Question about Gaggia Titanium Espresso Machine
CLogged Titanium My Titanium shows :Ventilating. I open the knob and let hot water/steam out many times. After 20 times it says "select coffee" so I push selector, it grinds and after the clicks it shows again "Ventilate". I used cleaning solution for 7 days but still no brewing. Seems a pipe is clogged or some orifice? I am an engineer and could take it apart, clean and re-assemble but until today the seller Abree did not provide me service manual. Any advice? Frustrated, John Harwer 949-310-4442
  • 6 more comments
  • krup Nov 12, 2007
    I appear to have the identical problem with my gaggia titanium. I have run a reservoir worth of water through the machine in response to the 'ventilate' message, but the message will not clear. jim
  • Gisela Nov 13, 2007
    Same problem!...after descaling my machine...the word ventilate came on my display...no matter what I try, the ventilate display stays on....meanwhile my great coffee machine will not make coffee....if you know of a solution please let me know...have trie on/off, unplugging, removing brew group, cleaning, ventilating many times, rinsing...nothing has worked.....thanks....
  • chip27 Nov 23, 2007
    Just got the machine and within 2 days am getting this Ventilate problem. I can't clear it and can't make copy. Any ideas.
    Mike
  • CafeLady Nov 26, 2007
    I'm now on my second Gaggia Titanium in the last 30 days. Both brand new machines steamed about 3 cups of milk before I got the "ventilate" message. I followed the manual instructions to prime the circuit and then attempted to manually prime. Neither worked. If I push the "hot water," and then open the wand, I get prompted to "close the knob" after a few seconds. If I keep repeating that process (20-30 times), the display will clear and I can use the machine to brew coffee. Sometimes the hot water will then pump, but half the time I will get the "ventilate" message again. When I get the dreaded "ventilate", I have to go through the entire process above (20-30 times), before the display will then clear and I can make coffee again. After going through two machines, I wonder how common this problem is.
  • Anonymous Dec 31, 2007
    i have had the same problem and found the answer it is just a stupid internal counter which has no relivance to if the machine needs decalcifing
    just hold the esc key down for 10 secs that resets the counter then go to factory reset and say yes clears the memeory then give it acouple of rinses for good mesure. good luck.
  • Boomer51 Mar 08, 2008
    Doing the repeat ventilate process over and over worked for me this time. Why are people being so tolerant of this problem, after spending so much on the machine? I'm sending mine back if this is indicative of life with the Gaggia Titanium. Is Gaggia doing anything to rectify this problem? It sounds fairly common.
  • grant917 Apr 27, 2008
    same problem with the ventilate ...this sucks. great machine, amazing coffee, but I have gone to Starbucks the last few mornings b/c the machine will not work!
    the Gaggia tita Titanium is 3 weeks old!
    I see numerous people have attempted to overcome the same problem by pushing the hot water button, then opening the steam knob, and repeating 20-30 times. I have attempted that without resolution.
    any new ideas?
  • jamesmmm May 17, 2008
    Continue to get ventilation error. Buttons do not work once i get this message.Only way to clear seems to be to reset to factory settings and then run hot water then change it to steam where it appears to clear it for a short time.
    Problem Solver:
  • 7 Answers
I think it's simply this: The duration of the rinsing cycle is equal to the amount of water you have in the water tank. I don't believe they tell you this anywhere in the manual! I own a Titanium SS and it rinsed and rinsed and rinsed the first time I performed it! I figured out it will just keep going until the water tank sensor tells the machine it is out of water which is equal to saying to it: "Thanks for using all the water I wanted you to use to rinse, now you're finished." Move the machine close to your sink...open the knob and let it do its thing for as long as it takes. Hope this helps, Tony.
Posted on Jan 04, 2008
Had the same problem
Pump was dry
Opened the Gaggia and saw that every time i opened the knob for steam the water roze through the tube from the water container to the punp. So opening and closing got my Gaggia working again ....
