Question about GE GTS22KBP Top Freezer Refrigerator
Everytime I plug in the power cord, it trips the breaker.
Everytime I plug in the power cord, it trips the outlet breaker. I have a 20 amp breaker in the fuse box and a 20 amp GFI outlet. Just last week, the fridge was fine at my grandmothers house. Not sure of the exact model #.
  • Robert Moller
    Robert Moller May 11, 2010
    It is tripping the breaker and not the GFCI ?
  • GE Master
  • 3,361 Answers
Refrigerators are not designed to run on a GFCI. Try a heavy duty extension cord to the fridge from a outlet that is not GFCI protected. If it still trips you probably have a short circuit in the compressor.
Posted on May 13, 2009
Bought a used air compressor with no owners manual. Just read that you should never use an extra long extension cord. Could doing this cause the motor to struggle and the unit to shut down?
If it is a 120V compressor, they draw about 20 amps when running. It takes a clean 120v plug and a 20 amp circuit breaker and dedicated outlet to operate them. Make sure the plug copper contacts are clean and bright and the receptacle also. It also takes a very heavy extension cord to operate them on a extension (and is not recommended), use a longer pressure hose instead.
Sep 21, 2014 | Dryers
No lights upstaires circuit breaker keeps tripping
Jan 2013
1) Move wire to another same-size circuit breaker to eliminate bad circuit breaker as suspect.
Do NOT increase size of breaker or it will cause fire.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
http://waterheatertimer.org/Troubleshoot-household-electricity.html
2) Put hand on each appliance and outlet to see which ones are warm. Outlet should never be warm or hot. Replace outlet. Inspect wires for loose and burned connections.
3) If the breaker is good, then add up total watts being used by checking watt rating on each device. 100 watt light bulb is 100 watts. Big screen TV has a label that shows 300 to 500 watts. Computer has label. Space heater has label showing 1500 watts. Iron has a watt rating label. Take total watts and divide by 110Volts and this will give amp load. Total watts used = 2000 and then divide 2000 by 110 volts = 18.8 amps
Compare amp load with circuit breaker.
20 amp circuit breaker has 80% safe maximum, or 16 amps.
If amp load is 18.8 amps, then 20 amp breaker is starting to get hot, and weak breaker will start tripping.
If amp load is 18.8 amps, and breaker is 15 amps, then you are overloaded and breaker is feeling the heat, and tripping because of heat.
Solution is to reduce amp load.
4) If you have short circuit, that can also trip breaker.
Unplug everything and then plug things back in slowly to see which plug or appliance is causing the problem.
Jan 18, 2013 | Electrical Supplies
My amana gas range just tripped the breaker and now the oven light will not turn off and it keeps tripping the breaker every couple tries. It is running of a 20 amp breaker so it should be getting enough...
One possibility is that the circuit breaker has weakened and tripping intermentently for no real reason. To see if that is the case the oven could be plugged into a outlet on a different breaker using a extension cord.
Another potential cause is that any one of the wires in the range has became bare and lost its insulation and touching a peice of metal, shorting out
Good luck in figuring out what is wrong,
Gene
Aug 05, 2011 | Amana Kitchen Ranges
WASHER TURNS ON FOR COUPLE OF SECONDS THEN TRIPS BREAKER.PROBLEM WITH MOTOR ???.
Is it tripping the breaker on your home's electrical panel? If this is the case, you need to know what that breaker is also feeding, how much amperage it can handle, and what the load demand is. Your washer needs 1700W which is around 15 Amps. If you're on a 15 Amp breaker that is already supplying power to something else, such as incandescent light bulbs, then you're going to trip the breaker each and every time. You'll want to plug it into a 20 Amp circuit that's being used by little to no other electrical devices. A quick alternative is to unplug or power off all other devices before using the washer... or plug it into the same outlet that you use your blow dryer.
Jul 18, 2011 | Black & Decker 1700 PSI Electric Pressure...
The socket next to my washer was used to put in an extension cord to fix my deck with a power saw. The socket is still out, but the breaker works for then lights there.
Usually the washer circuit is a seperate 20A circuit. The lights would be on a different circuit usually 15A. Check your panel and see if there is a 20 breaker tripped. Hopefully your panel is labeled (or it should be) Are you saying this tripped while using the extension cord? Another possibility is that it is controlled by a GFCI outlet. You can connect additional receptacles to a GFCI outlet to protect them. Check to see if you have a GFCI receptacle tripped (in garage, bathrrom etc)
Sep 11, 2010 | Gb Electrical 1 30 Amp Ground Fault...
Pushmatic breaker keeps tripping everytime I hit
You have it shorted out somewhere along the line. If it is a light switch you are switching, what have you done lately to make this trip? Anything? You might have a bad breaker. You can check it by shutting off the power, pull the wire out of the tripping breaker, put it in another breaker, turn the power back on, switch the breaker on, then hit the switch and see what happens. If it snaps off, it is not the breaker, but the switch, the wires in the box, or the lights, or something along the line, you will have to check each one. New construction has made all lights and all receptacles separate, so if your house is old, you might be looking at receptacles too. Check anything plugged in to an outlet, make sure there is nothing shorting. Hope this helps.
Apr 03, 2010 | RTO Pushmatic 100Amp 2-pole circuit...
No power to fridge. power to house ok, circuit breaker to fridge not tripped. what to do?
plug something else into outlet and see if it works your outlet/ wiring maybe bad if it works your power cord for fridge maybe bad have a short in it if outlet or cord is bad call eletrictian
Jul 07, 2009 | Sub-Zero Refrigerators
GFI on cord trips out.
Probable cause is a single pole gfi opposed to a double pole gfi.
* Do not use a single pole GFCI ON A MULTI WIRE CIRCUIT, IT WILL NUISANCE TRIP IMMEDIATELY
Use a two pole GFCI circuit breaker on such circuits.
May 20, 2009 | LG LWHD1800R Wall/Window Air Conditioner
Keeps tripping circuit breaker everytime on plug the power cord in
2 common, possible problems. 1 - there is a "short" in the plug - easy fix - replace either the cord or plug - not expensive. 2 - bad control board - not so easy, not so cheap. Is it brand new, used? Also, it could be a bad "internal breaker" - not easy!
Apr 24, 2009 | Maytag MGR6875BK Gas Kitchen Range
It keeps tripping the breakers or the GFI outlet.
try different outlets in another room to see if that dosent help you may have a shortin the cleaner but i think you may be overloading the breaker
Jan 17, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
GE GTS22KBP Top Freezer Refrigerator Logo
1,144 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
