Question about CTX Optoma EzPro 610H Multimedia Projector
Projector problem My projector can not find a signal when using rca adaptors, but works fine when using computer connection. What's the problem
It has a faulty rca jack provable. You are lucky you have the computer jack. You can get a little vga to rca adapter i think.
Posted on Nov 22, 2007
LCD VGA Display goes on and off.
Check refresh rate and setting for external display output. It won't work with unsuitable screen resolution, color depth or refresh rate. Check all three points and I believe you can troubleshoot the problem this way.
Jun 02, 2010 | Rosewill R900J 19" Flat Panel LCD Monitor
Rca input is broken on my infocus x1 bought vga adaptor to rca and i get no image is there some reason why it won't pick up vga connection
is the rca port broken or just not getting a signal? if it's truely broken, replace or repair the main board. if it's just a signal issue, reset the settings to factory default. try hooking up your computer and see if that works.
Mar 12, 2010 | InFocus X1 Multimedia Projector
No display from composite video input
Composite video are yellow RCA jacks and are made for analog signals of standard definition video. If you are connecting a digital source or a high definition output, it may be beyond the capabilities of the projector. You may be able to find a VGA to composite adapter if you laptop or whatever has a VGA output port. VGA is along the same lines of composite (analog, standard definition).
Mar 24, 2017 | Hitachi CP-X325W LCD Projector
Projector works fine, but does not show video
Hey. Sounds like you are using some kind of dual-view or extended desktop via the computer for video. This may sometimes be a problem. If you can see the desktop but no video using the projector it is not a projector problem. It is probably your grapic card och software problem.
Try different setups in the graphic cards settings, like the projector as primary monitor etc. That usually solves the problem.
Jun 05, 2009 | Hitachi CP-S210 Multimedia Projector
Projector takes 30-40 min to recognize signal from elmo 110xg
the resolution might not match from presenter to projector. are you using rgb, composite or s-video? the signal might not match. there might be an auto adjust on the projector to read and match the elmo's resolution. if not, the elmo may have an issue sending a powerful enough signal to the projector, and need a new main board.
Apr 07, 2009 | Elmo Projectors ELMO VISUAL PRESENTER,...
Sim2 Seleco DLP SDV 100 Projector only giving white screen dimly.
it's a resolution issue. make sure the projector matches the laptop's resolution. the projector has a 800x600 native and a 1024x768 max. and it's not digital.
Mar 02, 2009 | SIM2 SDV100 projector lamp Projector Lamp
Red color absent from projector picture
try to use another vga cable connector ther might be a cut on the red color signal try to move the connector form left to right until it gives you the red color if it does change your vga connector hope this help you on your problem thanks
Feb 04, 2009 | InFocus ScreenPlay 4805 Multimedia...
Connecting a Projector to a MacBook
Hi there
You will have to find out if this Projector supports Mac
Mar 30, 2008 | Sharp XR-10X Multimedia Projector
CTX Optoma EzPro 610H Multimedia Projector Logo
209 people viewed this question
Top CTX Office Equipment & Supplies Experts
Level 1 Expert
Arora Singh
Arora Singh
Are you a CTX Office Equipment and Supply Expert? Answer questions, earn points and help others
