan is big enough to collect all the oil that drains out. * Also install a new oil filter (From $4). * After draining the oil, tighten the drain plug in securely. IMPORTANT! Do not over tighten the drain plug as it will strip the oil pan and this could cost about $500-$800 in repair at the BMW dealership. Be Careful! * Fill up with the recommended quarts of oil. * Check the dipstick and make sure that the oil level is between the low and high point. * Check your oil level and quality of the oil every week, or bi-weekly when in low usage. Also do not forget to check for oil leaks, a simple glance on the garage floor will do the trick. * For conservatives, remember to change your oil every 3000 miles or 6000 miles if you use synthetic oil. It is a cheap but good prevention against engine damage. Remember the mileage between oil change also depends on your driving condition. * Reset your Oil change reminder on your car. That's it, you made it!
on May 19, 2008 | 1993 BMW M5
Have a gauge hooked up to low pressure fuel pump and it shows it works but high presssure one doesnt
Check to see you have oil up to full on dipstick . The high pressure pump picks up oil at the top level so if oil starts to get to low engine will stop before engine damage . The high pressure pump is what makes the injectors fire . Also check the wires that go thru valve cover some times they burn up and you can smell the burn thru the oil filler cap .
Apr 05, 2014 | 1996 Ford F350 Crew Cab
Oil pressure high, oil level low
Oil pressure and oil level are two different creatures.
your oil gauge determines oil pressure while the oil can (red light on dash) indicates oil levels.
There are usually two different sensors but can gauge the same types of things. E.G. - If your oil is so low that your pressure gauge is affected this can cause engine failure. Thus--a good rule of thumb is to check your oil once a week as the oil pressure gauge and red oil can may not always work as intended.
I hope this helps!
Aug 13, 2012 | Cars & Trucks
I have a 2002 jeep grand cherokee lerado with a 4.0 my oil pressure is normal when i drive but when i stop my pressure goes low
A low oil level will cause this. If the oil level is fine, then you need to have a mechanical gauge to verify the pressure is really low and that you don't have a bad oil pressure switch. You could try replacing the switch first if you don't want to put an oil pressure gauge in the vehicle. If the pressure is indeed low and the oil level is normal then replace the oil filter to see if that brings the pressure back up. If the pressure is still low, remove the oil pan to check the pick-up tube for debris. If it is clear of debris then you'll be needing to replace the oil pump. Another possible cause of low pressure is a damaged rod or main bearing and would require the engine to be rebuilt.
Jul 15, 2011 | 2002 Jeep Grand Cherokee
I have a ATLAS COPCO GA 160 w at my work and it is shutting down on high element temprature. I noticed that the oil level in the seperator is low and have topped it up a few times but everytime i run it...
Without more info or knowing your compressor my first question to you is,is the oil cooler clean and does the unit have good water flow. DO you have good water flow / pressure. The oil level should be about half way the sight glass running loaded. If the oil level was low ,when the thermostat opens it allows oil to flow to the cooler which lowers the oil level.Typical problems during this time of year are , , dirty oil cooler, Faulty thermostat, Faulty element temperature sensor, Low oil levels and bad oil. Also dirty oil filters restrict oil flow and can cause high element temp. problems. Try back flushing the water side of the oil cooler. Have you checked to make sure the water solenoid is opening. May have a bad coil or valve. May also have water solenoid plugged with something. What is the cooling water inlet temp and outlet temp. The W usually indicates water cooled. If not water cooled, most of the above also applies to air cooled units. just replace water with air if it fits.
Jun 28, 2011 | Air Tools & Compressors
2.8l v6 in a s10 blazer. no head gasket problems thus far. wondering why my oil pressure gauge fluxuates? minor rpm change while oil pres guage does its thing why?
Oil pressure always changes with rpm.
At idle you should have around 10 psi, and it should max out at high rpm around 50 psi or so.
You not only can't have as much pressure at idle, but you don't need it either.
Jun 06, 2011 | 1989 Chevrolet S-10 Blazer
I don,t not how to check oil level on my 650r honda 2001
To check your oil on your 2001 XR650L you need to run the motor for 5 minutes. Then pull the dipstick on the frame neck , wipe it off, reinsert the dip stick without screwing it in, pull it back out and look at the level. it should be between the high and low marks. Only use JASO MA certified motorcycle oil . Do not use any oil that says Energy Conserving on the label. It will shorten the life of your wet clutch and transmission gears. Synthetic oil will help your bike run cooler and shift easier.
Oct 26, 2010 | 2001 Honda XR 650 R
High temp low oil 2003 ford explorer
High temp could be low coolant check your coolant level. Low oil-check for leaks, if no leaks then check for blue smoke out exhaust, if no blue smoke it could just be low. A vehicle will go through a quart of oil between oil changes, even a newer one.
Apr 13, 2010 | 2003 Ford Explorer
How to deactivate check belt light for 2007 kawasaki kvf 360 4X 4 atv
on the KVF on the right side you will see 2 plugs, a grey and a black. conect the grey to black on both turn the key on for 2 minutes . turn the key off and then switch back to there proper position. this should work. The Check belt light comes on when its time for an oil change..
Apr 02, 2009 | Sport & Outdoor - Others
Cycling Logo
138 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
