Question about Compaq Presario 2190US Notebook
Replace hard drive on Compaq presario 2190US
I have a presario, 2190US. It hangs at the red compaq logo...allows to push f2 to enter setup but just says entering setup and nothing happens.  Tried booting windows and live disks from cd-rom but nothing happens (stays at compaq screen). Since i can't get into setup or boot from cd i cant do a hard drive self test.  The hard drive is making a ticking noise like a second hand on a watch...i'm assuming bad hard drive (any opinions...only thing other than that its a bad mobo) and would like to try replacing.   Can i replace with just any ATA hard drive...does it have to be same size to avoid bios problems etc...
  • 1 more comment
  • c-dub Oct 15, 2007
    Paeroa, thank you for your suggestion.
    The Presario 2190US I  have has Ubuntu installed as the main OS...I just put in the Windows disc (as well as the Ubuntu installation disc) in to see if it would even boot from that since it had XP originally installed, but as i said it will NOT boot from the cd-rom drive this includes live discs like Knoppix, as well as the hard drive self test burned as an iso on a cd-rw.
    Also...i can not enter the bios setup as i mentioned before when i hit f2 to enter setup it says entering set up but stays at the compaq screen and nothing happens.
    The other options are hitting esc to change boot order. If i remember correctly, normally a screen should pop-up showing the current boot order, but when i hit esc it immediately takes me to the Pheonix bios screen showing the memory test, etc but nothing happens, just stays there.
    The other option is f12 to boot from LAN (which won't really get me anywhere) but when i hit it says booting from LAN and just sits at compaq screen just as when i hit f2.
    the cd-rom shows the activity light blinking but nothing ever loads...it worked perfectly fine before this mishap.
  • c-dub Oct 27, 2007
    iowatoad--thanks for the suggestion.  Yes, i was then able to access the bios with out the hard drive in place.  Unfortunately after putting it back in after changing the boot order ..it still is hanging at the compaq screen and can't do a hard drive self test or read a cd.  If i put a cd in with out the hard drive in i just get an "operating system not found"  and doesn't go any further.
    If the bios can start with out the hard drive in , does this signify a bad hard drive?? or is this a software issue as Paeroa suggests??
    If its the hard drive to i need to replace with an ATA same make, model, and size to avoid bios issues etc??
    Thanks again.
    Problem Solver:
I tried "tapping" the harddrive, i am still getting the same thing :( also...did you notice it said the system BIOS is shadowed?? what does that mean? anyone?
this really makes me sick this laptop is doing this.
Posted on Sep 22, 2008
Summary: remove hard drive, tap it, re-install. Fixed!
I had the same issue with my compaq presario 2100. Stuck at compaq logo screen. Could not enter setup.
iowatoad's solution helped me realize it was a hard drive problem.
I then removed the hard drive and rebooted. I could now enter setup, so that confirmed the problem was the drive.
I then just tapped (quite firmly) the hard drive, and re-installed it, rebooted. And now it boots perfectly!
Tapping a hard drive is a known technique to (at least temporarily) resurrect hard drives. I've resurrected my ipod like this two years ago, and it still works! It is of course not a great sign for the health of the drive, so you best backup your data as soon as possible. But then again, your drive might be back in business for quite a while.
Hope this helps others out there.
Posted on Jul 13, 2008
I have a 2190 with the exact same problem. I have now found that it is the hard drive. The hard drive should spin with random clicking, not that clock-like clicking. The hard drive is located in the front edge of the unit looking like a drive door. Remove the two rubber plugs and two screws. Pull the "drawer" sharply to toward you to unplug the drive. Then try to boot the computer without the hard drive installed. The computer will now let you enter the bios, etc. Weird, huh?
Posted on Oct 25, 2007
    Sergeant:
  • 457 Answers
NO its a software crash use the installation disk you said you used......go through the blue screen allowing windows to boot up from that disc let it go right to the end and press "R" for the console (the dos line ) when there enter ....     chkdsk /p
Let Windows fix any problems. When finished remove the disc and I bet it will open windows for you.  Please come back and tell me how did you do because most people that I helped with this problem just run but you know old saying "what goes around comes around"
Posted on Oct 15, 2007
  • Peter Hirawani
    Peter Hirawani Oct 15, 2007
    You might want to also try an get into the setup of the bios and see if the CD rom is loading as the second slave before the hard drive.  This could be you problem why the CD wont start.....failing that then what your machine is asking you to do is restore the computer to factory settings thats done when you first start the machine if I remember for that compaq its the F12 Button only thing here is it wiill wipe everything else.
  • Peter Hirawani
    There is a battery lithium one soldered to the Motherboard in your laptop find it and unsolder it leave it for about a couple of hours the longer the better for some and then go back in it should have resetted the bios and may allow you more options particularly with reading the CDrom.
SOURCE:
Compaq Presario CQ57 has red screen with compaq logo on start up and wont go past that screen even when pressing f-buttons
The hard drive has issues or the windows files have been corrupted, remove the hardware and reseat it back in place sometimes this will activate the system, next! use your backup recovery disc if you have one, no change! the hard drive will need to be tested.
Jun 24, 2012 | Compaq Presario CQ60-220US PC Laptop
Compaq 6310US: Can't get into BIOS
you can try removing and replacing the battery on the motherboard. If that does not work, you will have to look for the reset jumper on the board.
