Question about Remote Controls
Stop VHS subtitles/captioning on JVC remote! ?
I give up. My 2 year old hit a button, and I now cannot figure out how to stop the subtitles/captioning when playing VHS videotapes using my JVC LP21036-027A remote. The DVD button for subtitles is clear enough, but what about VHS? Help! Thanks, Harrianne
5 Suggested Answers
SOURCE: Konka KLC 1508U TV
I am using a Phillips Universal remote I got at Target that controls 3 devices. The code for this is 0504. I have it hooked up with a cable box and in order for it to work correctly, I have to turn the TV on before I turn on the cable. If I don't, then channels don't change, etc.
Posted on Jan 05, 2008
SOURCE: RCA Universal Remote Control #451--Closed Captioning Will Not Turn Off
I can't figure out how to turn the cc off either. I went to menu and then audio then captions and off but they still won't go off. The captions are only on when I am watching HD channels. Anyone know why?
Posted on Oct 11, 2008
  • 7 Answers
SOURCE: need remote codes for jvc lp21036-034 to program
go to:
Posted on Sep 17, 2009
SOURCE: i can not remove closed captioning on all my
As best I can tell, the TWC remote requires about 12 steps to turn CC on & off - very annoying and I can't understand why it's not simpler. Hit the blue menu button near the top; scroll down or up to Settings, hit enter, scroll down or up to Captioning, hit enter, scroll to how you want CC (off, on, or just when Mute), hit enter, then hit Exit to clear the screen. A pain, no?
Posted on Dec 29, 2009
  • 30 Answers
SOURCE: Looking for the remote code for a phillips tv
Always my go to for this type of situation:
You will no doubt find what you are looking for.
Posted on Mar 05, 2011
0 characters
1 Points
How to turn off sub titles using urc7110 remote
You probably have closed captioning (not subtitles) enabled. Closed captioning is enabled/disabled as part of initial set up.
Jul 11, 2016 | One For All Remote Controls
Technika dv3t
Hi Warren,
Kindly tell him to push the D.SUB button underneath the yellow button, that is if he is on DVD mode. If that one won't work, you may ask him to push the third button from the left hand side of his remote control.
Turning off subtitles will not work for some programs as other broadcasting networks placed restrictions that you cannot turn on/off subtitles using your remote control.
hope this one helps.
Feb 06, 2014 | Remote Controls
Cant turn off subtitles
Normally the remote control has a button with the name Subtitles press the key for turn Off.However you must sure if the TV has Turn ON the captioning.God bless you
Jan 30, 2013 | Sylvania NE801UD
How do you remove the sub titles?
The "subtitles" are actually closed captions (CC). On your Toshiba remote, press the C.CAPT button to call up the CLOSED CAPTION MENU. Press the C.CAPT button on the remote repeatedly to select OFF
Nov 26, 2012 | Toshiba SE-R0305 Remote Control
Is there a way to access the subtitle button on a philips dvd player using the chunghop RM-88E universal remote control? Please help :(
Aren't you trying to select closed captions (CC)? If so, turning off the TV sound will cause closed captions to appear after a brief pause. Naturally, your TV has to be capable of doing this
Nov 02, 2012 | Remote Controls
Subtitles on screen
You have turned on closed captioning (not subtitles). You should have a CC button to turn it off
Oct 05, 2012 | One For All URC-3021 Remote Control
Is there a fee to answer this question: How do I cancel closed captioning with the Samsung BN59-00678A? Thank you.
If pressing the cc button on the remote is not working (you might have to press it multiple times in succession) then your cable box/satellite receiver is where the captions are coming from. You have to disable them with the cable box/satellite receiver remote or on the box/receiver itself. There is usually a hidden menu accessed after turning off the cable box and pressing the menu button on it. If you have a satellite receiver and not a cable box there is usually a yellow button to press to add/remove subtitles.
Jul 14, 2011 | Samsung BN59-00678A Remote Control
I found the user manual online - directions are:
Turn TV off
Hold RED TV Power button down
and at same time per manufacture of TV...
Hitachi - 1
Sony - 2
RCA - 3
Sanyo - 4
Zenith - 5
Panasonic1 - 6
Panasonic2 - 7
Sharp1 - 8
Sharp2 - 9
Toshiba - 0
JVC - Clear
Mitubishi - +10
Magnavox - SUBTITLE
Funai - AUDIO
Goldstare - DISPLAY
Jul 10, 2008 | Remote Controls
Since we don't have the model number, I'll try to use a generic answer. There could be a button on the remote that says CC or closed caption. If so, push it until it says off. If it is not on the remote, then you will have to find closed caption in the menu and turn it off there. Hope this helps. For better instructions give me the model and I can pull up the service literature.
Mar 04, 2007 | One For All URC-8811 Remote Control
Remote Controls Logo
224 people viewed this question
Top Remote Controls Experts
Are you a Remote Control Expert? Answer questions, earn points and help others
