Question about Dell 926 All-In-One InkJet Printer
Not working see bottom
Ced the ink cartridge and it keeps banging back not in alignment ., says clear the carrier jam then press check. there is no carrier paper jam., then it says' printing alignment'.
  • 11,896 Answers
Check your entire feed to make sure there is NO paper jams. Sometimes even the smallest little piece of paper can get jammed up and can e hard to see.
You can also check your manual for diagnostic mode and alignment print page.
Posted on May 13, 2009
My printer will not print, keeps displaying ( clear carrier jam! ). How can I fix it?? Do I need to buy a new printer or is this an easy fix. I 've unplugged the printer and checked ink cartridges...
Turn the printer off and unplug it from the wall. Press and hold the power button for sixty seconds. Open the top of the printer to make the ink cartridge carrier accessible. Grab the ink cartridge carrier with your hand and slowly move it back and forth until it moves freely. Then plug the printer back in and turn it on. That should solve your issue.
Sep 25, 2011 | Dell V305 All-In-One InkJet Printer
"Clear Carrier Jam"
Clean the carriage rail. This is the round chrome piece that the carriage assy that holds the cartidges rides on. Use a paper towel that is slightly moist.
Be sure to not force anything. Unplug the printer after you get the carts in the middle. Move them to one side and clean and then move them to the other and repeat
Jun 20, 2009 | Dell V305w All-In-One R840635AU InkJet...
Paper jam error
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Mar 22, 2009 | HP OfficeJet 7110 All-In-One Thermal...
Carrier jam on printer
There could be 4 possibilities.
1. Ink cartridges lids are open which is not allowing cartridges to move freely.
2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
3. Encoder strip is Dirty.
4. Encoder strip is Out of position.
Solution:
1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
4. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Oct 28, 2008 | Dell 924 All-in-One InkJet Printer
Ink cartridge carrier jam
If possible, shut off the printer completely and manually move the ink carriage to where the cartridges can be swapped out. turn it back on and try again. try to see if some mechanism that holds the missing cartridge in place has swung down and is bumping into something, preventing the carriage from moving past a certain point.
Aug 21, 2008 | Dell 926 All-In-One InkJet Printer
Dell 922 printer jam
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} When printer does not have visible paper jam and printer is showing error paper jam
Check if the Encoder Strip is Broken or Missing
1.Power down the printer and unplug the power.
2.Slide the cartridge carrier inside the printer a couple of inches to the left.
3.Locate the encoder strip (Figure 1) on the right-side of the cartridge carrier encoder strip
Note:
The encoder strip is a plastic strip with small markings over its entire length. The strip may appear to be translucent.
Reposition the Encoder Strip
1. Remove the power cord from the printer.
2. Lift the scanner unit to expose the inside, where the printer cartridges are located.
3. Gently slide the ink cartridge carrier to the middle of the printer.
4. Gently move the top part of the printer belt to the right.
5. Using an index finger, gently push encoder strip (Figure 1) down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
6. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
7. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
8. Once the encoder strip has been re-seated, close the scanner lid.
9. Re-connect the power cord to the printer.
Reseat the Dell Printer Power Adapter.
If your printer has a momentary loss of communication with your computer, it may be necessary to reset the printer to re-establish communication. You can reset a printer by unplugging the printer power cord from the electrical outlet and from the back of the printer for 10 seconds then reattaching the cord at both ends.
Check with manufacturer if printer is still covered under warranty...
If yes then get it replaced.....or else get a new printer
Jul 31, 2008 | Dell 922 All-In-One InkJet Printer
Lexmark x3550
Changing print cartridges Changing print cartridges Removing a used print cartridge
  1. Make sure the printer is on.
  2. Lift the scanner unit.
    The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
  3. Press down on the cartridge carrier lever to raise the cartridge carrier lid.
  4. Remove the used print cartridge.
Note: If you are removing both cartridges, repeat step 3 and step 4 for the second cartridge. Installing print cartridges
  1. If you are installing new print cartridges, remove the sticker and tape from the back and bottom of the cartridges.
    cartridge_tape_remove_one_2.jpg Warning: Do not touch the gold contact area on the back or the metal nozzles on the bottom of the cartridges.
  2. Press down on the cartridge carrier levers to raise the cartridge carrier lids.
  3. Insert the black cartridge or the photo cartridge in the left carrier. Insert the color cartridge in the right carrier.
  4. Close the lids.
  5. Close the scanner unit, making sure to keep your hands out from underneath the scanner unit.
    scanner_unit_close_2.jpg The control panel display will prompt you to load paper and press button_select_0.jpg to print an alignment page.
    Note: The scanner unit must be closed to start a new scan, print, copy, or fax job.
Jul 22, 2008 | Lexmark X3550 All-In-One Printer
Carrier Jam
THis solution I copied from another post. It worked for me as well
First you need to open the printer. Unplug from power. Then lift the scanning device, you can partially remove it when pushing the "hooks" close to where the lid is connected (careful with the cable connections). Then remove three screws in the cover of the bottom part and with some fiddling around you can remove the cover. Again be careful with the cable connections. Of course don't do it if you are worried about warranty or breaking the printer.
The plastic strip has slits at each side to attach to the inside back of printer, on the left side is a down ward facing arrow, the plastic strip feeds through the back middle of the cartridge carrier and then the slits are to be inserted to the metal tab like pieces on the back sides inside the printer on the right side (facing printer) it will look like a small rectangular hole with a longer metal tab like piece sticking out & on the left is a smaller squared like hole with a flat smaller metal like tab which will line up if the plastic strip is feed through the back of the cartridge carrier properly. This should allow the cartridge carrier to glide properly & work as it should, with no more banging.
Success
Jul 16, 2008 | Lexmark P4350 All-In-One InkJet Printer
Carrier jam Lexmark 4300
I had this same problem, I found a long skinny thin plastic strip had fallen off & caused the problem for me. The plastic strip has slits at each side to attach to the inside back of printer, on the left side is a down ward facing arrow, the plastic strip feeds through the back middle of the cartridge carrier and then the slits are to be inserted to the metal tab like pieces on the back sides inside the printer on the right side (facing printer) it will look like a small rectangular hole with a longer metal tab like piece sticking out & on the left is a smaller squared like hole with a flat smaller metal like tab which will line up if the plastic strip is feed through the back of the cartridge carrier properly. This should allow the cartridge carrier to glide properly & work as it should, with no more banging! Sorry my tech. terminology isn't good, I am not Knowelegable with this sort of thing, just sharing my experience :) HTH!
Jan 14, 2008 | Lexmark P4350 All-In-One InkJet Printer
Carrier Jam
The top of my ink cartridge had fallen off and was in the printer... I hadn't seen any paper or anything and was completely stumped, when I picked it up and heard something in there... It was hard to get back on, but now it works!
Jan 08, 2008 | Dell 924 All-in-One InkJet Printer
Dell 926 All-In-One InkJet Printer Logo
226 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
