My 1 year old Samsung LE40M86BD has been turning on and off. It only does this if im turning it on i would have to wait 2mins the first time it did. Then it slowly got longer today it took 2 hours till it eventually turned on my warranty just ran out on Feb. Not sure what could cause the problem i unplug it every night.The set makes a clicking sound like something inside is making it switch off the TV itself is perfect had nothing wrong with it besides this. Thanks a bunch if you do reply i jus hope for a DIY fix rather then take it to a service engineer.
SOURCE: Samsung HPT4254X/XAA plasma turns off and on by itself, clicking.
My samsung does the samething. TV is 3 yrs old. Repair guy said, it needs a new computer board. Said, that about 75% can be repaired if you can see what the problems is on the board. But the others show no sign so has to replace the whole board at $175.00 for the board and total cost around $300.00.
Posted on Aug 20, 2010
  • 7 Answers
SOURCE: Samsung LN-5265F LCD TV is very slow to come on.
its the elecrolytic capaitors on the power supply.
goto www.earthinfo.org/samsung-tv-makes-a-strange-clicking-sound
it shows how to fix it yourself for only 'peanuts'
Posted on Aug 05, 2009
  • 8457 Answers
SOURCE: samsung tv clicking sound
It ur power supply board it have components,is dead could be anythings,Capacitors bulbging happen mostly only on DLP Tv bacauce the FTB transformer,give high voltage for projection.Tries thes websites for replacement power supply board.Shopjimmy.com,Tv Repair World.com,Partstore.com or Ebay.com.
Posted on Sep 26, 2009
  • 610 Answers
SOURCE: TV screen went blank and it began clicking, turning
the power supply board has failed. call 1-800-samsung for nearest service center. power supplies are usually $125.00 plus labor, 1 hour maximum to repair.
Posted on Nov 24, 2009
Testimonial: "Thanks so much! Samsung customer service was less than helpful with this, but you came through! Awesome!!!"
cschindle725
  • 67 Answers
SOURCE: Samsung 40" lcd tv with power supply fault?
you need to replace the 10v blown capacitors with 16 volt or higher go to utube and type in samsung power supply fix and you can do this yourself for about 30 bucks
Posted on May 30, 2010
How do you replace the water level sensor?
Samsung Dishwasher Repair oE code_CRICKET in Water ...
? 3:23
https://www.youtube.com/watch?v=YOvFYcaLp8w
Jun 22, 2014 - Uploaded by Mgionfriddo
Samsung Dishwasher failed less than a year old. ... Removedwater level sensor to inspect and found a dead cricket blocking the float inside of it. ... worst, it'll throw that error right after 2mins of power on, any ideas what to do next? .... Dishwasher HeaterReplacement - Samsung Dishwasher Repair (part ...
Dishwasher Water Fill Sensor Replacement - LG ... - YouTube
? 6:28
https://www.youtube.com/watch?v=JjM-4FAg0Nc
Jan 24, 2013 - Uploaded by RepairClinic.com
Dishwasher Water Fill Sensor Replacement - LG DishwasherRepair (part #6501DD2001A) ... instructions ...
Nov 24, 2015 | Dishwashers
I have a miele dishwasher model G2270SCVI it is about 8 years old.It has just started tripping the meterbox every time we turn it on for a cycle{after about 2mins}i have removed the metal toe plate and...
Water in the under side of the washer is probably shorting the unit out, making for a potentially very dangerous and potentially lethal hazard.. Turn the breaker off to the dish washer until you have figured out where the leak is coming from. Is it from the supply line that feeds the water to the machine or is the tub leaking. I would guess the water supplu line is leaking.
May 24, 2014 | Dishwashers
SAMSUNG LE40M86BD kept clicking for 30 mins when turning on....i replaced copacitors 1000uf 35v all 4 of them. Tv turns on and works normal. But on start up, it blinks red light 4-5 times before turning...
Tv power supply board still have more problems and dying components parts test more and replace more capacitors parts,not all capacitors parts are weak and dying are showing up bulges or puffing up.Test all capacitors components if any not showing the correct Micro Fared and voltages replace it should shoved this problems.
Aug 19, 2011 | Televison & Video
When i turn on my compaqu v621au lap its LED glow but the screen is completely blank and harddisk LED does not glow, what is the problem? frnds help me out from this problem
Hello Rituraj,
Welcome to FIXYA!
We need some more information to give you the proper solution.
1) Does you able to get the display on your lap screen?
2) Does you connected the Power cable to the Lap?
Suggestion:-
1) Connect the Power cable and try to switch ON the laptop, Wait for 2mins if you not get any display. Unplug the Power cable, Dismount the battery (Back side), wait for 2mins and reconnect the battery.
See it should resolve the problem?
happy to hear from you the feedback!
With regards
FIXYA
Sep 22, 2010 | Computers & Internet
SAMSUNG LE40M86BD very thin black line
The screen is failing. A conductive strip from a flex connector to the glass panel is losing contact when cold. Any warranty left? extended warranty? Usually not repairable, screen has to be replaced and cost as much as a new set....
Mar 24, 2010 | Televison & Video
Samsung LE40M86BD keeps turning off and back on. But only when playing HD Blu Ray discs. Could you help with this problem. Why is it happening
I'm now having the same problem with my Samsung LE40M86BD (it happens when I'm playing my Xbox though). Did you ever solve it / find out why it was happening?
Mar 01, 2010 | Televison & Video
I have samsung 40 inch plasma (model LE40M86BD) will not come on . stand by light flashes and clicking relay sound from inside alternately . has gradually got worse.now will not switch on.
You plasma cells have died off. That relay making noise is not good. Sorry about the bad news. Plasma tv are knowing to do that after few years or so.
Nov 23, 2009 | Samsung Televison & Video
Wrong code now says wait
Disconnect from power source (or pull fuse) wait a few seconds and try again.
Good Luck
Jun 21, 2009 | Car Audio & Video
I have an AKAI 50in DLP rear projection HDTV keeps shutting down
hey there is sounds like your tv is trying to tell you to replace the lamp
the lamp is running out of mercury gas and is starting do give up I recommend you get a new bulb
Jun 19, 2009 | Akai PT50DL24 Television
52 HD Samsung tv turns off
I have the same problem with my 56" HD Samsung. It shuts off automatically and then on the power button the word Lamp is light up in green. Sometimes I can turn it back on but other times it won't and I have to wait a bit. It's been embarassing a couple times when people were over for a movie. I believe it might be some kind of overheating problem but would like someone to confirm this.
Jul 06, 2008 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
646 people viewed this question
Top Televison & Video Experts
