Question about Dynex 32 in. LCD Flat-Panel HDTV
No picture on new Dynex 42" lcd hdtv
New 42" Dynex lcd hdtv.. yesterday hooked it up but it has no picture, no display when I press menu or input from remote or buttons on tv, all I get are some black and white rectangles on the tv. These move and change shape when I press the buttons or remote but that's it.. what wrong and what do I do??
    President:
  • 814 Answers
This television is malfunctioning and should be return to place of purchase for a replacement. The Dynex customer support website is:http://www.dynexproducts.com/pc-696-23-dynex-42-1080p-flat-panel-lcd-hdtv.aspx You can place this web address in your address bar and got to the website. Here you will find all the customer support information on your television. If you have questions, You can use the e-mail function to talk to customer support directly. Give them the model number of your television and the problem with the television malfunction on turn on. They will be able to help you get a replacement or service for the television. You can also call customer support at this telephone number 1-800-305-2204 between the hours of 8am and 12 am CST. I hope this information helps you solve your problem.
Posted on Jun 06, 2009
  • 40 Answers
Do you have cable or DVD player connected yet? If not, connect your cable to the back of the LCD via Coaxial cable. Next turn channel to 3 or 4 whatever channel you use for cable. Then use auto programming to find all of your cable channels. If no cable connect the DVD outputs to one of the AV 1 or Av2 inputs on the back of your LCD. Power on the DVD player and change your input to which ever AV you connected it to. You should see a blue screen and your DVD Player Icon.
Posted on May 13, 2009
Unlocking the remote and panel for Sharp Aquos LC-46LE832U 46 in. HDTV LCD TELEVISION
When all else fails read the owner manual page 35:
"• To unlock the buttons on the remote control by using the
touch sensor panel of the main unit (see page 25):
1 Press MENU to display the MENU screen, and then
press VOLl/k to select "System Options".
2 Press CHs/r to select "Operation Lock Out", and
then press INPUT.
3 Press CHs/r to select "Off", and then press INPUT.
4 Press MENU to exit.
• To unlock the buttons on the TV, press MENU on the
remote control, and then select "Off" in "Operation Lock
Out".
Took 5 minutes to find the manual for this unit. GOOGLE
Apr 05, 2012 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How to enable the input of lcd
hi,
u can sellect input by following setup
1. Press INPUT. on remote
(A list of selectable sources appears).
2. Press INPUT again to select the input
source.
( An image from the selected source automatically
displays).
Each time INPUT is pressed, the input source
toggles.
If the image does not come in clearly from the external
equipment connected to INPUT 1 or 2, you may need
to change the input signal type setting on the "Input
Select" menu.
1. Press MENU to display the MENU screen,
and then press c/d button (on remote) to select "Option".
2.Press a/b button (on remote) to select "Input Select", and then
press ENTER.
3.Press a/b button (on remote) to select the signal type you
want to set, and then press ENTER.
4.Press MENU to exit.
just try these. need further help feel free to contact.
ok.
Dec 20, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I just bought a new dynex 32 inch that did not come with a manual. I attached the cable into the correct area however I am still unable to see my cable channels even when changing the input. What am I...
Check this link to download the user's guide or quick setup guide. Press menu > channel, go down to TV source change it to cable and go down to auto scan and press > to start programing the channels into the LCD memory.
Sep 14, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Have a lcd 42 dynex picture dark
Have a 40" Dynex LCD TV...Has been workin ok but i just turned it on today and pics are dark and yet all pics settings are ok. Pics are still dark even when i increase brightness from menu.
May 18, 2010 | Televison & Video
When I tried to hook up my dynex tv to my satellite box it kept saying no signal. Do you know what I am doing wrong?
Hello
Check the input setting in the menu setup.
You should have a different inputs such as.
1 cable
2 hdmi
3 sat
Choose sat or satellite.
Apr 06, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Black square on screen that covers half the picture appeared on my 42" sharp aquos tv.
sounds like you might have PIP turned one (picture in picture) .. if there is no input hooked up for the PIP . you will just get a black screen ... you should be able to move that PIP around and change its size .. indeed turn it off .. look for a menu item called PIP .. select PIP off ..
Nov 06, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
LGA connection
You have to select the correct input source, for your television to recognize the computer as the input source. After completing the hook-up connections. Turn on the television. Use the television remote to select the input source. 1.push the input button 2. use the up and down arrows to find the VGA input and press enter.Now turn on you computer and adjust the display controls of the computer if necessary. This information was found on the Dynex website in the owner manual on page 8. The website can be found with this link.(http://www.dynexproducts.com/pc-680-23-dynex-32-720p-flat-panel-lcd-hdtv-matte-black.aspx) Just copy the link and paste it into your address bar. You can find a customer section and communicate with customer service through the e-mail service. You can also call the customer service at the customer service telephone number 1-800-305-2204. Give them the model number of the television and the problem you are having connecting it to the computer. I hope this information helps you with your problem.
May 30, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Picture too large for screen. friend hooked up computer once & now can't resize.
Go to the menu settings and check the picture size. Most likely it's set wrong. What is the normal input from? etc...
Mar 14, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Dynex 42" HDTV - pressed "Comp" button now cant get back to TV
Press the TV button on the remote. You are confusing the Comp button with the Input button which allows you to switch between input ports.
Dec 14, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Dynex 32 in. LCD Flat-Panel HDTV Logo
879 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