Posted on Dec 26, 2007
  • 3 Answers
I went through 3 machines (both Gaggia and Saeco--both have the same Rapid Steam system), hours of searching the Internet, and phone conversations with support(?) staff before I came up with what seems to be good options for both fixing the problem and then preventing it from being a problem again.
The Fix. Fixing the problem works better with two people, so I will refer to person 1 (P1) and person 2 (P2). To fix the problem: 1) P1 uses either a turkey baster or the small plastic (and leaky) pump packaged with the machine; 2) while the readout says "ventilate", P2 pushes the hot water button, then turns the machine off and removes the water tank; 3) P1 fills the plastic pump (or baster) with water and inserts it into the water intake valve (as best as you can, it doesn't fit perfectly); 4) P2 then turns the machine on and opens the steam wand while P1 pushes water into the intake using the plastic pump or baster; 5) as soon as P1 is finished, P2 turns off the steam valve. Repeat steps 3) through 5) until the machine has accepted 4-5 good pumps of water. If you get the "fill watertank" message, you must begin the entire process over again (if you get the "fill watertank" message every time, just keep following the process until you get the machine to accept 4-5 good pumps of water); 6) turn the machine off and reseat the water tank. 7) Turn the machine on, press the hot water button, and open the steam valve. It may take a minute, but you should finally get water. Run it until it becomes a steady stream, and then some more...about 8 ounces worth. I have found that this process doesn't always work if the machine is hot. When it's hot, it sometimes won't accept any water into the intake valve.
Prevention. To prevent the problem, I have been successful (so far) by: 1) after steaming milk, I push the hot water button and run hot water through the wand until it is a steady stream, and then about 4 oz more. 2) I always steam the milk first, then run hot water through the wand, and then make the espresso. 2) I always run water through the wand after making coffee.
This seems like a lot of steps, but it really doesn't take that long once it's part of your routine. I've been successful with this process for the last several day and before that, I was getting the ventilate message every time I tried to steam milk. I'm hoping it continues to work! It's really a shame that the technical staff have not come up with a better solution or, at the least, addressed the problems people are currently experiencing. When I called Saeco, they told me they didn't know why it as happening!
Posted on Dec 12, 2007
    Sergeant:
  • Gaggia Expert
  • 223 Answers
Love to go over the problem with you. Give me a call at 866-408-9438.
Ask for john.
Cerini Coffee Services
Authorized Gaggia Service center
Posted on Oct 15, 2007
What PURGE means
Means to run Hot water through the steam wand... Also called ventilating the machine. Basically running water through the machine the easiest way possible which would be through the steam wand. On the magic deluxe all you have to do it turn the steam knob.
here is a page that may help you now or maybe some other time. http://www.cerinicoffee.com/item-group.asp?pgpID=13
Jun 06, 2011 | Saeco Magic De Luxe Espresso Machine
Ventilate!....shows in window and machine will not ventilate when knob is opened. it has regularly been de-scaled but we do live in a hard-water area.
Generally you can clear the ventilate error by pressing the button for Hot Water and then opening the steam knob. You should hear the pump run and water should start to flow from the steam wand. If it doesn't, try removing the frother nozzle so just the chrome pipe is showing.
To remove the frother nozzle you slide the outer sleeve off, and then grip the nozzle with one hand while twisting the cap to loosen it. Then it should slide off the metal steam pipe. Or you can check that the tip of the nozzle isn't clogged.
If you have the frother removed and the steam pipe is definitely open and not clogged and you still hear the pump running but no water is coming out, the next step is to prime the pump.
If you still have the squeeze bulb pump that came with the machine, you can use that - or if you don't have it, a turkey baster will work. You want to take the water tank off and set it aside, then pump water into the valve in the center where the tank had been sitting. You choose "Hot Water" and open the steam valve so the pump starts and then pump water into that valve with the Turkey Baster. You should hear the pump catch and start to move the water - when this happens immediately close the steam valve so the pump stops - then replace the water tank (filled with water please) and open the steam valve again and let water run out of the steam wand for several seconds.
