Question about Avid Code Hydraulic Disc Brake
Hi I have a harley davidson mountain bike from a friend for a gift!I need a replacement caliper for the front and back?
    Brigadier General:
  • 5,158 Answers
Lots of online sites ... here's one
http://www.munising.com/genuine.html
you may also just want to grab a phone book for your area and see if there is a harley dealer nearby.
Robert
Posted on May 13, 2009
Torque specs for rear brake caliper on 2001 harley davidson dyna wide glide
Hi, Karla 5/16"-20ft. lbs. 3/8"-35ft. lbs. for this scenario you will need your service/owners manual if you can not find the first and best tool you ever bought for your Harley, despair not, for a mere $9 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
How to Replace Install Inspect Brake Pads on Harley Davidson Guide...
Harley Davidson DYNA Models Workshop Service Repair Manual 2001 $9 cheap
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
http://www.harley-davidson.com/content/h-d/en_US/home/owners/maintain-your-bike/owners-manual.html
Instant Tech Relief To speak with me personally absolutely "FREE"
Apr 21, 2017 | 2001 Harley Davidson FXDWG Dyna Wide Glide
Just replaced rear shocks on 96 1200 sporty. Took for test ride and found that the front caliper appears frozen. The bike was moved earlier with no problem of moving.
Hi, Tony it happens probably need to rebuild the master cylinder and caliper for this scenario you will need your service/owners manual if you can not find the first and best tool you ever bought for your Harley, despair not, for a mere zero $0 you can download another one.
Harley front brake caliper rebuild
HARLEY DAVIDSON FT MASTER CYLENDER REBUILD KIT INSTALL
https://www.carlsalter.com/pdfs/Harley%20Davidson%20%20Sportster%201986-2003%20Service%20Manual.pdf
Apr 13, 2017 | 2000 Harley Davidson XL 1200 S Sportster...
Wrench size front brake calipers
Hi Anonymous, you are better off using 12 point sockets, if you are going to work on your own bike you have to have basic hand tools. The first and very best tool you will ever buy for your motorcycle should be a factory service manual. It will pay for itself the very first time you use it. Visit the websites below to help you get started: Harley Davidson Manuals Mark Workshop How to Install Brake Pads on Harley Davidson Road Glide by Cycles
Good luck
Apr 06, 2014 | 2005 Harley Davidson FXDXI Dyna Super...
Unstick front brake 2000 fxd
Hi Anonymous, loosen caliper halves and unbolt it from fork leg. Spin front wheel to see if rotor is warped or put a straight edge across it. Maximum total runout is .008" any more than that replace rotor. Check master cylinder for piston not returning all the way
(no gieser shot) then inspect caliper for contaminated pistons and bores. your going to need a service manual, download one at the website below for only $6.50. Good luck:
Jan 22, 2014 | Harley Davidson Motorcycles
Rear brake caliper
Hi Anonymous, not really for more information about your question please visit the website below. Good luck and have nice day.
Jun 20, 2013 | 2010 Harley Davidson FLSTF Softail Fat Boy
Neenchanging front and rear brakes on my 06 dyna custom
To change the brake pads on your bike, either front or rear, you must take the calipers off. They are held on by two bolts. Take the bolts out and take the caliper off. Replace the brake pads like the old ones came out. Then you must compress the pistons back into the caliper. I use either a large C-clamp or a large pair of slip joint pliers. Protect the paint on the calipers with rags or wood. Press the pistons all the way back into their bores on the calipers. Replace the calipers and work the brakes until you get a good firm brake. Make sure you do this job correctly as failure of the brakes can result in serious injury or death.
Good Luck
steve
Apr 24, 2011 | 2006 Harley Davidson FXDCI Dyna Super...
What is involved in changing front brake pads on an 08 Streetglide
I haven't done a brake job on a bike this new but it shouldn't be any different than any other bike. Simply take the two bolts that hold the caliper on out. Remove the old shoes. Use either a large C-clamp or a large pair of slip joint pliers and squeeze the piston back into the caliper all the way. Install the new pads and put the caliper back in place. Replace the two bolts and torque them to 25 Foot pounds. Squeeze the brake lever until you have a good firm brake.
Good Luck
Steve
Apr 02, 2011 | 2008 Harley Davidson FLHX Street Glide
How do I change the front and rear brakes on a 2006 Harley-Davidson Electra Glide Ultra Classic Injected - FLHTCU I
Not too hard - Undo the two bolts on the caliper and then seperate the caliper and pull the old ones out. Insert the new ones and put the bolts back in to hold the caliper back together and then install them back on the bike with the two retaining bolts. Use a bit of lock tight (Blue) on the threads. Warning do not let anyone apply pressure on the brakes while you have them off the bike or you will have a mess and/or a problem.
Jun 18, 2009 | 2004 Harley Davidson FLHT - FLHTI Electra...
2000 Fatboy throwing a 417 code.
Greetings!
Time to arm yourself with some coffee and donuts and make friends with the mechanics at your local Harley-Davidson dealer...
So sorry, but electrical system diagnostics for Harley is proprietary. They will be your best source for a solution, and having the bike will definately be an asset to the mechanic working on it to correct your problem.
Cheers, Jay
Apr 22, 2009 | 2000 Harley Davidson FLSTF Fat boy
Avid Code Hydraulic Disc Brake Logo
75 people viewed this question
Top Avid Cycling Experts
Christian Samuelsen
Christian Samuelsen
Level 1 Expert
John Egan
John Egan
Are you an Avid Cycling Expert? Answer questions, earn points and help others
