Question about Toshiba Satellite A105-S4164 Notebook
Ununtu wont boot from cd
I have changed my boot options to make the cd drive boot first but that didn't help anything. It still skipped the cd and went straight to windows. I am currently in the process of making a new cd and am going to try that but other wise I'm at a loss of what to do. Any suggestions?
  • rdwing3000 May 13, 2009
    I already did change the order to cd-rom first.
    Sergeant:
  • 138 Answers
Here are two things you can try:
Easiest First,
While booting tap the F12 key to force boot from cd-rom
Boot to bios and change boot order to cd-rom first
this can be done by tapping F1 while booting
Posted on May 13, 2009
  • Brittany Garner
    Brittany Garner May 13, 2009
    did you try force boot by F12
Best to get an external CD/DVD-drive. But, just for interesting sake: did you try and clean the CD properly with a lint free cloth from the inside to the outside? There just may be a fatty spot on it. Also, try and run a cd cleaning cd in your drive first and see if it helps? Hope you could get this to work.
Posted on Mar 02, 2013
Hi I have a problem trying to install win xp on a toshiba portege 7100 series but it wont boot from the cd. I now that my cd's ok so thats not the problem, do I need some kind of a driver for the...
when you boot the machine, check for a boot options option to tell the machine to boot from the cd/dvd drive, alternatively go into the bios settings and there will be an option in there to set which device to boot from.
May 05, 2011 | Toshiba Portege 7100 Notebook
The problem is that it wont boot from cd/dvd..i updated bios..but had the same problem again,help please
Most probably one of the following reasons..
- CD could be corrupted
- CD was not written in a "Bootable" mode
- CD Drive could have become old. Time for replacing.
- Boot sequence in BIOS needs to be checked up.
Mar 05, 2011 | Biostar MCP6P M2+ 6.x Motherboard
How to use the restore disks
1. Insert the restore disk into your computer's DVD/CD drive. Prior login to your user account is not required.
2.Reboot your computer. Watch the boot screens and wait for the onscreen prompt to press any key. If you do not get a prompt, reboot your computer once more and skip to step four.
3.Press any key to boot from CD when prompted to do so. You will now be taken to the first screen in the restore process. Follow the onscreen prompts to finish restoring your machine.
4.Change your BIOS settings, if necessary, to boot from your CD drive first. Common options for entering the BIOS include pressing "ESC," "DEL" or "F12" on your computer's first boot screen. If you don't know how to get to the BIOS, check your computer's documentation for instructions. Once inside the BIOS, set the primary boot to CD-ROM and save your changes. Exit the BIOS and wait as your computer reboots and begins the restore process.
If this answer helpful please vote me.
Good luck.
Thanks for using FixYa
Jan 22, 2011 | IBM NetVista PC Desktop
Hi when i satrt up my hp compaq mini 110 it wont load past the bios. it comes up with the options for F9: change boot device order, F10:BIOS setup options, F12: Network boot. if i leave it to laod past...
Check to see if any media is in you CD DRIVE, or any other drive because if BIOS is booting from the CD or other media first, it never gets to your hard drive thus never boots windows. If clear, Press F9 and enter into your BIOS setup. You will have to make sure your boot sequence/order is in order to boot first from the hard drive. If all is in order try F8 hitting it repeatedly until safe mode options appear. If this doesn't work post a reply and we'll go from there.
Jan 11, 2011 | Computers & Internet
T42 gets message"NTLDR" not available. Tried to
Don't try loading windows with out fixing the NTLDR...Try this simple steps in recovery console,
  • Insert the Windows XP CD-ROM into the CD drive, and then restart the computer.
  • Click to select any options that are required to start the computer from the CD drive if you are prompted.
  • When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  • Press 1 (One) to select windows XP and then hit enter.
  • When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
  • At the command prompt, start typing
COPY D:\i386\ntldr C:\ (Considering that D is your CD Rom Drive)
COPY D:\i386\ntdetect C:\ (a file that may also be missing)
  • Then rebuild the boot configuration boot.ini file by
    Attrib -H -R -S C:\boot.ini (if not found skip the next line)
    DEL C:\boot.ini
    BootCfg /Rebuild
    Note:
    Do not use the repair option in the recovery console.
    Or, if you can get into XP, even safe mode, you can arrange to bypass the
    password by the following registry change:
    Click on Start then click run and type Regedit. Navigate to the key mentioned below,
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\CurrentVersion\Setup\RecoveryConsole
    Set the DWORD Security Level value to 1
Hope this helps
Dec 27, 2010 | IBM ThinkPad T42 Notebook
Wont boot, not even from CD, won't open setup or boot options
At first you insert your system disc on your cd/dvd rom driver and restart your computer. Now press F2 or DEL until you get your BIOS option. Now go to advance option then boot option in that. Now change your first boot option to CD/DVD ROM DRIVE and save that change by pressing F10. Now restart your computer and continue your installation. Thank you.
Jun 10, 2010 | HP Media Center m7250n (ED842AA) PC...
Acer 5102 with xp, It wont boot from cd.
Make the DVD your 1st option for booting. It's also your CD drive but is identified as the DVD RW. Once this is made your default (make sure you accept and save the change before exiting) with your installation disk in the drive, boot up and it will read off the disk and prepare your system for install. If your disk is bootable, this will work.
Dec 19, 2009 | Computers & Internet
SYSTEM SWITCHES ON AND DETECTS ALL THE HARDWARE BUT WONT GIVE ME THE "PRESS ANY KEY TO BOOT FROM CD-ROM OPTION"
Some computers allow you to select an alternate boot device by pressing the F12 key as you boot up.
If your computer doesn't have this option then go into the BIOS configuration and change the boot order and make the CD-ROM the first boot device and the hard drive the second boot device.
Aug 14, 2009 | EliteGroup 661FX-M7 (661FXM7V11)...
Portege m200 wont boot from cd or anything.
look at this page
http://blog.ryantadams.com/2008/02/01/how-to-boot-from-the-network-pxe-boot-with-tftp-and-windows-pe/
it works very good.
Mar 27, 2009 | Toshiba Portege M200 Tablet PC
Need to reset boot order so i can reinstall windows, how do i get into to do that on this computer
Put cd in the drive
while continuosly pressing f7 while in restar a box should appear it will give you boot option high light your cd or cd/dvd boot
If this does'nt work while restarting press f2 or delete tells you on your startup screen what to press for setup depending on your system will get you into bios when in there you will be able to change boot options usually under boot
I would'nt change anything else in there but the boot option then press f10 to save and then enter restart withy cd in drive
LET ME IF THIS HAS HELPED
Jan 15, 2009 | Microsoft Systemax Ascent Desktop Computer...
Toshiba Satellite A105-S4164 Notebook Logo
332 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
