Question about Kitchen Appliances - Others
Should the outside of a vintage kenmore waffle iron get hot? bought it second hand as a gift. as the waffle iron heats up it is very hot to the touch on the outside
  • 33 Answers
Yes, even the cool touch gets hot, take care to keep little hands away and not get burned
Posted on May 21, 2009
What is the best electric waffle iron to make waffles at home?
In my opinion, the best waffle irons are the vintage ones made here in the USA. They are more durable and more reliable than anything made in China today. Look up the older Sunbeam, Toastmaster, Kenmore and G.E. models and you can usually find either round, square or rectangular versions, as well as models with and without non-stick coatings. The years from late 50's to the late 70's are best.
Jul 31, 2015 | Cuisinart Kitchen Appliances - Others
How do I replace the coil on my WMB-4 waffle maker?
It's most likely not the coil that's the problem, probably a thermal fuse. Unfortunately, these Made in China waffle makers do not last and are basically disposable after a few short years. Better off replacing it with a good quality, vintage 'Made in USA' Sunbeam waffle iron. You can find good deals online on eBay and Amazon.
Feb 20, 2015 | Cuisinart WMB-4 Belgian Waffle Maker
Where do I find parts
Try any small appliance repair and parts depot.
Oct 04, 2014 | Toastmaster Vintage Mcgraw Edison Waffle...
How To clean Vintage Sunbeam CG Waffle Iron Grids?
Here is a link to the actual CG & CG-1 (12 page) owner's manual.
It will tell you how to clean it properly.
http://www.meba.com/manuals/SunbeamWaffleBaker.pdf
Jul 17, 2014 | Sunbeam Cg-1 Vtg Waffle Maker Iron...
How to use the waffler by toastmaster model# 2810R026
Directions
  1. Preheat waffle iron. Beat eggs in large bowl with hand beater until fluffy. Beat in flour, milk, vegetable oil, sugar, baking powder, salt and vanilla, just until smooth.
  2. Spray preheated waffle iron with non-stick cooking spray. Pour mix onto hot waffle iron. Waffle is usually done when it stops steaming. Cook until golden brown.
Apr 16, 2014 | Toastmaster Kitchen Appliances - Others
Need the manual and recipe
Here's a manual for my W252, which is similar to your model.
Feb 14, 2014 | Toastmaster 442A Vintage Waffle Iron
Plug gets hot on my vintage sunbeam CG waffle maker
You can replace the power cord on these models easy enough, as the cord is actually attached to a small black, plastic box that can be opened to replace the cord. You can find cords at home improvement or hardware stores. Before going this route, make sure the wall outlet you are plugging the waffle iron into, is properly grounded. You can check this by using a small outlet testing tool that lights up green or orange if installed properly or improperly. It also checks for reverse polarity, in addition to bad ground.
Jan 13, 2013 | Sunbeam Cg-1 Vtg Waffle Maker Iron...
Waffle iron light goes on gut does not heat up
The most common reason for not heating up is because of a blown thermal fuse. Apparently the controller lets the iron get too hot or the fuse is out of manufacturing tolerance - and so the fuse opens.
The green lamp is normally lit when the relay is off and dark when the relay is on. When cold, the relay normally turns on within a second of power-up (switched on). During power-up, the green (ready) lamp should flicker on, and then as the relay clicks, go dark. If the green (ready) lamp does not flicker, the fuse is probably blown.
The fuse is clamped inside the bottom clamshell in silicon tubing. A replacement fuse (240°C) can be purchased from many sources. The fuse should be re-attached to the wires with new all-metal crimp fasteners.
If the iron is getting too hot and blowing thermal fuses, you may be able to avoid this failure by keeping the thermostat set lower. (Turned a bit counter-clockwise.) If the waffles are no longer dark enough at the ready beep, you may have to use manual override by watching the steam and smelling the waffle.
May 19, 2010 | Waring WMK300 Professional Belgian Waffle...
Tried to make waffles for the first time. They consistently burned in the middle. Added milk to the batter. Still burned in the middle, barely cooked on the outside.
Sounds like you might not have let it warm up enough. These usually heat from the inside out. So they heat up and then take a few minutes for the emtire surface to be hot.
Turn it on and let it heat up while you make your mix up. Or a good 10 minutes. Give it a spray of pam or equivilent on both sides if you want and then make some waffles. If you want to experiment a bit try dropping a drop of water on the middle and outside. When they boil or his about the same your are hot enough.
Mar 23, 2010 | Kitchen Appliances - Others
Nordic ware Belgiam Waffler maker
This is how I use the nordic ware...
1.Heat pan on medium heat on one side until temp gauge is in the middle. Dont turn pan at all when pre-heating
2. Open pan and coat bottom with a little butter.
3. Flip pan over and add butter to bottom side that has no butter.
4. Add batter quickly so butter doent burn. Add semi-thick batter in pan and only let batter run so there is about 1 inch of space left on the edge.(This space will fill with batter when you close the cover)
5. Temperature gauge should stay near the middle at all times.
6. Do not open the pan to check the batter waffle color or your crispy waffle will turn soft
7. Let waffle cook on first side until the steam that comes out from the side slows down to about half of the amount of steam that came out when battle was first put in. (Should be about 2 minutes)
8. Turn waffle pan over and DON’T open the pan.(you haven’t opened the pan once to look)
9. Let cook until steam reduces (Takes about 2 minutes)
10. Keep an eye on the temp gauge
11.Remember the first waffle always takes longer to cook than the second and third waffle.
12. If you have the urge to open the pan. Open the cover slowly. If it doesn’t open up easily then it is still rare and wait one minute to open. If you need to look, you should only open the pan after you turned it over. Once you open the pan, leave it open. If you close it the cripy top will turn soft.
13. Remember trial and error
Mar 16, 2008 | Nordic Ware 15040 Belgian Waffle Maker
Kitchen Appliances - Others Logo
235 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
