Question about Haier America Manual-Control Room Air Conditioner, 5,200 BTU
Haier t.v. how do i remove the block from t.v.?
  • 86 Answers
No idea abt t.v
Posted on Mar 17, 2008
Haier hlp21n washer valve inlet - Water is not coming properly very less water then usual
Hi, if you turn off water to machine, remove flexable feed pipe to it and look into inlet hole, you should see a filter, this should pull out, maybe with plyers carefully, if blocked, clean with bleach, or descaler, ours (on a bosh machine, is in the actual tap on the wall, most odd that.) & replace.
If this is the cause, I would do it maybe every 6 months or yearly, depends on age of machine.
Hope this helps.
Nov 27, 2017 | Haier Washing Machines
Haier Refridgerator
Your freezr drain is blocked or frozen. What you need to do is remove the ice rack then in the front of the freezer you will see 2 or 3 plastic plugs on the freezer floor remove the plugs and there might aso be some 1/4 inch screws farther in on the freezer floor. also remove the back of the back of the freezr and then lift out the bottom floor. under the evaporator you will see a lot of ice or just fod blocing the drain. I will bet its all full of ice. Carefully remove all the ice and hot water will help once you get the buk of it out. The hot water will make sure the drain is not blocked with ice. Once its al clear install in the reverse order and things should be good. This is a common problem with this unit.Good Luck
Jul 12, 2007 | Haier HSW02C
My washer machine dose not spain
possibly a blocked pump, you can check this by listening for the hum of the pump without water being removed from the machine.
Oct 17, 2013 | Haier Washing Machines
Make sure it is not the fill tube from the ice maker first. Yes I would think ice or sludge is blocking the defrost drain and causing water to flow into freezer and then to the floor. Here is more about leaking refrigerators=> Leaking Refrigerators
Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
How to Fix Fridge Water Leak
Dec 05, 2012 | Haier RRTG18PABB (207 cu ft) Refrigerator
HAIER ONly blows air on one side
Possible that the vent or the vane is blocked which can also be due to a jammed motor in the auto oscillation vent.
Remove the panle and check the free movement which will confirm this case. Sometimes it could be dirt that is logged in that prevents free movement.
Jul 03, 2012 | Haier HPRB07XC7 Portable Air Conditioner
HAIER Model # HWR06XC3 not working :(
If this does not work, call an air-conditioning technician--the refrigerant ... 5) Remove the thermostat's cover and unscrew the wire from the Y terminal. ... may be blocking the water's flow, or leaking, or the pump may not be working. ...
Jul 09, 2010 | Haier Heating & Cooling
My portable air conditioner Haier started linking
Hi. Check the drain hose and look for kinks and partial blockage. Even algae can often block these tubes. J.
Jul 06, 2010 | Haier HPR09XH7 Portable Air Conditioner
Haier C2000
Haw to change Haier C2000 phone cdma sos mode lock remove?
Jul 02, 2009 | Haier Cell Phones
Haier HWD1000 washer/dryer
solved!!!! theres a flaw in the machine, lint builds up in air return area from the back of the machine to the heater, takes about 45 min to fix, take off lid and back pannel, remove weight, remove heater wires and hoses, remove plastic air return area, clean out lint, put back together, the air temp sensor is in the plasic housing in the rear of the plastic housing, the lint blocks air from circulating and triggers warning
Jan 31, 2009 | Haier HWD1000
Haier model# HTQ21J*SS freezer ices up with melted water, not draining
Go to an electronics section of Walmart or Target, buy a can of "CleanSafe Dust Remover" compressed air in a can and try to blow the drain clear from the freezer portion. If that doeasn't work, let me know.
Mar 14, 2008 | Haier HTQ21JABWW Top Freezer Refrigerator
Heating & Cooling Logo
52 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