May 02, 2010 | HP Compaq Presario 6310US (DA201A#ABA) PC...
How do I acces the Bios on a Compaq Presario 5000 built somehere around 2002.
during the bootup post routines you should see a message that tells you what to do to go into the bios.
Sometimes the post routine is run without being shown on the screen. If so, try pushing the F2 button, or DEL key during the bootup sequence.
Dec 29, 2009 | Compaq Presario 5000 PC Desktop
Compaq Presario2500 don't go in setup
Reset the BIOS and Replace RAM .. issue will be solved.
Aug 28, 2009 | Compaq Presario 2100 and 2500 ,NX 9000...
Compaq presario 2199us notebook does not boot
Hi Krishna. Could be that the processor's cooling fan is no longer functioning and then the processor instantly overheats and everything STOPS !!! Could be the RAM memory chips not in good state anymore .....Could be that (while it tries to determine what hard drive is in there) the hard drive is BAD and cannot be identified... that would also just STOP everything. It really is quite a few things that could cause that
Jul 06, 2009 | HP Compaq Presario 2200 Notebook
How can i get rid of the compaq logo even after i format my hard drive .
The screen that I think you're referring to is the OEM BIOS splash screen.
This particular logo / image has nothing to do with your hard drive... it is embedded on a physical chip (EEPROM or ROMBIOS) on your motherboard.
It is possible to make modifications to this particular splash screen (through a hardware hack), but I don't recommend doing it. The screen shouldn't be a problem; it sounds like you might be experiencing a "Boot Order" issue.
I'm assuming you might be having problems with the Boot Order if you're having issues with loading your OS from CD. When you have the Windows CD in the CD ROM and you reboot the system, you should see the following message flash up on the screen (immediately following your OEM BIOS Splash screen):
"Press any Key to Boot from CD..."
If you don't see this message and your CD ROM Doesn't spin up and begin to load windows...you might have a Bad CD ROM, bad CD "Disc" or...you might not have your BIOS Boot Order set up correctly.
HOW TO FIX IT:
To get into the BIOS Setup on a Compaq Presario system, do the following:
When the OEM Logo Splash screen appears, press F1 to enter the BIOS Setup.
Note: On certain Compaq Presario PCs (prior to 2002) press the F10 key at the logo screen to enter setup.
To change the Boot order:
Here's the URL for Compaq's Online FAQ for Changing the Boot Order:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07110&lc=en&cc=us&lang=tr&man_lang=en&product=1843681&dlc=tr#N1310
Try changing the Boot Device Priority in the BIOS Setup: Make sure that the "CD ROM" entry is moved "Before" the entry for the Hard Drive and Network PXE:
Example Boot Order:
  1. CD ROM or Removable Media
  2. USB
  3. Floppy (if you have one)
  4. Hard Drive
  5. PXE (Network Boot)
This should help you load the OS successfully from CD (if you're not being presented with the "Press any Key to Boot from CD..." notification when rebooting with the Windows CD in the CD/ROM drive.
Please repost if this fixed your problem and rate my response!
Good Luck,
LounaTech
Apr 17, 2008 | Compaq Presario SR1800NX Desktop PC
How do you enter set up in an oler compaq presario. It came with win 98.also if hard drive controller is bad can I put in a new one without replacing motherboard
Depending on the actual model of the old Compaq, you can enter the CMOS/BIOS setup by pressing on the a special function key or key combination during Power-On Self Test (POST), before the operating system loads. During POST, the BIOS usually displays a prompt such as:
Press F2 to enter Setup
Common keystrokes that will access the BIOS Setup are F1, F2, F10, and Del. For older Compaq computers, like the Deskpro 286 or 386, you must place the Diagnostics diskette in the A: drive, and then restart the computer.
For newer Compaqs, like the Prolinea, Deskpro XL, or Presario, while the cursor is at the top right corner of the screen during bootup, press the F10 key.
The hard drive controller can not be replaced without replacing the motherboard. Incidentally, there are old PCI sundcards that has an IDE port and can be configured to replaced defective on-board IDE port.
If your concern has not been addresses after completion of the above procedures, you may need to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 17, 2008 | Computers & Internet
Blank screen on start up
It means that your system cannot detect Windows on your hard drive. Check the connections inside if you can. If everything is connected properly, then your hard drive is probably is at fault. You can do a disk check in dos but may not be accurate.
Oct 30, 2007 | Compaq Presario M2000 Notebook
Need to get to setup menu
either the 64kb of bios memory is damaged and not allowing the system to pass the post check, or the processor is unable to find the boot.ini file because of a corrupt hard drive or file. The first thing to try is if you are using XP is to keep pressing F8 on start up and then when windows enters safe mode select the line 'Last known good configuration' and press enter for a restart, if there is nothing major wrong then the system will boot up. If it won't boot then you are going to need to set your notebook to boot from cd drive (F2 or del on boot up and enter the bios and change first boot device to cdrom) and boot up using your; or a borrowed Windows XP disc and perform a system repair. Post back for further instructions, as it may be the hard drive that is damaged.
Aug 22, 2007 | Compaq Presario 1275 Notebook
Compaq Presario 2190US Notebook Logo
951 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
