Question about Chicago Pneumatic Air Tools & Compressors
Need a manual for a chicago pneumatic trailer compressor model#175-rg-1 83426 33426 need hose diagram to hook it all back up correctly
  • 1779 Answers
SOURCE: Looking for a wiring diagram for a 2006 Ford Expedition
7way- black is 12volt (power), brown, running lights, yellow is left turn signal and stop light, green is right turn signal and stop light, white is ground, blue is brakes, and orange is aux power (can be back up lights, if trailer equipped w/ them). 6way is the same, minus orange wire. I have run into some variations to the above color codes (brown, yellow and green only-sometimes these 3 are different than stated, but only mixed as that group, as to what they control- example would be green is running lights, brown and yellow are turn signal and stop lights, the others should be as stated), if you have any trouble with things not working properly, it may be due to these variations, although the above are pretty standard. If you have an ohm meter you can check as you go (check for power at black wire- should be constant 12v, turn on turn signal and check for power-it will fluctuate from approx. 12 volts to 0 volts as the signal power pulses in the wire) hit the brakes, blue wire should show power, etc. Let me know if you need more help as you go.
Posted on Apr 11, 2009
  • 50 Answers
SOURCE: need wire diagram to hook up trailer lights, truck not factory equipped w/harness,
I'm assuming you're just going to splice into the tail light wiring so that's what these wire colors are:
at the tail lamp 3 way connector:
black and yellow = park lamp
dark green and brown = left turn signal
there should be another connector with violet and black wire for reverse lights.
the stop lights are turned on through the turn signal circuits.
Posted on Apr 12, 2009
SOURCE: need vacuum hose diagram for 1988 chevy s10 v6
If you dont want to spend the money on the book go to your local libary you can check out chilton book or make a photo copy of the diagrams you need from the book.
Posted on May 05, 2009
pops296
  • 174 Answers
SOURCE: electrical wiring diagrams
try http://www.etrailer.com/faq-wiring.aspx. This should help. Mike
Posted on Sep 30, 2009
sscullys
  • 984 Answers
SOURCE: 2001 Ford F150 need a fuse box diagram. Hooked up
You can download a PDF version of the owners manual from Ford
https://www.fleet.ford.com/maintenance/owners_manuals/default.asp
Posted on Nov 03, 2009
I'm trying to find the check valve on a chicago pneumatic air compressor model QRS5.0. Can anyone help me with the location.
the check valve is normally on the end of the air line from the compressor into the tank
most are screwed into the tank with the compressor line attached to it.
Jul 12, 2015 | Chicago Pneumatic Air Tools & Compressors
Manual for chicago pneumatic air compressor
go right to their web site and you can download free in pdf form any manual from user manuals,parts list,etc. www.chicagopneumatic.com
Feb 26, 2011 | Chicago Pneumatic 7.5 Hp 3 Phase Air...
HOW DOES IT WORK WITH NO CORD???
If the product your have this listed under is correct then you need to hook up an air hose to this sander to make it work...it works on compressed air...
heatman101
Aug 21, 2010 | Chicago Pneumatic Cp7200s Mini Random...
I have a Sullair 185 air compressor. The engine runs fine until I hit 90 psi and then it kills the engine. What could be wrong? Max working pressure 175
your not return balve is stuck open or your valves are sticking the pressure from the tank is going back to the pump so when the compressor goes on the compress stroke its very hard as it has to open the valve with pressure behind it its hard to explaing buddy but on the tank you wil see anon return valve from the pump unscrew it and inside is a rubber with a spring turn the rubber around and try this if doesnt work you need to inspect the valves (if sticking) good luck
Sep 02, 2009 | Chicago Pneumatic 1/4" Air Screwdriver
Picture of assebly for chicago pneumatic demolition tools
Parts / Diagram here http://www.toolsrenewed.com/AirToolPrints/CP/CP-1230%20Breaker.pdf
You might post again describing the problem that you are having with the hammer. Enjoy
Dec 10, 2008 | Chicago Pneumatic Demolition Tool - 60 lb....
Air Tools & Compressors Logo
175 people viewed this question
Top Chicago Pneumatic Air Tools & Compressors Experts
John Trevino
Are you a Chicago Pneumatic Air Tool and Compressor Expert? Answer questions, earn points and help others
