Question about Maytag MAT12CS Top Load Washer
By pass coin mech for a maytag washer mah21pddww
I want to take out the coin mechs and am looking for a wiring diagram to see how to by pass the wires.
    Problem Solver:
  • 5 Answers
All you have to do is program the machine to run with no coins Open the service hatch and use the woolens key to scroll through to the setting which is your multiplier setting it may be set to 610 for example you need to set it to 600. While viewing this number use the permanent press keypad to change this setting each press changes it by one increment keep pressing it until it goes back around to 600 Then close your service hatch and the machine will be set to work for free you only have to select which program you want to start.
Hope this Helps
Posted on Jun 17, 2009
What is the wiring diagram for winch remote
Ramsey website shows Badger wiring diagram for solenoid hookup etc but not plug. Shouldn't take a good DIY mech or auto electrician too long to work out which wire goes where especially if they loosen the socket it plugs into which should reveal which wires go to where on the solenoid block. Basically that's all they do, there's a supply side, a ground wire and all the hand control does is switch the supply to the solenoid for forward and reverse. From memory there's only 4 wires? Supply to hand control,1 wire to one sol, 1 wire to other sol, 1 ground wire. Supply could be red, ground is usually black, fwd / rev will be 2 other colours. Look at the socket to see match up?
Jul 20, 2014 | 115101: Ramsey Badger Series Winches
Hello, i had a Tune Up from Hell,#1 Mech.installed NewAutolite plugs," Standard " Brand wires,PVC Valve,Fuel filter on pass.side, Timed car, Results;hesitation, stutter type acceleration, hell i thought my...
black smoke equals too rich a fuel mixture. check the engine vacuum at idle should be 20 inches of mercury if not check for stopped up catalytic converter. are there any check engine lights
Sep 27, 2013 | 1986 Lincoln Town Car
Just replaced plugs and wires on a 95 chevy camaro v6 now has no power
Sounds like you may crossed up some plug wires? use the diagram below to check this out as the poss problem. Match the numbers on the coil pack to the cylinder numbers. Cross wiring plug wires is the most common thing that home mechs do that they get wrong.
Feb 16, 2012 | 1995 Chevrolet Camaro
I bought a Kramer Krane 20000, the coin door missing, when turned on claw closes and claw assembly returns to the home posistion. Problem, coin door was missing and all wires loose, What color wiresgo to...
There is a machine like yours in the warehouse I've been fixing crane games for someone in, I can look if you're still stuck. I could take a picture with a digital camera as well if I had somewhere to send it. The "kramer krane" there is a mess, it looks like someone made it in a middle school wood shop, has ground issues, etc. This one has been "upgraded" to a play til u win candy crane, but I'm pretty sure it has the original harness, you can e mail this same username at yahoo if you still need. The coin mech wires may not have voltage under normal conditions. Some are just a normally open logic board which is triggered by change in resistance, some get 5v, etc. I can also meter that for you (again, if you are still stuck & u reply!)
Feb 21, 2011 | Video Game Consoles & Games
The coin mechanism is hard to push the coin slider, but it works.
Coin mech is held in place with 4 screw heads in key hole slots.
Move the mechinisim UPWARDS about 3mm and wiggle it around to disengage the screws.
The hex bar is only used to stop the mech going upwards.
Sep 12, 2009 | Whirlpool CAM2752RQ Coin Operated...
2007 flhx.
The GY/BK wires from the 04 passing lamps plug into a two hole connector from the main harness. the GY/BK wires from that connector become one GY/BK wire that goes to the passing lamp switch. The other wire from the passing lamp switch is Yellow and is spliced in to the Yellow wire that goes to the headlamp bulb. This is not a diagram, but it is pretty simple layout. Hope this helps.
Jul 26, 2009 | 2008 Harley Davidson FLHX Street Glide
Dont know wich wires go to wich prongs on ignition
You can get a wiring diagram by going to a web site for OMC Motors
Jim OMC Retired Mech
Jul 03, 2009 | Boating
I need a wiring diagram for a 1990 heritage 1600 starcraft boat it needs to be rewired
wiring diagram for a 1990 heritage 1600 starcraft boat type this in and do a web search. Is the wiring for the boat are for the motor? Jim Retired OMC Mech
Jul 01, 2009 | Boating
2 channel amp to 6-6x9 wiring diagram
Hello magoocsl,
Yes, with the use of 2 high-pass and 1 low-pass crossovers, that Kicker amp will operate in what they call stereo and mono simultaneously (SAMS). You'd run 4 of the 6X9's in mono. Wire them in series-parallel with a low-pass crossover on the positive leg to the amp. The amp would see a 4ω load. The other two 6X9's would be wired as stereo, one to each channel with a high-pass crossover. Again, the amp sees a 4ω load.
Here's a link to the appropriate wiring diagram. The diagram is on page 5. Just substitute your 4 6X9's wired in series-parallel where they show the "mono" speaker.
http://www.kicker.com/sites/default/files/02KX300_400_500_800_2AmpManual.pdf
Hope this helps.
Apr 01, 2009 | Kicker KX500.2 Car Audio Amplifier
Space Invaders
Awesome find John!
Ok everything else works except it won't coin up?
Open the coin door and look inside, there should be a microswitch under the coin mech, with two wires running to it. Those are what sends the signal to coin up the game. Make sure the wires are connected to the switch properly. There should be three pins on the switch: a common, a normally open, and a normally closed. One wire goes to common and one goes to normally open.
If you look further into the cabinet there should be a Menu and a Service button. Work your way through the Menu with a little trial and error and you can put the cabinet on Free Play, so you don't have to worry about coining it up.
If its even older than what I think you might have to adjust the freeplay settings with dipswitches and that is a whole different story.
-Let me know!
-Captain Jake
Jan 16, 2009 | Video Game Consoles & Games
Maytag MAT12CS Top Load Washer Logo
1,137 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
