Question about Ryobi Garden
Gas oil mixture
What is the right gas oil mixture for my Ryobi 31cc trimmerplus, model no. 720r
  • 246 Answers
Hello slabieniec:
The Newer 2 Cycle Trimmers use a 50:1 Ratio (OEM Suggested Ratio). I Use a 40:1 Ratio in Most of my Equipment, Except for Chainsaws and Hole Drillers/Augers. For the Chainsaws I Use a 32:1 Ratio and the Hole Digger/Auger Uses a 25:1 Ratio.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 13, 2009
  • John C Bridgers Sr May 14, 2009
    Hello slabieniec:
    You are Most Welcome.
    >>Till Next Time. May All Your Mechanical Problems be SMALL ONES and as Always, May the All Mighty Bless You and Yours. Be Safe and Happy.
    Best Wishes and Good Luck
    Respectfully
    jbridger (John)
TrimmerPlus 720r Manual
Mine would start and run on the primer gas then die. Replaced the plugged fuel screen under the flapper valves on the single large screw cover of the carb. Runs well now
Aug 30, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
What is the correct oil/gas mixture for Ryobi 31cc 15"
I'm pretty sure it's 50:1 but checked with your local dealer to be sure.
Apr 24, 2010 | Ryobi 15" Electric Factory Reconditioned...
Oil and gas mixture
Mixture is typically 40 or 50 to 1, gas to oil. The exact mix should be stamped on the gas cap.
Apr 10, 2010 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 720r weedeater. Starts, stalls, won't start.
When you rebuilt the carb did you remove and replace the welch plugs. If you did not, then that is probably where your problem is. Debris, varnish and corrosion can build up under the welch plugs and the unit will not pass fuel.
Sep 06, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Is the fuel mix on a ryobi gas trimmer 50-1 or 32-1 ?
My Ryobi 720r is 32-1 but just to be sure go to www.managemyhome.com and download your owners manual to be sure.
Aug 17, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 720r trimmer starts ok but stalls when the
The carburator needs to be adjusted a little, thin our your mixture screw when the trimmer is warmed up and idling. Well how do you get it to idle? I usually have to play with the choke lever with the throttle wide open going from choke to partial choke as needed to keep it running. Adjusting can be tricky, you need a small screwdriver. Screw all the way in then back out 3 to 3.5 turns. this should get you close. Adjust idle as needed.
Jul 05, 2009 | Garden
What is the ratio of gas and oil mix for a ryobi 31cc trimmer
just use about 3 to 4 ounces of 2 cycle oil per gallon and you should be fine. a little extra lubrication wont hurt it
May 18, 2009 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
My ryobi 31cc 15" 700r won't start
You need to push the primer button 10 times or so (the button at the top of the speed control) to get the gass pumped up into the system again. Likely gas not getting through the line yet. Takes awhile.
May 12, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How do I connect the fuel lines on the Ryobi 31cc petrol edge trimmer.
I have a Ryobi 31cc 17inch cut with gas line problems and this answered my questions. Thank You
R Green
Oct 18, 2008 | Garden
Garden Logo
456 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
