Question about ASUS P4PE-X Motherboard
Advanced BIOS setting
ASUS P4PE-X ACPI BIOS revision 1005 motherboard.
does not see the hard drive on boot but detects it in the Boot BIOS.
Error msg: "Improper frequency combination"
What should be the CPU External Frequency setting at?
Hard drive has XP installed.
Any idea?
Frank
  • 300 Answers
I would suggest using the set bios default option on the main screen. This should reset everything to factory defaults.
Be sure to exit saving settings. After that, assuming there's no hardware damage, it should start fine.
Hope this helps. Please remember to rate this information.
Thanks
Posted on May 13, 2009
How can i boot or reformat using usb in motherboard p4pe-x, or can i boot from usb from that mobo instead? If so, how? I see on boot setup the removable devices, under that after i click removable...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
Apr 27, 2011 | ASUS P4PE-X (90-M8LAW1-G0EAY) Motherboard
Does asus p5gc-mmx/1333 support usb booting
Yes, enter the bios by pressing the del key on start up, you will need to have the usb device connected.
Enter the advanced settings tab and your usb device should be selectable as a boot device.
If the bios has no such option, find out what bios revision you are using (on the first blue screen after hitting the del key) and check the asus website for a bios revision that is newer.
Asus website
http://support.asus.com/download/Options.aspx?SLanguage=en&type=1
I hope this has been helpful
Apr 03, 2011 | ASUS P5GC-MX/1333 Motherboard
Hard drive won't boot up. It just keeps restarting and never gets to post
Hi
remove the HDD from you mother board and start you system If you able to get in to the BIOS set then there may be short circuit in the HDD
Dec 18, 2010 | ASUS P4PE/L (ASU49J) Motherboard
HOW CAN I GET MOTHER BOARD SOFTWARE OF ASUS P4GE MX ACPI BIOS REVISION 1005
pliz help me i want to download mother board installer for asus p4ge-mxacpi
Sep 01, 2010 | ASUS P4PE-X Motherboard
P4pe x cannot detect hhd drive
If the BIOS cannot detect the hard drive then :-
1. The hard drive data cable or power connector may not be inserted properly.
2. The motherboard disk controller is faulty.
3 The hard disk is faulty.
To test the motherboard disk controller, connect another hard disk to the motherboard and go into the BIOS to see if it detects the hard drive.
If it detects the hard drive, then the other hard drive is faulty and need to be replaced.
Another way to test the "faulty" hard drive, connect the hard drive to an USB hard drive adapter and plug it into a working computer's USB port. If this computer sees it as an external hard drive and you can open the folders and files the the hard disk is OK, and the fault is a faulty disk controller on the motherboard.
Jun 14, 2010 | ASUS P4PE-X Motherboard
Looking sound driver installer to my computer asus p4pe acpi bios revision 1005
Go to asus.com and enter your info there. You will be shown a page with all the pertinent drivers for your computer. Download your audio driver and then install it. If you still don't have any audio after that then your integrated sound card may be burned out. You can easily fix that by getting a PCI sound card.
Mar 19, 2010 | Intel Pentium 4 1.7G, 1.7 GHz...
BIOS issue or ? Rebooting PC into BIOS on ASUS A7V8X-X ACPI BIOS Revision 1003, 13.2.2003
If you lose time and day, means the little battery on your motherboard is done. Get a new one, replace it, should be fine then. As far as booting into BIOS, there should be a boot option, and you can boot into a hard disk, a usb or a cd rom drive. Of course in this case, choose the hard disk that has your operation system on it.
May 30, 2009 | ASUS Computers & Internet
PC won't boot if SATA drive connected, drive works fine if plugged afterward
Try Hirens Boot CD. It has a lot of programs on it to detect format etc.
I think your hard drive has a missing or corrupt MBR and it needs to be replaced.
When I have had a hard dive not recognized I hve used Super Fdisk to format and reset hard drive.
On the boot disk
Nov 03, 2008 | ASUS K8N-E Deluxe nVidia nForce3 250...
Failed to load to windows XP
wow yea it's looking for grub/linux i did that same thing once you need the xp install disc insert that hopefully you can get into your bios then go and set it to boot from disc restart and go through the options till you get to repair and type in fixmbr
Oct 06, 2007 | ASUS P4PE Motherboard
ASUS P4PE-X Motherboard Logo
534 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
