Question about Cameras
Green pre flash light coming on and picture is blurred--how do I stop this? and revert to just the white flash
Camera being taken to Jessops to find out what has gone wrong
Posted on May 14, 2009
When taking pictures they come out blurrie i try
Turn on your flash! Even in good lighting, shoot with the flash on. This will make your exposure shorter, and there will be less opportunity for movement of the camera or the subject to blur the photo.
Nov 10, 2009 | Vivitar ViviCam 5024 Digital Camera
PT54DL50
MOST LIKELY problem is the convergence amps but.....
It might be your vertical or horizontal circuit...those initiate a 3 blink failure code too....
Dec 01, 2007 | Panasonic PT-50DL54 50" Rear Projection...
I have a pre fab wiring harness on my trailer with 6 wires: Violet/white strip, Violet/orange stripe, Yellow/green stripe, Green, Black/white stripe, Gray/orange stripe. I only need to run a flat plug (4)...
I assume you only want lights, brake lights and signals. Your best bet is to plug a wire onto your truck... the flat plug, and turn , first the left signal, on. Use a test light to see which part of the plug in is flashing. Once you have established that, just keep plugging the other end of the wire into the trailer plug, until you get the left turn signal flashing on the trailer. Then repeat the process for lights etc.
You can also take the plug-in apart on the trailer. Inside the plug in it will have l/t, r/t, s, etc. (left turn, right turn, stop, etc.) There will be a very small arrow pointing to the terminal connection that is for each.
Nov 03, 2009 | Chevrolet S 10 Cars & Trucks
Blurred pictures on fuji finepix J15fd
This is the camera shake warning, and thus the blur. It is suggesting you are using too slow of a shutter speed for the lighting conditions. The flash should be set to "auto" in order that it will automatically fire if the light is insufficient. Check your flash settings to make sure it's not set to "slow-sync" or "fill-in" settings.
Apr 06, 2009 | Cameras
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Jul 18, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Fujifine pix A330 produce blurred image on all picture taken
continuous blurred images? or only occasionally (say in low light)?
Mar 30, 2008 | Fuji FinePix A330 Digital Camera
Blurred pictures in auto mode
it is probably a camera shake problem. Consider using a tripod. Also, using higher ISO helps..Using flash helps too.
Jan 03, 2008 | Nikon Coolpix 5600 Digital Camera
Flash
you may need to try using a different flash, if you click the flash button various times you may notice that there is different flash options.
Nov 24, 2007 | Praktica SlimPix Digital Camera
BLURRED PICTURE WHEN USING MOUNTED FLASH.
If you are not using canon lenses then the low light focusing aid will not work correctly. Go into the menu and turn of the flash infra red light
Jun 10, 2007 | Canon SPEEDLITE 580EX TTL Flash
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
