Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My usb is not become format - Kingston (DTIU3/2GB) 2 GB USB Hard Drive
  • Roberta Smith
    Roberta Smith May 11, 2010
    what exactly do you mean ?
Insert it in a usb port, let the computer find it, go to it and right click on it and choose format. it WILL erase any/all data on it currently...
Posted on May 13, 2009
I have a mini usb stick that seems to have become read only,
No sorry but that is it, you have a defective flash stick.
Feb 09, 2017 | The Computers & Internet
My hitachi TV does not recognise my USB device
Usually because it is not formatted to the right size. I.e. Has it been fat 32 or 16 and the the blocks set to correct size.best way is to save all data onto computer.then put card into tv and see if you can format it there then retransfer what you saved off the computer back to it.best utility is free it is called hp usb utilitity which will format varying formats and block size if you tv won't .even when they become unreadable.
Sep 07, 2014 | Computers & Internet
Why should u format a usb
Typically USB cards and flash drives arrive with default formats.
The user should not have to format them before use.
However like any storage format it can become corrupt.
Be it virus or read write fault. Also different formats provide better storage space but limit access to some devices/programs.
Hope this helps.
Mar 03, 2014 | PNY Electronics - Others
My pen drive not formating
Is your pen drive detecting while connecting to system then use the below process
  • To format a USB stick to FAT with Windows, follow these instructions:
  • Open the Control Panel,
  • Select Administrative Tools, then go to Computer Management,
  • Select Disk Management,
  • Right click on the drive letter corresponding to the USB drive and select Format,
  • If the key has a capacity of more than 2 GB, choose FAT32.
  • Confirm with OK.
  • To format a USB flash drive to NTFS, follow these steps:
  • Put the key into the USB port and wait for it to be recognized as a mass medium.
  • Go to Start/My Computer.
  • The USB key is visible in Devices with Removable Storage.
  • Right click on the key, then go to Properties/Hardware.
  • Double click on the USB drive icon.
  • Go to the Policies tab and select Optimise for performance.
  • Click on OK.
  • Go back to My Computer.
  • Right click on the USB drive and then choose Format.
  • Choosing NTFS has become possible, in addition to FAT option.
  • Feb 24, 2013 | SanDisk 16Gb USB Flash Drive
    Kingston Data Traveler 2.0 64 GB USB - file system corrupted - need to work on windows XP- Upon formatting the pen drive It shows that it has become a raw drive - wat is the file format for the USB to work...
    Theoretically, you can't format a more than 32 GB drive with FAT/FAT32 file system. In your case you have to choose the NTFS file system to format your 64 GB USB flash drive. However, if you really need to format it with FAT32, you got to use the command line or a third party tool. Hope this is going to help you.
    Apr 06, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
    I have TRANSCEND JETFLASH V10 (TS8GJFV10) 8GB USB 2.0.i when try to format the capacity of usb become 1.8GB, why...? Could you help me. Do you have software for reinstall to usb so the capacity become...
    The device is working correctly.
    The '2GB' means 2 times 1000 times 1000 times 1000.
    The '1.8GB' means 1.8 times 1024 times 1024 times 1024.
    It's the same number, only expressed differently.
    Nov 18, 2010 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
    Computer doesn't seem to recognise LG KU990i via usb
    first check ur usb port that is it ok? sometimes some usb has problem when it become old. then check ur usb cable is that ok? if everything are ok then format ur pc and install usb 2 software for ur usb system. thanks
    Aug 08, 2009 | LG KU990 Viewty
    Not able to format 32gb kingston usb pen drive
    go to start>
    run>
    type cmd
    ms- dos window appears
    if your drive is g: then type following codes on dos
    format g:
    y
    either your drive is f: then
    type
    format f:
    y
    donot forget to rate if it becomes formatted
    by Nischal nisc
    if you are using vista then
    go to my computer right click on my computer
    manage>
    then you can format by entering device manager
    Mar 29, 2009 | Electronics - Others
    My usb flashdisk become raw data
    1). Do not format this hard drive before you've recovered all your stored data back. In your case, the formatting process may erase everything on your drive and make your data gone permanently.
    2). Never save anything new on this drive in case that any new file would rewrite your original data.
    3). Plunge this drive to your computer and download a RAW drive data recovery freeware to get back all your lost data back:
    http://www.freeware-fix.blogspot.com/2013/02/raw-hard-drive-recovery.html
    This hard drive has helped many people around me restore their inaccessible data back from a RAW drive or memory card. It can also work perfectly on your drive.
    Read more detailed information of this freeware here:
    http://blog4mark.blogspot.com/2012/10/help-external-drive-became-raw.html
    4). Save and back up all your restored data on another drive in case of data recovery failure.
    5). Format this drive to see whether it is fixable.
    Dec 16, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
    Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
    61 people viewed this question
    Top Kingston Computers & Internet Experts
    Cleverer2
    Computer Links
    Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
