Question about Troy Bilt 5.5hp Self Propelled Mower
Need replacement belt guard for sovereign lawnmower
Original had fight with rockand is deceased and now belt completely exposed and more prone to debris
  • 11,896 Answers
  1. Discount Troy Bilt Partsupstateoutdoorpowerequipment.com Save Up To 35% on Troy-BIlt Parts. Save Up To 35% on Troy-BIlt Parts.
  2. Troy-Bilt Partswww.partstree.com/troy_bilt_parts Need Troy-Bilt Parts? Look Up Parts and Diagrams for All Models.
  3. Troy Bilt PartsSearsPartsDirect.com
HERE IS THE ACTUAL PART YOU CAN BUY FROM EBAY!!!!!!!!!!!!
http://cgi.ebay.com/Troy-Bilt-NEW-Bumper%2FGuard-Attachment--Part-%2311045_W0QQitemZ280344217654QQcmdZViewItemQQimsxZ20090511?IMSfp=TL0905111310008r5209
Posted on May 13, 2009
How to put on new belt
https://www.partstree.com/parts/troy-bilt/edgers/tb516ec-25a-516-966-troy-bilt-edger-2011/general-assembly/
Zoom into the diagram, remove (item 45) belt cover to expose the belt and pulleys. Take note of how the belt is routed.! you will need to follow the same route with the new belt. You may need to remove the Blade guard (item 40) if the belt doesn't fit over the head of the guard. There may also be a sprung idle tension pulley, which will take up the slack in the belt once replaced. Looks pretty straight forward.
Apr 19, 2016 | Troy-Bilt Troy-built Tb516ec 4-cycle Gas...
Tip
Replacing Riding Lawnmower Blade Belts.
I discovered on a Craftman Riding 3 bladed mower that there is an easy way to replace the belt for the blade pulleys.
The mandrel cover of the Left side blade is the only part you need to remove to replace the belt. You can insert the belt under the right side mandrel cover and onto the clutch pulley before finishing on the left side of the mower.
The tensioner or idler pulleys will contract when you pull on the belt. When you get to the left blade pulley you can turn the pulley with one hand and guide the belt with the other hand. The belt will walk right up onto the pulley. Attach the cover and you're done.
I like my method because you can stay away from a hot engine and replace the belt without waiting for the motor to cool off. You are also not fighting the mower clutch or drivebelt with my method.
on Dec 16, 2010 | Garden
How do I change the belt on a dirt devil dynamite II cyclonic
Hi! Happy to help with that. Please follow the steps below.
  • Lay cleaner flat and flip cleaner to expose nozzle base. Base should lay flat and face up. To remove nozzle guard, use Phillips screwdriver to remove the three (3) screws.
  • Lift and remove brushroll. Dispose of old belt.
  • Slide belt onto motor shaft.
  • Place new belt in area of brushroll without bristles.
  • With new belt in place, pull and slide brushroll into nozzle making sure that the brushroll end cap on the left is in the correct orientation. Rotate brushroll manually to make sure belt is properly aligned.
  • Reattach nozzle guard by carefully sliding back into place. Interlock rollers and nozzle guard by tilting rollers down towards the base while replacing the nozzle guard.
  • Be sure to replace all three (3) screws.
Hope this helps!
Oct 12, 2014 | Dirt Devil Vacuums
How do i change the belt on the dirt devil vacume cleaner
Hi there! Below are steps to replacing the belt on your vacuum. I have also included a link to the instruction manual which has illustrations if needed.
1. Lay cleaner flat and flip cleaner to expose nozzle base. Base should lay flat and face up. To remove nozzle guard, use Phillips screwdriver to remove the four (4) screws. Arrows show location of screws.
2. Lift nozzle guard off.
3. Slide belt off motor shaft.
4. Lift and remove brushroll. Dispose of old belt.
5. Place new belt in area of brushroll without bristles.
6. Slide belt onto motorshaft.
7. With new belt in place, pull and slide brushroll into nozzle making sure that the brushroll end caps are in the correct orientation. Rotate brushroll manually to make sure belt is properly aligned.
