Question about Microsoft Xbox 360 Pro System Console
Xbox 360 Pro : To Play This Disk Error
Ok I Bought New xbox 360 pro from a guy and i had broken **** tray and i had no Hard Drive (hhd) So I Hade by old abox disk try i putted that in there and i placed the old hard driver 130 gb (hhd). then after that i set up the system and when i put the game disk in there it dosent play it says ( To Play This Disk. Put In Xbox 360 Console.)
When I Put Movies cd dvds It Plays Just Fine.
Can Any One Help Me Please
ty.
  • 4 more comments
  • samsvams May 13, 2009
    Yes I Puted In The Original Box.
  • samsvams May 14, 2009
    its not just xbox i just placed my old xbox 360's disk tray in the new xbox 360 pro.
    so you are saying that new xbox 360 pro wont play older xbox game?
  • Xboxsupport2 May 11, 2010
    Please revise your question, I cannot understand you what you're asking...
  • d3mag0gu3 May 11, 2010
    So you put the xbox360 game into an original xbox?
  • 767 Answers
Eather the laser is weak and need to be replaced , easy fix ,20.00-30.00
or the drive has been swapped with out swapping the old cd rom
board to the replacement drive , that's really bad
check the date on the old cd drive to see if it matchs up
with the manufacture date of the box , at least you will
know and not wast more money on a new laser.
Posted on Jul 02, 2009
    Problem Solver:
  • 11 Answers
Some old xbox discs wont play :( but try to keep it clean that might help!
Posted on May 24, 2009
    Problem Solver:
  • 9 Answers
The disk is probably scracthed so much, i had the problem with a halo 3 disk there is nothing realy you an do about it , you can get the disk repaired for 3 pounds at all good game shops
Posted on May 18, 2009
    Problem Solver:
  • 6 Answers
Unfortunately , a new xbox360 game cant be played in a normal xbox (not xbox 360)
The problem is that the new xbox is way different on the inside than the original xbox is. Because it is way more powerful, you can put an old xbox game into a 360, and it will work fine (most of the time), but if you try the reverse there is no way to make it work.
Posted on May 13, 2009
  • d3mag0gu3 May 14, 2009
    The only other things i can think of is these three possibilities:
    1) The drive from your old xbox360 is broken or going bad
    2) The data cable from the drive to the motherboard is going bad. have you checked the connections to make sure that everything is connected properly?
    3) Xbox360's have had many hardware revisions, that is to say changes to the actual internal design of the console. A change might have made your old drive incompatible with the new 360. This is improbable, but definitely possible. After making sure your problem isnt the first two possibilities, you should flip your xbox over and look at the stickers on the bottom. If you google "xbox 360 hardware revision" you should be able to find a decent guide to figure out what revision your console is.
Wont read games only reads dvds
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1.Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser.The laser is the part that actually reads the disc. The reality is...with all the hours and hours of game play, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3.Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything,including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock.The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
May 15, 2010 | Microsoft Xbox 360 Pro System Console
What price of Xbox360 in india (gujrat)?
Depends.....Arcade costs 16990,pro costs 21990,elite is 27990....buying an arcade wud be useless as u would hav to purchase a hard drive which again is 5000 so the best buy rite now wud be a pro...
May 15, 2010 | Microsoft Xbox 360 Console
Saying open tray on my x box 360 pro just started a week ago im trying to found out if there is a replacement disc drive for the x box 360 pro
I had this same problem a year after I purchased my first Xbox 3602_bing.gif. Most of the time this problem is due to dust and dirt getting sucked into the system by the terrible cooling system that the older Xbox 360s have. If your Xbox 360 is over 2 years old then most likely this is your problem. these Xboxes are made to stand up not lay down so if yours is laying down try tilting it upright and play it that way. This fixes the problem 80% of the time. You can also try to blow into some of the openings on your Xbox to get the dirt and dust out but I must admit this rarely works. If after trying both of these things you still have the problem, then it must be fixed by opening up the Xbox and determining the problem with the laser or disk drive. This costs time and money so you better hope that my first two solutions work!
Feb 21, 2010 | Microsoft Xbox 360 Pro System Console
Xbox 360 will not play games
check around the disk tray for dust and gentaly clean with a hoover also use a wet cd lens cleaner, this should solve the error but it may be that your dvd drive laser has died
Nov 08, 2009 | Microsoft Xbox 360 Pro System Console
Disk Drive Problems
Your old xbox is not up to date, so it is reading it wrong. Just because the older they are if not updated on live it will read games and DVDs wrong.
Aug 15, 2009 | Microsoft Xbox 360 Console
Why does My Xbox 360 Freeze when i play MLB 2K9
If it only freezes on that game, chances are it's the disk that's causing the problems. I've experienced that some xbox games act up if only the slightest scratch is on the disk. If there is, either take it back or pay a few bucks for Best Buy or some video rental place to repair it for ya.
Apr 21, 2009 | Microsoft Xbox 360 Pro System Holiday...
Brand new fable2 freezes on brand new xbox360 pro
Since your Xbox is brand new, you can just install Fable 2 to the hard disk of your xbox 360. I didn't have this problem with Fable 2 - but that's maybe because I installed it to the HD from the start. Fallout 3 did freeze on me, but installing it to the HD fixed the issue. Don't get any ideas though, you still need to insert the disk if you want to play ;-)
This is how you do it:
  1. Load the disk into your Xbox 360 console and go to your Xbox 360 console
  2. Scroll down to My Xbox
  3. Scroll across to Game Library and hit the A button
  4. This should put you on the Recent Games window and your game should be highlighted, so you should just need to hit the A button. Otherwise, scroll to the Recent Games window and choose the game.
  5. On the game screen, choose Install to Hard Drive. This process should take a few minutes, but once it is complete, you'll be able to enjoy improved performance.
You'll also note that the game screen contains all kinds of great information about the game such as the achievements unlocked and featured downloads available for the game.
Mar 08, 2009 | Microsoft Fable 2 for Xbox 360
X box 360 question
no you cant really download any game unless it is an arcade game but if your disk tray problem isnt fixed you could always change your face plate that was always my problem with my disc tray if you cant fix it thaT way you could check for a warranty and send your x box in
Jan 25, 2009 | Video Game Consoles & Games
Xbox 360
Ok i know how to solve your problem. First you must go on the xbox sit and download or buy and update disc. Then put it in your xbox and follow the on screen instructions.
Jan 18, 2008 | Microsoft Xbox 360 Console
Open Questions:
Microsoft Xbox 360 Pro System Console Logo
449 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
