Question about Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Washer stops during begginning of cycle with F 35 reading .
Early in the wash cycle with my 8 mos. old Whirlpool Duet Front load Steam Washer it stops and flashes either F 35 or Sud error readings. I then have to unplug and replug to get it to start again. Sometimes with several attemps. Very annoying and makes laundry a slow going project!
  • Michael Masters
    Michael Masters May 11, 2010
    Are you using the correct HE detergent?
  • 15,935 Answers
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
F-35 code My washing machine Whirlpool duet steam machine keeps going into the F-35 Code and stops washing.  I don't have the book.  Please, if anyone knows what this means or how to fix it, my email is...
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Sep 12, 2008 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
My whirlpool steam duet washer won't pour water in the wash cycle
There is no output from the control panel to switch on the inlet valve, so check the inlet valve at this time of the cycle. Also check the water level pressure sensor switch.
Choose another program to confirm if not the controller seems to be suspect.
Jan 24, 2013 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
We have a Whirlpool Duet WFW9400SW02 that is making loud noise during the high speed spin cycles. It is only 13 mos old. Whirlpool will not even stand behind the parts. The repair person estimates over...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Error code F-35 is showing on my whirlpoot steam duet stackable front load washer, what does that mean? It won't run through any cycles.
it is an analog pressure sensor failure theres a malfunction with the steamer component detected by the steamer electronic board
check if pressure hose is fixed correctly
check if the airtrap is not blocked
check if the hose is not blocked
hope this helps if this doesnt work write me back
Jul 21, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
During wash cycle the washer stops at 11 or 12 minutes left and screen reads F . i have a frontload whirlpool duet HT
Just F on its own?
Try to clear it doing the following:
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and select HOLD TO START. If the problem
remains, call for service.
Hope this helps comment back if you need further help,
Jul 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet bounces across the floor during wash cycle!!!
yes , first make sure your machine is balanced , and if you want to risk it to check the springs all you have to do is remove the top and check if one of the springs is longer thet the other or if tub is **** eyed, I am assuming you removed the shiping bolts before connecting your washer.
also your frame or base might be dammaged from shipping.
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does F 35 mean on the front load washer? it's a whirlpool duet steam
it may be a problem with the pressure switch clean it out and see if this clears the error code
Nov 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Front Load washer won't start
according to site an f-01 relates to a CCU issue, remove power for 2 min and try to reset, if not check wiring to CCU(central control uint) all in tact?? replace CCU
Mar 03, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Duet 4.0 Cu. Ft. Steam Washer Logo
324 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
