Question about Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7
How do you change a pump seal on a hayward 1hp pool pump
  • joe_moncada May 13, 2009
    i've taken it apart but can't stop shaft from turning
  • 78 Answers
The seal is located behind the impeller. Once you remove the impeller it is fairly obvious how to replace it. Basically, unscrew everything, replace it and put it back together again. There is a decent diagram on page 11 of the Hayward owners manual found here if you need it. http://www.haywardnet.com/products/Manuals/pdfs/Manual113.pdf
Posted on Apr 22, 2010
I replaced emerson 1hp pump to my hayward max pump and leaks any ideas all seals replaced
Hi, this is John the Hayward tech. Sounds like the mechanical seal is leaking. If you replace the spring loaded seal the problem could be that it was installed backwards. It is ceramic against carbon. if installed the other way it will leak. Any debris or oils getting on the seal will also cause it to fail Running pump without any water will heat up the seal and cause it to fail.
Jul 21, 2014 | Hayward Pool & Spa
My Hayward 1 hp super pump will run for a second and then trip the gfci. What has happened? Thanks.
Normally the GFCI is doing its job.
Water is getting into the internal of the motor.
Try replacing your Shaft Seal
Jul 31, 2012 | Hayward 1HP Super Pump II Inground Pool...
How to replace seal on hayward power flo matrix?
if seals leaking ruining bearings next to go replace whole unit
Jul 21, 2012 | Hayward 1hp Power Flo Matrix Above Ground...
Will a smith 1hp pump fit in place of a hayward 1hp
as long as the frame size matches i.e. 56J in this case then you should have NO issue with changing the motor mfg.
US Parts Center
Aug 18, 2011 | Hayward 2HP Pool Pump Motor A O Smith...
How do I take my hayward Power Flo Matrix pump apart to replace the shaft seal?
The instructions are in your owner's manual, which you can also find on Google. No specialty tools are required.
Aug 04, 2011 | Hayward 1hp Power Flo Matrix Above Ground...
Hayward 1HP for in-ground pool: When I shut the pump off sometimes DE backflows from the filter through the pump and into the pool and accumulates on the bottom. The pump is about 10 years old and it just...
Usually caused by a small air leak somewhere on the pressure side of the system. A check valve on the line coming out of the pump going to the filter will solve problem.
May 05, 2010 | Hayward 1HP Super Pump II Inground Pool...
Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7 Logo
328 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
