Question about Frigidaire GLTF2940ES Front Load Washer
E20 error? My wash machine is filling full of water and is stopping with an e20 code and not continuing to cycle or drain.
  • jnntck Nov 09, 2007
    My machine has done the same thing. Sometimes it runs fine but other times I have to wash and then run it on the drain and spin cycle.
  • Matt6112 Nov 14, 2007
    Same problem as others. I will add that the drain cycle appears to start and stop many times before the machine kicks off. Thanks.....
  • 3 Answers
Thanks a lot! It was packed solid from threads of a rug!
I had to replace the clamps.
thanks alot again!
Posted on Jul 28, 2008
    President:
  • 1,294 Answers
Plug off the wall first before these jobs. Remove rear panel.Check your filters and pump. Most probably you have a block in your pump. You have to drain out water from the machine by lowering the hose behind the machine to floor level, be prepared, bucket, etc. Dont forget to fix hose behind at very same position in wall drain. Your filter panel is in front bottom right of machine.
Things shd be fine, rate me pl.
Posted on Dec 02, 2007
My washing maching is reading E20 and it is not washing. it seems to stop after a few minutes of washing and then it will read E20 and just continuosly beep
Hello.
Frigidaire front-loading washing machines have an electronic control panel where the wash cycle and any other wash options are selected, and the wash cycle is initiated and stopped, if necessary. The control panel also has indicator lights that show the washer status and will display an error code if there are issues with the washer. The "E20" error code indicates a possible pump problem.
Blocked Pump
One of the primary reasons why there may be an "E20" error code on a Frigidaire front-loading washing machine is if there is something blocking the pump. Disconnect the washing machine from the power and release the clips on each side to remove the front access panel. Set a container under the pump drain, which is located on the lower right side of the washing machine. Open the pump drain plug and allow it to drain. Clean out any debris that might be causing the obstruction, then close the drain plug. Close the access panel and restore power to the washer.
Drain Hose
If the drain hose is blocked or crimped, the water may not pump out fast enough, causing the pump error to appear on the display. Straighten out the drain hose in the rear of the washing machine and move it away from the washer if it's trapped between the wall and the washing machine.
Oversudsing
If too much detergent--or the wrong kind of detergent--is used in the washing machine, too many suds may result. This can overwhelm the drain and pump system, resulting in the error. Use only high efficiency (HE) laundry detergent with Frigidaire washing machines and follow specific instructions on the laundry container for the recommended amount of detergent. Run a drain cycle if there are excess suds in the washer to clear out the system.
Pressure Switch or Control Boar
The pressure switch may not be communicating properly with the control board, which can cause the E20 error to occur. The other possibility for the E20 error code is if the control board has failed entirely. Try to reset the washing machine by pressing "Stop/Cancel" and disconnecting the washing machine power cord. Wait 30 seconds, then restore power. Make a new cycle selection and press "Start" to see if the error code returns. If it does, turn off the washing machine and contact Frigidaire for repair.
Thanks.
Nov 08, 2011 | GE Energy Star WCVH6260F Front Load Washer
Washer fills washes will not spin or drain...get a code E20 .can drain it manually then it will complete is cycle.....sounds like the pump but how do i get to the pump
your machine is not emptying the water out of the unit and this is why you are getting the error code 20 you would have to check the drain pump and the drain line that connects to the pump itself in order to properly alleviate this issue If you have any further questions message me back and please remember to rank how this opinion has helped it allows me to continue to help others in similar situations in the future Thanks again Rick
Apr 28, 2011 | AEG Washing Machines
I have a Zanussi Electrolux ZWF 1430 W and it's coming up with an E20 error code. The machine starts off OK but after about 25 minutes the Error Code E20 starts flashing in display and the machine stops...
E20 is a draining error.
  1. First, try to reset the machine to factory settings first by setting cycle selector to off position for 5 sec, then to spin for 5 sec, then back to off for 5 sec, and then to spin. The machine should reset allowing you to select the drain cycle and get the water out of the machine then run a spin cycle to clear any remaining water before you unscrew the filter to clear it.
  2. Next, you need to take the filter out at the front, bottom right, of the machine, empty it of all lint and replace it. It may have water trapped in so be ready to soak up excess liquid! Also, make sure when you put it back in you have tightened it enough to avoid leaking but not too much that you cannot get it back out.
