Question about Microsoft Windows XP Professional for PC
When booting the system the following error message appears: SQLDUMPER failed initialization
    President:
  • Microsoft Master
  • 1,996 Answers
Please see this link for a solution to this error: click here.
Posted on May 13, 2009
    President:
  • 2,559 Answers
You just need to uninstall the microsoft SQL server in add/remove programs,This is due to a service pack 3 overwrite.
    Sergeant:
  • 138 Answers
Go go to add and remove programs and uninstall the microsoft SQL server, this will take care of the problem
  • 11,896 Answers
The uninstall tool vs_uninst.exe located at http://download.microsoft.com/download/0/a/a/0aacd9c1-a0c5-43ab-a428-0ee440d4472c/vs_uninst.exe.
this error usually occurs when removing certain Microsoft products, or when using the SQL server. Here is a few articles which may help you correct your issue. First, it is a forum where an individual has a similar issue, and the help offered:
http://www.sqlteam.com/forums/topic.asp?...
Next, a Microsoft Knowledge base article on the SQL sqldumper utility, and some troubleshooting techneques:
http://support.microsoft.com/kb/827690
The next page is the SQL tech support and has different errors which can be generated. Look down the list and see if you can locate your particular error and when/how it occurs:
For SQL 2000:
http://www.gridview.org/kb/SQL2000/defau...
For SQL 2005:
http://www.gridview.org/kb/SQL2005/SQLSe...
    Champion:
  • 381 Answers
Hello..the error or failed message is came from not completely install the windows/OS or OS is defective..try to re-install the windows/OS using a good copy of CD/DVD or try to clean up the CD/DVDrive Lense of player...Thanks and Good Luck..Have a Nice Day...^_^
When I started my DELL Inspiron 1525 running Win 7 Ultimate, I got a white-on-black screen which questioned the voltage from power adapter. Diagnostic program run.. Stopped with the following msg: Error...
2000-0142 and 2000-0146 are hard drive SMART errors, indicating the HDD will fail.
To boot message about the AC adapter was a BIOS level message that normally appears when a Auto/air ac adapter or other 65 watt ac adapter is used to power the system.
Jul 16, 2011 | Dell Inspiron 1525 Laptop
When I turn on the PC the following message appears and my system goes turn off... For Realtek RTL8101E/8102E PCI-E Ethernet Controller v2.13 PXE-E61: Media test failure, check cable PXE-M0F: Exiting...
This error occurs when the BIOS finds no hard disk drive to boot from, and tries and fails at booting thru the network jack (PXE Boot is a network boot used in large corporations, usually to image a system.)
Reseat the hard disk drive in the system, then reset the bios defaults and see if the system will boot normally. You can also try running diagnostics (Fn + Power on a Dell)
Most likely scenario is that the hard disk drive has failed and you will need to replace it.
Jul 15, 2011 | Computers & Internet
I get ''SQLDUMPER LIbrary failed initialization'' when i start the computer
SQLDUMPER is an accessory for Microsoft SQL Server that will allow you to track down problems with MSSQL. There's no need for it on your system if you're not using SQL Server.
Using Control Panel, select [Add or Remove Programs], then select the [Microsoft SQL Server] program and click on the remove button.
If you want to reinstall it, you can go to MSDN.microsoft.com and get a new copy, but if you're not using it and no programs you are using are, there's no reason to have it.
May 26, 2011 | Microsoft Windows XP Professional for PC
Hi, My laptop doesn't boot up. I got a blue screen with the following error message- STOP: c000021a {Fatal System Error} The initial session process or system process terminated unexpectedly with a status...
Thats known as a blue screen of death. you simply have to put in an operating system CD which is bootable (the one which you are currently using win xp vista or whatever) just boot through the cd ignore the first repair option and hit enter when the option for repairs appears for the second time just hit R and follow the options. you won't loose any data.
Aug 20, 2010 | Dell Inspiron 1525 Notebook
System initialization has failed
do a system restore back to the point it was last working.
hope this helps.
Apr 29, 2010 | Microsoft Dialogue Technology Flybook V5
"failed to initialize" camerawindow-downloading images to macbook
Do what the pros do...use a card reader to download to a folder you create on your desktop.
Feb 20, 2010 | Canon PowerShot A470 Digital Camera
Latitude delld610 Boots with the following
press F2 to get into the dell bios and be sure the HDD is listed as first to boot, Then if restart turns the same error, press F10 and run the pre-boot system assesment check. if error 0141 appears, your HDD is failing and needs to be replaced
Aug 24, 2009 | Dell Computers & Internet
I get I get SQLDUMPER LIbrary failed initialization
SQLDumper is used to collect stack information and debug information in case SQL Server crashes. The dump that is created out of this is normally send to Microsoft and is used by the development team to debug problems (not that you can elect not to send this information to Microsoft).
The error above means that likely your SQL Server installation is corrupt, so I would suggest that you reinstall SQLServer.
Apr 14, 2009 | Microsoft Windows XP Professional for PC
I'm am trying to play age of mythology and after the movie ends, error appears and states "initialization failed".
Initialization failed
This means that the game is attempting to initialize hardware such as the video card but has failed
This can be caused by a number of factors.
1. Your hardware does not meet the games hardware requirements
2. Your hardware requires farther configuration to run the game properly
if you are certan that the game supports your hardware you may need to perform
some extra steps to get your game working
"Failed to initialize" is an incomplete error message because it does not tell you what exactly failed
a more complete error message would read "Failed to initialize the video subsystem" and then it would give an error code such as Error Code xxx telling you exactly what error code to look up
to determine what exactly failed.
Most of the time when a game says ( failed to initialize ) that means a video issue
this may mean missing files or wrong versions of files or incompatable hardware.
Selah.
Sep 15, 2008 | Computers & Internet
Microsoft Windows XP Professional for PC Logo
168 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
