Question about Yamaha RX-V2092
Problem with yamaha rx-c2092
Hi, I have a yamaha rx-v2092, and i can't to turn on.. the receiver turn on the display ligth for 2 seconds and then turn off
  • 40 Answers
Hi, try to unplug this unit from the wall for a minute or so, It may just need reset. If it still does this I would say that you have a loose wire inside where the power supply is. I would not recommend working on this unless you are computer savvy.
Posted on May 13, 2009
How can I factory reset RX-V2092
Press MASTER ON/OFF on the front panel to
release it outward to the OFF position to turn
off this unit
Press and hold STRAIGHT on the front panel
and then press MASTER ON/OFF inward to
the ON position to turn on this unit.
This unit turns on, and the advanced setup menu
appears in the front panel display.
Rotate the PROGRAM selector on the front
panel to select "PRESET"
Press STRAIGHT on the front panel
repeatedly to select "RESET"
confirm your selection and turn off this unit
Dec 10, 2016 | Yamaha RX-V2092
Looking for remote for this Yamaha RX-V2092
This unit has 2 remotes, main and 2nd room remote.
Both are available with Remote.com
Click that link for price info.
Aug 29, 2010 | Yamaha RX-V2092
I have a yamaha rx-v2092. The unit turns on for
it could be the problem with t108 transformer or with the power on relay circuit eg. zener diode
Jan 12, 2010 | Yamaha RX-V2092
No power yo frount speakers
check powersupply or check the amp driver stage voltages
Sep 17, 2009 | Yamaha RX-V2092
RX-V1600 when i turn on no sound or channels display on
If you are sure that the speaker wiring is correct and connections are good, then:
  • Check the input and output connections are correct for each source.
  • Check that the input mode is not set to DTS or Analog - rotate the input selector to the source and the press the input mode, set it to Auto.
  • Also check that the front speakers to be used are selected A or B (or A+B).
  • If there is an optimiser microphone supplied with this receiver, ensure that it is not still plugged in.
Hope one of these solutions work for you.
Jul 19, 2009 | Yamaha RX-V1800
Yamaha RX-V995 receiver turns on & then powers off 2 seconds late
I suggest you run self diag.  press [FM/AM] key + [Input mode] key and press the [power/standby] switch.
ps prt = power supply problem
dc prt = shorted output or leakly cap in channel
tmp prt means to hot on heatsink
you'll likely have to measure the resistances of the output FETs to find a short,
Jan 02, 2009 | Yamaha RX-V995 Receiver
Rx v2095 receiver - No sound from either front main speaker
I have had similar problems on a Denon. I suspect your DSP needs repaired and/or replaced. Need to contact authorized Yamaha repair shop or a competent local repair facility. I have a Yamaha RX-V2092 which is similarly designed. I have had it for 10 years. Hope this helps.
Nov 29, 2008 | Yamaha RX-V596 Receiver
Rx-v2092
Sams Photofax has the paper service manual for $20.00 U.S>
No Efax downloads
May 27, 2008 | Yamaha RX-V2092
This yamaha receiver goes on for 1 second then off.
This is the protection circuitry. Mine is doing the same thing. I'm trying to get a schematic for it right now ;-)
Jon
Oct 23, 2007 | Yamaha RX-V2092
Yamaha RX-V2092 Logo
347 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
