Question about Hitachi DZBX35A DVD Camcorder
Cc will not come on eving with ac plug
My battery got low so i change to a new battery but it will not come on so I switch to ac and it still won,nt come on and i did a reset
Try leaving it plagged in over night.
Posted on May 13, 2009
97 chevy suburban AC clutch won't engage pressures
Looks like the low pressure switch gets power from a 10amp ac fuse. Power then goes to the ac relay which is powered on by the ac heat controller on the dash. Power then goes thru the high pressure switch to the compressor. The ac relay is grounded to the body. Do you have power on the lite and dark green wires going into the relay and is it grounded ?
Jul 26, 2013 | Cars & Trucks
My ASUS P4T533-C won't turn on
This is really a common problem with computers these days. It may be caused by a number of reasons like a faulty charging system, faulty battery or anything burned out on the computer's system board. But in this scenario, i would suggest the following
1. Remove the battery and connect the laptop with the AC adapter only and see if it will respond.
2. Remove the AC and re-connect the battery and try to turn it on
3. If the above two do not work, then consider changing the AC adapter for your laptop. You can try to use a different AC adapter that has the same rating as your laptop's. The problem might be with the Charger.
4. But if all this does'nt work, consider getting a Computer Technician who can open up your computer and check the circuit board, there might be a problem with one of the chips
Mar 01, 2012 | ASUS Computers & Internet
Hi. I have a HP Compaq 6820S, Intel Pentium T7250, 2 Gb RAM, 160 Gb HDD, i have a problem, Laptop won't charge battery. I let the laptop in sleep mode, around 7 days, when i come back, battery was 0%,...
try a new battery yet? (brand new fresh)
sleep mode. so you want it to run for 7 days in sleep.
ive no idea how long this laptop runs in sleep
and hibernate is longer.
no idea at all.
you do know that the speed features are programmable
right?
including what chips do and do not go to sleep'
like USB ports, WIFI, and all wake on , features. like Ethernet chip.
and more.
why not just turn it off, and let the battery last longer..
this mode sleep kills batteries faster. way faster.
leave it plugged in all the time to the wall pack.
so the battery never drains unless you need to use it, on battery.
Jul 18, 2017 | HP Compaq 6820s Notebook
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
I have a Simon XT which I installed about two weeks ago. I keep getting a system low battery message when I press the status button on the console. I had a new battery shipped and I installed it about 24...
Call your Central Station and put your account on test if it is a monitored system.
Power down the system. Disconnect the battery, then the AC adapter. Then plug the battery in first, then the AC adapter. Plugging the AC adapter in first can cause the low battery message.
if that doesn't work, with the battery disconnected, measure the voltage of the battery with a multimeter. If it reads less than 5.4 volts, the battery is bad. Bad out of the box batteries are not too uncommon.
Next, check the charging voltage from the panel. Measure DC voltage from the leads that connect to the battery. They should read around 6 Volts DC. If the charging circuit is bad, it will cause a low battery trouble and the console will need to be repaired or replaced.
Hope this helps.
Feb 19, 2011 | GE Security Simon 3 Wireless Home Security...
I bot a hp mini laptop recently.. ws working well..bt sddnly it ws nt chrgng ystrday and showed cross sign over battery in control panel.. why is it nt chrgn and wht to do?
If the laptop is still working when it is plugged in , then the ac adapter is good and the battery is just bad. If the laptop will not work when it is plugged in then more than likely the ac adapter is bad.
Oct 27, 2010 | HP Mini 1000 Netbook
No Power Using AC Power or Battery
I had this same camera. If you have a power fluctuation it can really damage the batteries. make sure it was not exposed to fluctuations
Jan 26, 2010 | Panasonic VDR-D100 DVD Camcorder
No power for AC compressor
try removing the plug off the low pressure switch on the accumalator plug a paper clip into the plug and turn ac on if it comes on then your low pressure switch is bad or your low on refigerant.
May 28, 2009 | 2000 Chevrolet S-10
I left my Compaq 2510p on standby with the battery low a couple of hours ago. I have now connected it to the mains charger and tried to turn the machine back on, but it won't turn on...any ideas what I...
Might be stuck in hibernation. Pull the battery and ac power for about 1 hour. Replace and try to boot. If fails, pull the battery and try to boot just off ac power.
Dec 01, 2008 | HP Computers & Internet
Hitachi DZBX35A DVD Camcorder Logo
55 people viewed this question
Top Hitachi Video Cameras Experts
mega_mind
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