  3. If this doesn't fix the problem, check your drain pipe hoses to make sure they are not kinked and flush them out.
  4. Last but not least, replace the drain pump.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jan 08, 2010 | Zanussi ZWF1430W Front Load Washer
Error code E20 comes on during a wash cycle. i
If the filter is clean and the hoses are free of obstructions,you will need to replace the pump
Oct 18, 2009 | Washing Machines
MY WASHING MACHINE HAS STOPPED 28 MINUTES THROUGH THE WASH CYCLE. ITS SHOWING UP E20 ERROR. ITS FULL OF WASHING AT THE MOMENT
Hi!
Error E20 means there is a problem with water draining. Please check the drain hose which may be kinked or squashed or the drain pump may be blocked. Another possible cause is totally blocked filter which is required to be cleaned to resolve the issue.
Thanks for using FixYa and revert for further assistance.
Thanks
Rylee
Jul 18, 2009 | Zanussi ZWF1430W Front Load Washer
Stops at 23 mins with error code e 20
E20 is a draining problem. the first thing to check is the filter at front of machie as there may be something blocking the pump.
Before removing filter tilt machine back and place a bowl under as there will be water inside.
Thanks for using Fixya.
Jan 08, 2009 | Zanussi ZWF1430W Front Load Washer
E20 code on washer : will not empty water on spin cycle?
something is stopping the water from drainning...check for kinked hose,,,check waste pipe,,,check units sump...onthejob
Dec 18, 2008 | Frigidaire Affinity ATF7000E Front Load...
E20 message
Hi Helenw,
The error message E20, simply means the filter plastic cage which is located behind the trap door bottom right side of the machine is full and needs to be cleaned out.
All the fibres and lint gets trapped in here and prevents the waste water from escaping, hence Error code E20.
Regards,
David
Sep 12, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Error codes
Hello ALARM CODES Alarm code Description of fault User code Effect E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2 E12 Problems with water fill in drying E10 Cycle PAUSED 8.3 E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4 E22 Problems with water drain during drying or drying condenser blocked E20 Heating phase skipped 8.5 E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked with door closed 8.6 E32 Incorrect calibration of analogic (electronic) pressure switch --- Cycle PAUSED 8.7 E33 Incongruency between level of analogic (electronic) pressure switch and level of anti-boiling pressure switch 1 --- Cycle blocked with door closed 8.8 E34 Incongruency between level of electronic pressure switch and level of anti-boiling pressure switch 2 --- Cycle blocked with door closed 8.9 E35 Water level too high --- Cycle blocked with door closed and water drain 8.10 E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked with door closed 8.11 E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked with door closed 8.11 E38 Pressure chamber blocked --- Heating phase skipped 8.12 E41 Door open E40 Cycle PAUSED 8.13-14 E42 Problems with door closure E40 Cycle PAUSED 8.15-16 E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18 E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19 E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked with door closed 8.19 E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door closed (after 5 attempts) 8.20 E52 No signal from tachometric generator --- Cycle blocked with door closed (after 5 attempts) 8.21-22 E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked with door closed 8.23 E54 Relays (motor) contacts faulty --- Cycle blocked with door closed (after 5 attempts) 8.23 E61 Insufficient heating during washing --- Heating phase skipped 8.24 E62 Overheating during washing --- Drain, end of cycle 8.25 E63 Insufficient heating during drying Heating phase skipped 8.26 E64 Overheating during drying --- Heating phase skipped 8.27 E66 Power relay to heating element faulty --- Drain, end of cycle 8.28 E71 NTC wash sensor faulty --- Heating phase skipped 8.29 E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30 E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31 E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle (door open) 8.32 E85 Circulation pump faulty --- Drain, end of cycle (door open) 8.33 E91 Communications error between main PCB and user interface --- --- 8.34 E93 Configuration error E90 Cycle blocked 8.34 E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34 EF1 Drain filter blocked LED-EF0 --- 8.35 EF2 Excessive detergent LED-EF0 --- 8.35 Regards David Marsh
May 06, 2007 | Zanussi ZWD1470W Front Load Washer / Dryer
Zanussi Electrolux ZWF 1430 W (E20 error)
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.11_20_2011_8_57_27_am.jpg
Sep 26, 2006 | Zanussi ZWF1430W Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
220 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
