Question about Motorola T6510 XLR Talkabout Two-Way Radios :
I don't have the supply power cord for T6510 charger
Can you please help me to get the specs cord to feed C/A to the T6510 charger?
  • pechjose33 May 13, 2009
    Thanks for this solution, One more question..Does the Micro Amp are relevant for the supply cord?
  • 11,896 Answers
I do believe it is a 9 volt charger. Look under the battery cover and it will say how many volts. It is probably 9 volts. Just have to find a 9 volt charger with the same plug as you have. Or contact Motorola for new one. Possibly E-bay
Motorola T6510 FRS walkie talkie with charger
http://shop.ebay.com/items/_W0QQ_nkwZT6510Q20chargerQQ_armrsZ1QQ_fromZR40QQ_mdoZ
$1.04
Posted on May 13, 2009
  • Nate Stansfield
    Nate Stansfield May 13, 2009
    It should say Input voltage
Hp pavilion g6 series
Have you tried another cord/charger with the EXACT same power specs? Has the AC jack, in the laptop, been damaged due to pulling on the cord/charger? Have you tried with and without the battery? Does it power with the battery? Has there been ANY damage? If you remove the battery what does it do? Describe what happens, without battery, when you push the on/off button? Anything? Led blink? Fan spins?
Jul 08, 2013 | Computers & Internet
I have two latitude x1.one dosent charge the betry.i have to put charged betry in it and its work fine..i need to fix this.anyone can help me?
Try another Cord/charger with the EXACT same power specs as the Original. Both Batteries are good? Both Cord/Chargers are good, same power specs. DC volts and Milliamps? Dell Specs: http://www.dell.com/downloads/emea/products/latit/LAT_X1_emea.pdf Battery, charger can be found here: http://www.atbatt.com/laptop-batteries/b/dell/m/latitude-x1.asp
Feb 27, 2013 | Dell Latitude X1 Notebook
No power to start Eee1000H
Try another AC outlet, "extended supply", can you explain? a UPS? Try another Cord/charger of the EXACT same power specs.
Feb 12, 2013 | ASUS Eee PC 1000H Laptop
Change power supply
Are you refering to the AC jack? Have you tried another Cord/charger of the EXACT same power specs? Has the AC jack been damager due to pulling on the cord? HP Support may help: http://h10025.www1.hp.com/ewfrf/wc/product?product=3650971&lc=en&cc=us&dlc=en&lang=en&tmp_track_link=ot_we/prodlink/en_us/3650971/loc:0&cc=us
Feb 11, 2013 | HP Pavilion dv9700t Notebook PC
Trying to order battery and new power supply for computer 96254
Without the Make, Model of computer It's difficult to help. But a word of advise, Beware of inexpensive aftermarket Batteries and cord/chargers. They sometimes , at best, do not work properly, a worst, can be a fire hazzard. It's cheap for a reason. Be sure to buy the EXACT power specs, Voltage, Amperage. Look to the Laptop Manufacturer for exact replacement. They may be pricey, but , in the long run a better bet.
Dec 02, 2012 | Computers & Internet
I am trying to use my start-it pro system for the first time to jump start my vehicle. Can someone please tell me where does the power connect to the actual 12 volt dc supply. I have 2 things 1. The yellow...
When a question is presented to any forum, model number(s) are essential. Please provide any that you have and if you would. Just to make sure I'm fully understanding what you're asking, would you please rephrase your question?
A lot of models don't come with an AC/DC wall charger and it must be purchased separately but I'm fairly certain there is an alternate method to charge your unit. I'll be able to specifically determine how, once I have the model number.
FYI: The VEC070 1.5 Amp Automatic Charger is a commonly used charger for this type of jump-start system. Don't buy anything until we're certain.
Sep 08, 2011 | JUMP START SYSTEM
I have a Roland Fantom FA76 midi keyboard. I don't have a power supply cord for it. Where it plugs into the keyboard looks just like the cord that would plug into a desktop computer, three prong female...
yes they are the same type of cords as for the specs that is statting what the internal power converter can safely use to power the devices in the appropriate modes to change the mode you need to pen the pannel and change the seitch position, the factory default is 110-117V AC, if by chance that it is set to the higher settings the only sighn would be that the fuse will keep blowing on the device or it will cut in and out.
Jul 01, 2011 | Computers & Internet
My charger for my Motorola T6510 is not charging. The charger is getting power.
Check your battery contacts, both on the radio and the charger. Clean with a pencil eraser if needed. It is possible you are not getting good contact. If both radios are not getting charged in a dual well charger, you may have a problem with either the wall adapter or the base. (Assuming your batteries are good.) Wall adapters burn out over time, somewhat like a light bulb.
Replacements are available at the Motorola online store. http://www.store.motorola.com/2-Way-Radio-Rechargeable-Battery-Upgrade/dp/B003H0FUD2?ie=UTF8&id=2-Way%20Radio%20Rechargeable%20Battery%20Upgrade&field_availability=-1&field_launch-date=-1y&field_browse=2265964011&searchSize=12&searchPage=1&searchNodeID=2265964011&refinementHistory=brandtextbin%2Csubjectbin%2Ccolor_map%2Cprice%2Csize_name&searchRank=salesrank This kit contains a pair of new batteries and a complete charger.
Best regards.
Nov 04, 2010 | Motorola T6510 XLR Talkabout Two-Way...
Charger for T6510
I am having the same problem. Has anybody provided you any help? Did you find a solution
Jun 01, 2008 | Motorola T6510 XLR Talkabout Two-Way...
Motorola T6510 XLR Talkabout Two-Way Radios : Logo
250 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
