Question about Canon Office Equipment & Supplies
Canon Printer Cartridges
I have refilled the cartridges on my IP2500 printer a short time ago but now it's stopped printing saying they are empty when I know they're not. Is there any way round this?
    Sergeant:
    Champion:
  • 240 Answers
Try to unplug and plug it again..to reset everything..
or reload your cartridge on the carrier..
Posted on May 14, 2009
Why lexmark 3550 won't print after installing new ink cartridges
Check your manual for instructions about this type of problem. Are you using the ink cartridges meant for your printer? Sometimes using refillable cartridges instead of the manufacturer's cartridges can cause the printer to still think the cartridges are empty, and display an 'on-screen' message that they need to be replaced, which could stop the printer from engaging. I have a Canon Pixma printer, installed refillable cartridges, and now the unit displays a 'cartridges are empty' message on PC screen; but the printer still works. The system just recently went into a non-printable mode displaying a more convincing message that the black cartridge is EMPTY, and completely stopped printing. The solution to this: press and hold the Stop/Reset button for about five seconds, and it overrode the issue and started printing. Moral of the story, maybe its best to just buy the manufacturer's printer cartridges.
Jul 26, 2014 | Lexmark Office Equipment & Supplies
Why can't I print black and white, without colored ink?
I have the same problem & have been searching for weeks for a replacement printer that will print B & W with one or more colors empty. I haven't had any luck yet - I did run across a post that said: For black and white images and photos, a blend of colors called "composite black" may be used to achieve significantly better image quality and smoother gray tones than can be accomplished with black inks alone. I'm still searching...
Jul 28, 2010 | Epson Stylus CX5000 InkJet Photo Printer
Just changed cartridges to refills and clour and black lights flashinghowever we can still print ok. Why are the lights flashing?
The lights are flashing because you are using refilled cartridges. The printer "sees" those cartridges as empty, since it can not know that someone has refilled them. When you put in new cartridges, the lights will stop flashing.
Just ignore the lights and print!
Hope that helps!
May 19, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Bland and color cartridges have been refilled but
Ink level counter (program) didn't read actually ink at ink tank. Brand new cartridge ink level counter 100% (full), and ink 100% (about 10 ml). After may printing, ink will dry out, and ink level counter reach zero (ink out). Printer will not allow print anymore, even have refilled, because ink level read "ink out". For canon type, you just to release ink level counter, and counter just stop, but printer will allow to print. Press stop/reset button for about 30 second.
Mar 15, 2010 | Canon PIXMA MP190 All-In-One InkJet...
I refilled my printer cartridges.they are full i did all the diagnostics cannon maitenance said and they are still not printing. it printed for a little bit then it stopped.it says that both of the...
You can't reset the ink level on all Canon Pixma printers.Press the resume button for 5 seconds.This operation releases the function for detecting the remaining ink level of the above ink.The printer shows empty cartridges but it will printing.
Nov 02, 2009 | Canon Office Equipment & Supplies
My refilled canon ip1600 ink jets are reading as empty
To get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
Jun 09, 2009 | Canon PIXMA iP1600 Printer
Refill cartridges
This is normal.
Printer will warn the ink is getting low. almost empty very nearly empty....
then (in effect) it says if you want to use refilled cartridges you can but it may void printer warranty. Press yellow flashing button for 5 seconds to "release ink detection" (summat like that).
Printer will continue to print but shows the cartridge as empty. Its your responsibility to make sure you do not run out.
It does this separately for each colour - tedious for the pro9000 with 8 colours
Feb 14, 2009 | Canon PIXMA Pro9000 InkJet Photo Printer
Printer cartridges not recognised
Sometimes even when an ink cartridge has been refilled to capacity, your printer still registers it as empty. This is because your printer remembers that the cartridge was previously installed and it can only remember it as being empty. Part of this is due to technology put in place by printer manufacturers so that you will always have to buy new cartridges. Part of it is also that print catridges are clogged if not used for sometime after its empty even after refilling this is because the contact was already clogged due to the dryness of the old ink inside it before refilling so in that case you will clean/soak the contacts with solvent before refilling .
again since there is no “official” way to fix this problem, you have to basically clear the printer’s memory to make it recognize that you are installing a full cartridge. If you have tried to install the refilled cartridge and you have done all you can to convince your printer that the cartridge isn’t still empty, then basically you just have to unplug your printer for a minute and then trying reinstalling again. but it should fix this problem and it can potentially fix other annoying things your printer is doing.
Sep 06, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Reset Ink levels for canon mx310
To Reset the Canon Cartridges Works 100%
Power off the printer
Hold the stop/reset button then press and hold power (for 5 secs)
Hold Power and release the stop/reset button
Press the stop/reset button twice
Relase power button
Wait until the power button lights a steady/still green, press the stop/reset button three times with a 3 sec space between each press.
On the 3rd press the inicator should be orange.
Press the power button to set data
To set data remove cartridges then replace.
leave for 20 or 30 secs
Press the power button again to shut down
Then press power button to power up.
The printer will feed one piece of paper through
then set language and counrty.
Then ink should be reset
Any problems contact me on charmed_halliwell@hotmail.co.uk
Jan 31, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon ip4200
Hi You can buy canon refile "InkTec Canon BCI-5/BCI-6 color" and fill Remove the empty and try to print,or you can buy canon refile "InkTec Canon BCI-5/BCI-6 color" and full it,it`s cheap instead to buy everytime a new cartidges. Good Luck
Aug 19, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
127 people viewed this question
old marine
old marine