That should clear the ventilate message.
Oct 21, 2010 | Gaggia Titanium Espresso Machine
Gaggia Titanium bought new in Italy. tested it to make coffee ALL OK. tested to see if steam came out and it did. Took it on a plane with me plugged it in coffe good but steam does not come out for...
When you twist the steam knob all the way, it actuates an electrical switch. The first part of the turn just opens a mechanical valve to allow the steam or water to come out but doesn't turn on the heater nor does it start the pump. You need to turn it far enough to trip the electric switch that starts the heat and the pump.
If it still isn't working, then perhaps the switch was knocked loose when it was taken on the plane.
Oct 13, 2010 | Gaggia Titanium Espresso Machine
Gaggia Titanium. Fault suggests ventilation required. Followed manual instructions, nothing happens. Tried rinsing, nothing happens. Tried hot water nothing happens? Have taken out and cleaned all pbvious...
Do you hear the pump working but no water flows?
You should select hot water (the third button from the right) and the display should say "hot water" at the same time it is saying VENTILATE --- open the steam valve all the way and the pump should start and you should see water from the steam wand.
If you don't hear the pump at all, then that is a different problem.
If you do hear the pump but still don't get any water with the steam valve open, then you need to prime the pump by using a turkey baster or the accordian pump that came with the Titanium to pump water into the valve where water from the tank goes. Remove the tank and use the turkey baster to pump water into that valve while the pump is running and the steam valve is open all the way with HOT WATER selected. the second water starts to come out the steam valve you want to stop the pump (turn the power off or turn the steam knob shut) and put the water tank back on and make sure there is plenty of water in the tank - then start the pump again by opening the steam valve all the way and let it pump water out the steam wand for a few minutes.
Oct 05, 2010 | Gaggia Titanium Espresso Machine
Steam not working properly = keeps saying close knob then ventilate have waited and pressed 26 + does coffee but then steam not strong enough again
Probably a broken "Steam Valve Cam". They are plastic & prone to failing with consequence that the steam/hot water needle valve does not properly open.
May 05, 2010 | Gaggia Titanium Espresso Machine
Keep getting ventilate message - won't ventilate and cannot operate steam or grinder w/ ventilate message
Try this run the hot water cycle for a few seconds, it that works, try steaming if you get the message again clear it by running the hot water cycle and then go to steaming, this time push in on the knob after you open it, it that works, then the tap rod or the valve assembly needs to be replaced.
May 01, 2010 | Gaggia Titanium Espresso Machine
Gaggia Titanium Espresso machine problem: steam venting into inside compartment after pulling espresso shots.
Normal, depending on the amount, when the hot water goes through the coffee and the pressure builds up the excess has to go somewhere when it stops, usually the drain tray, so there is a little steam loss.
Mar 04, 2010 | Gaggia Titanium Espresso Machine
Keeps showing ventilate. tried running the hot water. took removable machine parts out, cleaned, and put back. nothing works
Check the end of the steam wand, that could be blocked, if not then try this push in on the knob after you turn it open if that works, then replace the steam valve assembly.
Feb 25, 2010 | Gaggia Titanium Espresso Machine
No hot water or steam from wand.
If steam wand is not blocked then the problem is on the inside of the machine, try descaling the machine that might clear the blockage in the steam line.
Nov 28, 2009 | Gaggia Titanium Espresso Machine
Saeco Vienna Digital
I had this problem on my Saeco Vienna Digital a while back. I read somewhere just to keep on ventilating, even if it took 20 hoppers of water. Sure enough after about 16 cycles, I heard a change in the noise and looked to see the ventilate sign was gone.
Oct 24, 2007 | Saeco Vienna Digital Coffee Maker,...
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
728 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
