Blue screen of death - Computers & Internet
  • pin_0018
    pin_0018 May 11, 2010
    Please give the Error Code which u get on the Screen.
  • Barbat Nae
    Barbat Nae May 11, 2010
    Also known as the BSoD, the Blue Screen of Death appears when Windows crashes or locks up. It’s actually a Windows “stop” screen, and is designed to do two things: tell you the reason for the error, and to calm your nerves, hence the use of the color blue (studies show it has a relaxing effect on people). Though Blue Screens are difficult to decipher, all the information you need to figure out what caused it is right there in front of you in blue and white—and that’s where we come in. We’re going to show you how to dissect the blue screen error details, so you can fix the problem that’s causing them.
    Error Name
    There are many parts to a BSOD, but the most important is right at the top. The actual name of the error is presented in all caps with an underscore between each word. In some cases this will be all that’s needed to get to the root of the problem (thanks to the handy guide you are about to read). Most of the time, however, more information will be required.
    Troubleshooting Advice
    Nearly every BSOD includes a portion of text with some basic troubleshooting advice, the first of which recommends restarting your computer. Gee, thanks for the tip Microsoft. Before you restart, copy the exact all-caps error code and hexadecimal values shown above and below this portion of generic text. The next paragraph provides sound advice, alerting the user to check to make sure their hardware is installed properly, or to undo any recent software or hardware upgrades.
    Memory Dump
    Every BSOD is accompanied by a memory dump. What this means is when Windows crashes, it dumps whatever it is holding in system memory to a file, and saves the file on your hard drive for debugging purposes. If you contact Microsoft for technical assistance, they’ll want to know the contents of this file.
    Stop Code
    The “technical information” section portion contains the actual Windows stop code, in oh-so-easy-to-read hexadecimal form. Despite appearing unintelligible at first glance, this combination of numbers and letters is instrumental in determining the cause of the crash. Pay particular attention to the first set of numbers and letters. It precedes the other four, which are enclosed in parenthesis. If a specific driver is associated with the crash, it will be listed on the very next line.
    I Run Vista, so I'm Immune to BSODs, Right?
    Unfortunately, no. A common misconception is that blue screens don't even exist in Vista, but not only are they still there, but we're here to tell you we've seen them first hand. The good news is Microsoft put a lot of work into how Vista handles critical errors and other glitches that in previous OSes would cause a system crash. Most of the time, if a problem occurs, Vista will attempt to fix the problem without any interruption. For example, if your videocard crashes, you may see a messge saying "Display driver stopped responding and has recovered." In XP and previous OSes, this almost always would have resulted in a system crash.
    In some cases, Vista will be unable recover on its own, and the result is a blue screen. By default, Vista will reboot itself after briefly flashing the blue screen. It happens so fast you might miss it, but once Windows reloads, you'll be greeted with an error message similar to the above. You can try clicking the 'Check for solution' button, just as you can try your hand playing the lotto. Neither one is likely to result in anything.
    Instead, scroll down and take note of the blue screen codes. Armed with this information, you can perform your own detective work. Alternately, if you'd prefer to see the actual blue screen rather than automatically rebooting, right-click the My Computer icon on your desktop, select Properties, and click on Advanced System Settings. In the System Properties window that appears, select the Advanced tab, click Settings under Startup and Recovery, and uncheck the box that says 'Automatically Restart.' The same steps also apply to XP.
    In another nod towards streamlining the troubleshooting process, Vista's Problem Reports and Solutions wizard can save you oodles of time in PC detective work, and may even alert you to potential conflicts you weren't even aware existed. You can find this applet by name in your Control Panel, or just type Problem Reports and Solutions in Vista's search box. Once loaded, click 'Check for new solutions' in the left-hand column. If Vista finds any conflicts, it will list them in the main window, along with any potential resolutions.
    IRQL_NOT_LESS_OR_EQUAL (0x0000000A)
    The most common cause of this conflict is improperly installed drivers for a piece of hardware you recently installed. For example, if you’ve installed a webcam two weeks ago, and have been getting BSoDs ever since, start your investigation with the webcam. First, disconnect the hardware, and uninstall the drivers for it completely. If that fixes the blue screen, you can search for updated drivers or contact the manufacturer.
    If you haven't installed any new drivers recently, you'll need to do some more detective work. Start by examining the blue screen to see if it lists a specific driver. Looking at the blue screen, check the text at the very bottom of the screen. You'll probably see a file name. This is the driver that caused the problem. If, for example, the driver in question is named nv4_disp.dll (an nVidia-related file), and you've recently switched from an Nvidia videocard to an ATI part, then it's reasonable to assume that either the old driver was not uninstalled correctly, or the new drivers weren't properly installed.
    Swapping Videocards
    If you've narrowed your search of offending drivers down to those associated with your videocard, turn off the system, disconnect the power, and remove and reseat the videocard. Next, go into the BIOS (press F2 or Delete when your BIOS prompts you to do this, or consult your user manual or motherboard manufacturer's website) and check the bus speed for your videocard. We typically recommend leaving the PCI-E frequency set to Auto in the BIOS, but if you've overclocked your system, it can inadvertently knock the bus speed beyond a stable spec, which can cause blue screens. If that's the case, manually set your PCI-E frequency to 100MHz.
    You're more like to experience this IRQL error when switching form one videocard brand to another, as the drivers will conflict with each other. The safe way to swap videocards is to completely remove all remnants of your old videocard drivers using a utility called Driver Cleaner, or the freebie alternative Driver Sweeper. To begin the process, open up your Control Panel, select Add or Remove Programs in XP or Programs and Features in Vista, highlight the videocard drivers, and click Uninstall. Reboot the computer, holding down the F8 key to enter safe mode. Run the Driver Cleaner utility to scrub away any remnants of the previous drivers that a typical uninstall overlooks. After you reboot, install the appropriate drivers for your new videocard.
    Some Sound Advice
    When the error is related to an audio driver, take note of the program that was running when the BSoD occurred. Make sure the offending application's sound options are configured correctly -- it's especially important that it uses the correct audio device -- and download any patches available that address known issues. You should update your soundcard's drivers as well.
    If you're using an add-in soundcard, verify that the motherboard's onboard audio is disabled in the BIOS, so the two audio drivers don't conflict with each other.
    Change Doctors
    System services known to cause this error include virus scanners and backup utilities. We've had good luck sticking with the major players, such as AVG, Norton, Kaspersky, AntiVir, and Nod32 for our antivirus scanning, and Norton Ghost and Acronis TrueImage for backup duties. Do not run more than one antivirus application on your computer at the same time!
    President:
  • 1,996 Answers
See links here and here and here, for info and stop error code diagnosis.
Posted on May 13, 2009
Computers & Internet Logo
497 people viewed this question
David Payne
David Payne