8. Reattach nozzle guard.
9. Secure by aligning the three (3) tabs in the base slots. Be sure to replace all four (4) screws.
http://bit.ly/1s8GQSX
Hope this helps!
Jul 27, 2014 | Dirt Devil Featherlite Bagless Vacuum...
Belt is strech doese not pick up diert
Hi! The brushes are needed to spin on carpet to agitate the carpet fibers and assist the motor with maximum pick up. If the belt is stretched you will need to replace it. This unit takes belt 562633001. Below are step-by-step instructions for replacing the belt on your Nano.
1. Lay the cleaner flat and flip it to expose the
nozzle base. The base should lay flat and face up.
Remove the five (5) screws.
2. Pull and lift the nozzle guard off.
3. Lift and remove the brushroll. Dispose of the
old belt.
4. Slide belt onto motorshaft.
bristles.
6. With new belt in place, pull and slide brushroll
7. Reattach nozzle guard.
8. Secure by aligning the three tabs in the
base slots.
9. Replace all five screws to secure nozzle guard.
Follow the link to order a replacement belt for your vacuum. Flat Belt Nano Upright
Hope this helps!
Mar 04, 2014 | Hoover Nano Cyclonic Compact Bagless...
Need to put a new belt on the rear of the Troy-Bilt LTX 1842
First buy proper belt... Next note how old belt is warped around the pulleys, take a picture or draw a diagram... Remove all covers off deck pulleys, and guards to expose belt completely... Pull and stretch belt off one of the idler pulleys, once one is off the rest will slide off... Reverse procedure for installation... Note: grease all nipple fittings, bearing and shafts to avoid seizing of bearings or bushings.
Nov 17, 2013 | Troy Bilt 25HP VTwin Hydrostatic 50" Zero...
I need the size of the poly v belt for a qualcast 4000 lawnmower.
Most time you don't have to get original parts like belts from the manufacturer. Suggest you go to a reputable lawn and tractor supply store where they can easily measure the belt and give you a comparable one for your machine. Hope this helps!
Mar 26, 2012 | Computers & Internet
Where do I buy replacement parts for my Sovereign Eurorider sit on lawnmower?
I have used one company this autumn to replace the blades, drive belt and deck. I spoke to them at length and found them very helpful. I do not wish to put the name on an open forum as the number of spares is limited, so drop me an e-mail at myownaddress2 @ yahoo. co. uk without any spaces in it and I can let you know.
May 15, 2010 | Garden
Sovereign lawnmower requires new belt
I believe the part number you are looking for is SV150. Try calling ALM Manufacturing 01423 797208 for advice and stocklist.
Sep 30, 2009 | Garden
How do you chabge the belt in the dirt devil ultra swivel?
Attached is a copy of the link for the manual. I have included the steps here, but the manual has drawings on page 10 of the manual, it will tell you how to change the belt. You will need a phillips screwdriver.
  1. Lay cleaner flat and flip cleaner to expose nozzle base. Base should lay flat end face up. To remove nozzle guard, use Phillips or Flat head screwdriver to remove the 5 screws. Arrows on diagram shows locations of screws.
  2. Lift nozzle gueard off.
  3. Be sure belt is off motor shaft. Lift and remove brushroll. Dispose of old belt.
  4. To Replace belt, Slide belt onto motorshaft
  6. With new belt in place, pull end slide brushroll into nozzle making sure that the brushroll end caps are in the correct orientation. Rotate brushroll manually to make sure belt is prperly aligned.
  8. Secure by aligning the 3 tabs in the base slots. Replace all 5 screws to secure nozzle guard.
http://www.dirtdevil.com/CustomerService/Manuals/default.aspx?id=23331
Please rate this solution
Jul 31, 2008 | Dirt Devil Vacuums
Troy Bilt 5.5hp Self Propelled Mower Logo
1,433 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
